Old May 01, 2011, 07:09 AM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Build Log
AP UAV like plane , using 10g BL
after looking at jarel design 's UAV , and talking with him over some sapects , i simply could not wait for him to kit one up .
- Thanks Richard , it's all your fault / inspiration . lol
so i used some cheap things .
less than 1 sheet of $store readiboard
1, 1/4 basswood dowel for LE / main spar
4, 1mm x 6mm , basswood spar
some 1.5 thick , good balsa sheet for wing ribs
( i wanted to test mixing balsa and foam for an upcomming project )
1/4x1/4 balsa stock for TE of wing that gets carved & sanded to a taper
1 of those $1.25 chuck gliders ...
chopped and turned into a fuse. they have decent and easy to work with faom .
2 styrene tubes for holding baloons , for part of tail booms.
1 foam plate , to get 1.5mm depron like foam for vert stabs.
HK 18-11 2000kv bl
GWS 5x3
plush 6a esc
2 3.7g servos
460mah 2s lipo
small MD80 knock off cam .
30in WS , 4.25in chord , no taper or dihedral ,only wash out and reflex in aileron
length 28 inch
AUW ? have to get my scale sorted , soon
early build pics and info in my blog .
http://www.rcgroups.com/forums/showthread.php?t=1422908
last flight , testing CG and finding and fixing the last few flaws
AP drone on fogy day .. (8 min 24 sec)
wee cam on top .
AP Drone Fogy Day , on board cam footage (7 min 25 sec)
plans for later will be a box or mono block fuse to replace the chuck glider .
and less camberd wing , and 3 deg of dihedral or so.
she has crazy lift
Prime_8 is offline Find More Posts by Prime_8
Old May 04, 2011, 09:26 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
good flught in wind
great flight! even in wind ... i have no idea the AUW , i will get that later tonight .
man can this beast lift ! i had to add 30g! of ballast in lipo bay
( i could run a 1000mah 2s if i need !,or both mu 460's in paralel
that woudl be mad air time as i only used 40% of the lipo today , the meter said 62% left )
any how here is some stills snapped from the onboard cam ..
one is inverted ! and ver cool to watch ...
I will have the videos converted and posted later tonight ... or so ..
- yeah i hit a fence at the end .. LOL
no probs just pop off some glue on one of the under-spars .. used CA should have been GG . LOL
Old May 04, 2011, 10:57 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
and here is teh on board cam's view (FPV)
the ground cam will come later tonight ...
this proly has 40 min left on conversion but i have to head to sleep soon .
Old May 05, 2011, 01:25 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
well that sucked .. LOL the link is gone .. hmm ..
ah well
on board cam link ..
AP Drone , big day .. small crash at end (8 min 50 sec)
and some pics taken form the ground cam .
ground cam is uploading / converting now ..
so 30 min till visable
AP Drone , ground cam , nice flight .. with a loop near end (8 min 45 sec)
Old May 07, 2011, 05:20 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
just did a AUW /RTF = 180g , that inculdes LiPo & ballast LOL
yet she has crazy lift and still moves quick and nice.. and i have to fly her down .. else she will just keep floating .. LOL
I think a rudder mod is in order.
Old May 07, 2011, 03:10 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
rib/ foil pattern for those who are interrested..
simply cut the rat tail off TE to match your chord length .
Old May 10, 2011, 07:15 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Great windy day flight !
only got 10 min of air time ... but got most all of it
the last flight it was too windy and main cam battery died , and teh on board cam was fussing ( loose SD card , was culprit ) .
any how got some silid footage from ground and some great shots on the plane ..
the wid was freshening from dead calm as i arrived , by the tim i had her in the air ther was a breez and some dark clouds came over ( our bad WX for tomorow showing up .. LOL )
any how she flew great even in head wind ~ = to 90% max thrust / forward speed. LOL
but she flew great and was very predictable.
the videos ar cooking now so only be a few hours ..
to edit and convert n such .. but here are some pics .
Old May 10, 2011, 11:02 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
video!
AP Drone , great windy day flight (4 min 32 sec)
AP Drone (on board cam) , great windy day flight (5 min 7 sec)
Old Jun 10, 2011, 12:06 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
More fly .. loats of fun
the on board cam only got 1.25 flights .. lol it did not have as much chareg as i thought ..
( too bad there was not V check prot on it . lol )
any how some pics. & vids.
ground cam of 3rd flight .. Mike was flying for me .. as bug were driving me nuts.
AP drone ground cam . on TJ maiden day (6 min 46 sec)
here is 1st and 1/4 of 2nd flight form onboard cam ..
AP drone fly OBC , before fog came (2 min 57 sec)
was great fun .. but i did go high on one flight and it is a shame the cam stopped redording .. Mike figures i had her 200 + feet or so ..
Old Jun 10, 2011, 01:51 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
thats cool.Shes a really stable plane. i was so relaxed flying her!! Well after what i was through today lol it was nice lol
Eastcoast78 is offline Find More Posts by Eastcoast78
Discussion Anybody using their SD-10G with a simulator? Mr. Wiz Radios 5 Jun 17, 2012 11:54 PM
Build Log RC UAV Ground Station using 900 MHZ two way data modem FAKHREALAM UAV - Unmanned Aerial Vehicles 24 May 29, 2011 02:14 AM
Discussion Anybody using their SD-10G with a simulator? Mr. Wiz Radios 0 Mar 25, 2011 03:01 PM
Discussion Anyone using or modifying the Predator UAV for AP? sweatyfingers Aerial Photography 17 May 18, 2009 03:24 AM
