Old Aug 22, 2003, 08:39 PM
FoamCrusher is online now
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Originally posted by goofup
My T-Hawk (virtually the same plane with a fiberglass body like the Aerobird) was destroyed after the 6th crash.
goofup:
Are we talking about the same Tiger Hawk? Fiberglass body??? The T-Hawk I am speaking of is this one http://www.toytx.com/thawk3chrtf.html It has a flexible polypropylene body with a 380 motor.
Mine has a wrinkled body from quite a few - many more than 6 - nose-in "landings" but it is far from destroyed. You would have to do something very far out to break the carbon fiber rod fuse or the tail feathers.
I have put a few dings in the wing (hitting poles tends to do that) and taken a few chunks out of the trailing edge of the wing when the rubber bands broke and the wing pivoted into the still spinning prop, but it still flies and has little if any epoxy added in the way of repairs. A TM or SS would not be so lucky.
FoamCrusher is online now Find More Posts by FoamCrusher
Old Aug 23, 2003, 05:26 AM
goofup is offline
Find More Posts by goofup
goofup's Avatar
Yukon, OK
Joined Apr 2002
Same plane. The body was "unflyable" and the carbon boom was broken in a separate incident. I got parts, but could not get it back together in flyable condition (servo, servo tray, control rod, etc. problems).
All I'm saying is that a "first" plane and a "wind" plane shouldn't be the the same plane. Of course we all want to fly whenever we get the urge, regardless of the wind. We all know it's much easier to learn on a slow flying plane when it's calm. And that it's harder to learn on a fast flying plane in the wind. This is the choice the beginner has to make. It's his plane and his learning curve.
Hey, I hate wind too. I'm building a plane right now that will handle some wind. But I won't fly if it's over 10 mph, or if it's over 100 degrees. To me, it's just not that much fun.
goofup is offline Find More Posts by goofup
Old Aug 23, 2003, 02:30 PM
Elk Grove, CA
Joined Sep 2002
What I have noticed using different battery packs in the T-H (OEM seven cell 600 mAh NiCd, 2S2P 1200 mAh E-tech, 2S2P video cam LiPo, eight cell 650 CPB NiMH, seven cell NiMh and eight cell 1050 KAN NiMH) is that the heavier the pack, both the faster it flies and the better it penetrates the wind due to higher wing loading.
One of the nice things about the T-H is that by using different weight packs, I can adjust the weight to fly in winds from 0 up to about 10-12 mph (as read on a digital wind meter). There are some minor CG issues, but within the packs mentioned above it flies very well.
I guess what I am saying is that if you fly the T-H with a light battery in light winds it makes an excellent "first" plane (the 8 cell CPB 650's seem to be the best for a beginner - lots of power to get you out of trouble, light and reasonable duration).
As you crash less you can go to heavier packs and fly in some wind. I tried learning in 5 - 8 mph wind and it was frustrating. No wind is much better, but depending upon where you live, you may not have much choice and in that case the T-H is still a good first plane - with the right pack. Your mileage may vary.
FoamCrusher
Cool Six Keys to Success for New Pilots aeajr Beginner Training Area (Aircraft-Electric) 1127 Yesterday 10:59 PM
Cool Question about setting surface throws for new pilots aeajr Electric Plane Talk 22 Aug 15, 2009 02:46 PM
Discussion Adding expo for new pilots in G3? Steve450se Simulators 0 Jan 19, 2007 11:15 AM
Discussion Tip for new pilots - HS-55's CHCHGSR Micro Helis 3 Jul 27, 2006 05:20 AM
Cool Ourstanding resource for new pilots aeajr Beginner Training Area (Aircraft-Electric) 0 Feb 11, 2005 08:01 AM
