Old Aug 18, 2003, 07:35 PM
BillBowne
BillBowne
Guest
n/a Posts
General Western Meteor Monoplane
Just had the maiden flight of my new Meteor monoplane. Geared (2.3:1) 6V Speed 400 on 8 old 500AR cells. Weight is 26 oz, wing area is 300 sq. inches. Covering is aluminum Litespan (BOO!) with black craft tissue and Sharpie pen trim.
Was a bit slower with an APC 8X6E than I expected, but showed no bad habits. I only flew it for about 3 minutes, then landed as the Sun was right off of the approach end and made visibility miserable. I'm thinking of putting in a geared brushless, but it has to be able to fit where a Graupner gearbox does -- any suggestions?
I've been shooting photos during the build and have drafted an article on it for submission to Jim.
Bill Bowne
Old Aug 18, 2003, 07:40 PM
BillBowne
BillBowne
Guest
n/a Posts
Another shot, catching Micki, my wife as she takes photos of the plane for our scrapbook (I'm not allowed to fly anything until she has a picture of it).
Bill B.
Old Aug 19, 2003, 08:38 AM
BillBowne
BillBowne
Guest
n/a Posts
Any ideas on a brushless?
Old Aug 19, 2003, 08:53 AM
Christer Lagerstedt is offline
Find More Posts by Christer Lagerstedt
Stockholm Bromma, Sweden
Joined Mar 2000
Very nice model. If you want some more speed, do as I have done and install a SAITO 53 cc 5-cylinder radial engine.
(Just kidding, my model is quarter scale)
Christer Lagerstedt
Haninge MFC, Sweden
Christer Lagerstedt is offline Find More Posts by Christer Lagerstedt
Old Aug 19, 2003, 10:39 AM
BillBowne
BillBowne
Guest
n/a Posts
If I bought a glow engine, I'd better have a fast car, too, so I could get away from my wife, because she hates glow engines
Bill B.
Old Aug 19, 2003, 10:43 AM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
Very pretty plane.
I'm guessing here but a Mega 16/15/7 or /8 would probably be about right as they can swing a pretty big prop and use your batteries. You might want to ask in Power Systems.
Matthew
Matthew Allen is offline Find More Posts by Matthew Allen
Old Aug 19, 2003, 01:28 PM
BillBowne
BillBowne
Guest
n/a Posts
Will a Mega motor fit in a Graupner gearbox?
Old Aug 19, 2003, 03:10 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Bill
Cute little model - hope the plan escapes into the Great Wide World. Parasols just have a certain 'something'
But if Sue found me publishing shots of her from that angle - I'd be out of hospital around Christmas
D
Dereck is offline Find More Posts by Dereck
Old Aug 19, 2003, 03:20 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Ah. I THINK that you can use an MPjet25/35 with teh adapter kit that clamps on teh motor to get a beam mount.
Actually, a better upgrade would be a long can 480, and a 9x6 or 10x7, in fact you would probably find a 9x6 on it as it stands would improve matters a lot.
Your original combo is more right for a 22oz plane ...
Old Aug 19, 2003, 03:22 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Shaft is wrong at least - 3.2mm v 2.3mm
I think the Mini AC range has the right mounting holes and shaft diameter.
But the FG series box is pretty poor frankly. I'd change the box and make up a new mount.
Old Aug 20, 2003, 06:36 AM
Luxembourg
Joined Apr 2001
With the Mega you wouldn't need a geabox if you went for a high wind (7+). This would also make the plane quieter.
http://www.aircraft-world.com/prodde...161508&from=14
Matthew
Old Aug 20, 2003, 11:26 AM
bob the builder is offline
Find More Posts by bob the builder
planaholic
bob the builder's Avatar
Zig Zag, OR
Joined Mar 2003
you could also go for one of the outrunners, I here they swing a pretty big pop with authority.
bob
bob the builder is offline Find More Posts by bob the builder
Old Oct 07, 2003, 10:33 AM
BillBowne
BillBowne
Guest
n/a Posts
Just a quick update. I decided to go the easy way and replaced the 6V S400/Graupner 2.33:1 gearbox with the 7.2V equivalent. Since I just happened to have on hand two 10-cell packs from my wife's Miss 2 that fit fine AND keep the CG good, I thought I'd try it.
Result: I gained almost 10 watts/lb, with only a 2 oz. overall weight increase. The Meteor flies much better now, and doesn't show any sign of the increased weight.
Bill B.
p.s. Yes, Dereck, I know this is what you've been preaching for some time!
Old Oct 07, 2003, 11:05 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
he other option would have been to put a long can 480 in the same box. More power, better efficeincy, and not so much extra weight.
In fact you could drop to 7 cells on that setup...
Old Oct 07, 2003, 02:35 PM
BillBowne
BillBowne
Guest
n/a Posts
Good thought. I went with the 7.2V as I know it works -- it's what's in my wife's Miss 2 as the stock 6V is neither powerful enough nor heavy enough.
Bill B.
Article General Western Meteor Bill Bowne Electric Plane Talk 20 Jul 30, 2010 06:48 PM
