Old Apr 14, 2012, 09:18 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by leethetreeguy View Post
Yea, I agree Joel. That is part of the disavatages I was thinking of. Flight envelope would dwindle. But, some planes can't do much of that anyway. I was just thinking that some planes could benefit from permanent flaps in my yard. hahaha. Slow and low, relaxing flights every now and again are kinda nice.
Lee
Lee,
Might also be useful when flying indoors, but I've found spoilerons to be better for that. For the Mossie, I programmed a 3-way switch with 15 degrees of spoilerons, none, or 15 degrees of flaperons. The flaperons made it much more difficult to fly slowly. They made the plane very prone to tip-stalls, and low-speed aileron authority was pretty much non-existent. In contrast, the spoilerons very noticeably extend the lower end of the flight-envelope. They allow for great roll-control at very low speeds & at high angles-of-attack. They dramatically improved low-speed maneuverability. I use the spoilerons when flying in tight quarters, like when we only get one indoor soccer court at our winter flying spot.
If I remember correctly, someone extended the leading-edge of the wing of the UM Sukhoi to slow it down for flying in cramped quarters indoors. Might be an option for your backyard flying.
Joel
turboparker is offline Find More Posts by turboparker
Old Apr 15, 2012, 03:17 AM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Originally Posted by seitz2c View Post
I have a love hate thing going with the corsair ! I bought a slightly crashed one on Ebay .My intention was to rip out it's guts for a P-39 I'm building.
I took it to the Sunday afternoon indoor fly in It flew so well that I just coudn't cut it up. It saw extremely tail heavy I added the dime and 7 lead shot to hit the CG.the stock prop has plenty of power to fly indoors. it was a little fast for the gym. I then dropped in 30 degrees of flaps . Just what to docter orderd. with the extra drag it slowed down . I added 10% down ele trim to keep the nose down .I'm useing a DX6i transmitter.
The Hate! there were 3 other Corsairs there they ALL looked the same. But it flies so well I decided to repair the crash damage and repaint. I decided on the AU-1 1956 version . Yes I know that all the AU-1 went to the Marines. BUT I have a photo of 4 AU-1s setting on the ramp with NAVY painted on the aft fuse.
Paul
WOW!!!! That is nice looking!!! I really like the exhaust!! That looks GREAT!!! Glad you didn't rip into her! Wish you could paint my full-size PZ Corsair in that scheme..... even the Ottumwa is cool lookin! Gotta sport where you're from!!
rcoconut is offline Find More Posts by rcoconut
Old Apr 15, 2012, 08:25 AM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
The flaps were done with the Tx .the linkage rod was moved to the 2nd hole closest to the control horn pivit point.
the flaps let me fly in a smaller space .As with everything to do with flight there is a trade off . I don't think I'll be going to many loops with a 40 foot ceiling. because of the increased drag you have got to use a little more power . this cuts down on your flight time. you let the nose rise and you stall quickly.
Ottumwa Naval Air Station closed in 1946 A lot of navy pilots started there
Paul
seitz2c is offline Find More Posts by seitz2c
Old Apr 15, 2012, 09:00 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Paul
Deflecting the ailerons up instead of down will allow for slower flight and it will be more stable and easier to fly.
When the tips are deflected down, they can stall before the root, and the plane fall off to one side or the other. With the tips up, the wing root will always stall before the tips.
The plane will fly with a higher AOA, which produces more lift and Drag.
UNGN is offline Find More Posts by UNGN
Old Apr 15, 2012, 10:22 AM
seitz2c is offline
P. Seitz
Joined Jan 2006
normally I would agree 100% but my corsair shows no sign of wanting to tip stall ! it might be a combination of the undercambered wing and the wing tip dihedral.
Paul
Old Apr 15, 2012, 05:07 PM
Stuart Linfoot is offline
Find More Posts by Stuart Linfoot
build, fly, crash, repeat ...
Stuart Linfoot's Avatar
United States, OR, Beavercreek
Joined Jan 2004
it was flying so nice, like it was on rails, it was just perfect, then someone let the dog out ......
Stuart Linfoot is offline Find More Posts by Stuart Linfoot
Old Apr 15, 2012, 05:27 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Dang, that looks pretty serious. Arrrrggghhh, dang dog.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Apr 15, 2012, 06:26 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I do most of my flying in town and this is my second biggest fear, next to having the plane go out of control and hurt somebody. There have been a few close calls with stray dogs and one of these days...
Did you see it coming? I got a fair bit of practice at hand-catching planes this winter, when the snow was really deep and I didn't want the electronics to get wet. I figure it might be a good option for that day when a dog comes out of nowhere and there is only one thing on his "mind".
Jovanx is offline Find More Posts by Jovanx
Old Apr 15, 2012, 06:57 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
With my Champ at the park, I found it easy to fly low and let the dogs chase it across the park and then hurry back after I've worn them out. Put a little high speed distance between them and your landing.
whirlcap is offline Find More Posts by whirlcap
Old Apr 15, 2012, 10:16 PM
BrundleFlyBy is offline
Find More Posts by BrundleFlyBy
Never stop being a kid.
BrundleFlyBy's Avatar
United States, CO, Manitou Springs
Joined Jan 2012
Looks great, Paul. You may have seen this one:
http://www.rcgroups.com/forums/showp...3&postcount=72
I think it looks great as well, but I like yours even more.
I've been thinking that Parkzone would do well to offer some alternative paint schemes for many of their planes.
BrundleFlyBy is offline Find More Posts by BrundleFlyBy
Old Apr 15, 2012, 10:51 PM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
Awe man, after all that you've done to get her in the air. Not sure if I'd rather have a crash or have the dog eat it??? Sorry to hear 'bout that. Hopefully you'll be too busy flying the Carbon Cub SS (or MiG?) to keep your mind off the Corsair???
Old Apr 16, 2012, 01:10 AM
Joined Jan 2004
Yeah, I want the carbon cub, but I was told "no more planes" today, so I think the carbon cub is gonna have to wait.
that corsair was flying so nice to, it went where you pointed it, was very predictable, the power off glide couldn't have been more perfect.
I just couldn't outrun the dog, no matter how hard I tried, that dog is one fast SOB, I flew the plane to the far end of the field, did a 180 degree turn, and flew it back as fast is it's little motor would haul it, and it just wasn't fast enough, the dog was literally under it the entire way.
yup, I'm really disappointed plus I'm told I spent to much already so I can't have another one, so I guess I'm just gonna have to rebuild this one again.
on the bright side, I learned a few things during the previous re-build, so for the third time around, it oughta come out dang near perfect, even better then before.
Old Apr 16, 2012, 01:15 AM
Corky65 is offline
Find More Posts by Corky65
Gravity always wins . . .
Corky65's Avatar
USA, CA, Palmdale
Joined Dec 2010
That just breaks my heart to see a plane in that condition
Corky65 is offline Find More Posts by Corky65
Old Apr 16, 2012, 09:27 AM
Jovanx is offline
Joined Nov 2011
I ran into that situation once with a really fast dog. There were some kids who tried chasing the dog and calling it off but it was so determined. Then luckily it's master came out of a house and called him away with the voice of authority. If that ever happens again, and it's too fast to hand-catch, other options might be parking it on a roof or in a tree.
Old Apr 16, 2012, 10:27 AM
Joined Jan 2012
...or flying it out over a busy street, assuming it's not your dog.
Just kidding. Who would think of such a horrible thing...?
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13416 Yesterday 10:39 PM
Discussion Parkzone vs.BlitzRCWorks F4U Corsair (which one) wjohnson1186 Beginner Training Area (Aircraft-Electric) 21 Nov 05, 2012 01:55 PM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion Difference between Parkzone's different Ultra Micro planes? bunger Scratchbuilt Indoor and Micro Models 21 Jul 10, 2011 03:32 PM
New Product New Ultra Micro F4U Corsair BNF by ParkZone P-51C Micro Ready-to-Fly 3 Feb 23, 2011 10:27 AM
