Old May 01, 2011, 08:03 AM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľký Krtíš
Joined Dec 2006
Build Log
My new Jet-Teng Models (JTM) L-39 Albatros
Hello fighters...
I finished build of my new L-39 Albatros made by Jet-Teng Models > http://www.jet-teng.com/main/2008117...20098810473498 It's a matter of my heart because I see this jet every morning when I go to work I had to modified some things on mind. I used 5 servos HITEC HS-225 MG with EZ servo mounts on ailerons, flaps and rudder, 2 servos HITEC HS-125 MG on elevators and one TURNIGY S3317M metal gear servo for nose gear controlling. I have got separate external TURNIGY MEGABEC 8A with 2S Turnigy 1600 mAh for receiver FUTABA R6014HS FASST 2,4 Ghz. My power system is carbon edf VASAFAN 90mm (http://www.vasamodel.cz/img/foto_90_02.jpg) with original carbon intake lip powered by motor HET TYPHOON 700-68-1680 kv and ESC CASTLE CREATIONS ICE 100 (I made external fan for improve cooling during flight) with 8S TURNIGY nano-tech 4500 mAh 25-50C lipos. I had to molded my own intake and I made thrust tube with exhaust diameter 72mm, I measured in this configuration more than 4,4 KG of static thrust...I used original JTM scale struts with newest E-FLITE tricycle 60-120 full metal electric retract landing gear system which is designed for aircraft with RTF weight up to 7 kg...work very nice and is very strong...Cockpit is for BAE HAWK but I modified it according original L-39 cockpit...flaps are moving slowly by this great modul: http://www.hobbyking.com/hobbyking/s...idProduct=8863 Here are some pictures of my build, after maiden flight I will share video...Here are two videos from test of function of my flaps and retracts...ENJOY
E-Flite retracts on my Jet-Teng Models (JTM) L-39 Albatros (0 min 39 sec)
Flaps on Jet-teng models (JTM) L-39 Albatros (0 min 41 sec)
pajlotmato is offline Find More Posts by pajlotmato
Old May 01, 2011, 08:08 AM
Joined Dec 2006
This is original
This is real pattern of my l-39...
Old May 01, 2011, 09:54 AM
jetfan20 is offline
Find More Posts by jetfan20
orlando florida
Joined Jun 2005
7kg That's a bit heavy isn't for such a small plane?
jetfan20 is offline Find More Posts by jetfan20
Old May 01, 2011, 10:20 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
The plane looks GREAT!!! nice work!!!. I love the cockpit..looks awesome!!!
Good luck on the maiden flight. Let us know how it goes.
falcon5 is offline Find More Posts by falcon5
Old May 01, 2011, 11:49 AM
Joined Dec 2006
NO, retracts are designed for planes up to 7 kg, my isn´t that heavy...
Old May 01, 2011, 04:24 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nřtterřy, NORWAY
Joined Mar 2006
Very nice indeed! Good luck with the maiden flight
kimhey is offline Find More Posts by kimhey
Old May 02, 2011, 02:14 PM
Joined Dec 2006
I have a little concern from maiden flight because the model is a little bit heavier but I can´t wait to see him fly ...
Old May 03, 2011, 03:38 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Nice! What is your ready to fly weight?
like2fly! is offline Find More Posts by like2fly!
Old May 03, 2011, 07:46 AM
carrot41 is offline
Find More Posts by carrot41
Dover,Ohio
Joined Jun 2008
Awesome!!
Your plane looks great!!
Thanks for taking the time to post all those pictures, you have saved me a lot of time
planning some parts of my build!
If I have a question, I'll just look at the pics you posted..... :-)
I do have a question....?
The control horns for your flaps appear different from the others.
My kit did not contain those "straight" horns.
Mine are all offset like your aileron ones....
Did those come with your kit?
Are they straight for a reason, more leverage maybe?
So, what is your final weight?
I'm also a little nervous about what my final weight will be.
I plan to just land hot the first couple of times and no steep banks in the landing pattern.
It appears you have a long runway, so that should help.
Good luck with your maiden and please keep us posted.
Thanks again for the pics!
Bill B.
carrot41 is offline Find More Posts by carrot41
Old May 03, 2011, 02:11 PM
Joined Dec 2006
Hi...
Thanks...Control horns on my flaps are my own home made, these straight control horns help reduce flat torque of servo because the originals horns were not good, servo has problems with hold down position...Yes, we have a long runway and I counting on it
Originally Posted by carrot41 View Post
Awesome!!
Bill B.
Old May 03, 2011, 02:12 PM
Joined Dec 2006
It is more than 4 kg...
Old May 03, 2011, 02:19 PM
Joined Dec 2006
So today I met one last thing before maiden flight and I shot the model with the template, original 1701 Slovak Air Force ... ENJOY
Old May 03, 2011, 02:51 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Right on!
Did you have him sign it?
that must have been fun
thanks for sharing
Ron101 is offline Find More Posts by Ron101
Build Log Jet Teng Models L-39 Thunderbird by UsaRcJets BILLYDSRC Electric Ducted Fan Jet Talk 75 Sep 18, 2011 07:58 PM
Discussion I got my flyflyhobby 70mm L-39 But.... seals666tw Foamy EDFs 2 Mar 09, 2011 07:01 PM
New Product New Great Planes Jet!: The L-39 Albatros SwissBoy Foamy EDFs 7 Dec 28, 2007 03:48 PM
K&A Models L-39 Albatros GlasairAllen Electric Ducted Fan Jet Talk 20 Nov 29, 2001 12:04 AM
