Old Apr 10, 2012, 03:52 AM
DropTank is offline
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
United States, NC, Raleigh
Joined Jun 2008
My Corsair came yesterday but,there were no instructions. Where is the balance point?
DropTank is offline Find More Posts by DropTank
Old Apr 10, 2012, 07:39 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Put the battery all the way forward and the balance point should be farther forward than that.
For instruction, the Horizon Hobby website is the best resource:
Corsair manual ... page 10.
UNGN is offline Find More Posts by UNGN
Old Apr 10, 2012, 01:45 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Thanks UNGN. I cut a whole in the cowl and slid the battery as far forward as it would go. Seems to balance pretty good. I'll try it out as soon as the wind quits howling.
Old Apr 10, 2012, 03:32 PM
Wayne on Maui is offline
Find More Posts by Wayne on Maui
Wayne on Maui's Avatar
Joined Mar 2011
Your manual is under the foam ,take the foam out of the box should be taped to the bottom
Wayne on Maui is offline Find More Posts by Wayne on Maui
Old Apr 10, 2012, 06:17 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
I bought a used one from the classifieds. There was not a manual. I did check out the one online like UNGN said.
Old Apr 11, 2012, 04:10 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
The CG recommended in the manual is 28mm back from the leading edge. The manual is correct about the location and it flies well with the CG there. However the manual is wrong when it suggests you can achieve that CG by putting the stock battery in the front of the stock battery cavity.
Just do whatever you have to do to get the it to balance at that point, and it should fly like a dream. You can put dead weight on the nose temporarily, and then fiddle with battery location and size and then remove the weight.
Jovanx is offline Find More Posts by Jovanx
Old Apr 13, 2012, 03:02 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
I put two flights on my Corsair this morning. It flies great! It does take a good bit of right rudder on takeoff. Is that normal?
Old Apr 14, 2012, 12:05 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
DropTank,
Yes, that's normal behavior for a taildragger. There are a number of forces at work. Torque, gyroscopic precession, slipstream effects, and P-factor come into play. They all tend to make planes with clockwise props yaw to port during the takeoff roll. If you're not doing it already, try rolling into the throttle on takeoff. Once the tail is up, smoothly go to full throttle, ease back on the stick, and lift-off. That should minimize the yawing tendency.
Joel
turboparker is online now Find More Posts by turboparker
Old Apr 14, 2012, 05:08 AM
megadaz is offline
Find More Posts by megadaz
United Kingdom
Joined Mar 2012
Hey people heres a vid of my corsair,its a bit beaten up but it taught me loads.I now fly a umx beast and a parkzone spitfire.All thanks to the help of this little warhorse
My UMX Corsair F4u (7 min 17 sec)
megadaz is offline Find More Posts by megadaz
Old Apr 14, 2012, 10:30 AM
MayorThis is offline
Find More Posts by MayorThis
MayorThis's Avatar
Joined Apr 2012
Couldn't agree more. I wish I had bought this micro before I bought a couple of full sized warbirds. Way cheaper way to learn how to fly!!
MayorThis is offline Find More Posts by MayorThis
Old Apr 14, 2012, 04:48 PM
seitz2c is offline
Find More Posts by seitz2c
P. Seitz
United States, IA, Mechanicsville
Joined Jan 2006
I have a love hate thing going with the corsair ! I bought a slightly crashed one on Ebay .My intention was to rip out it's guts for a P-39 I'm building.
I took it to the Sunday afternoon indoor fly in It flew so well that I just coudn't cut it up. It was extremely tail heavy I added the dime and 7 lead shot to hit the CG.the stock prop has plenty of power to fly indoors. it was a little fast for the gym. I then dropped in 30 degrees of flaps . Just what to docter orderd. with the extra drag it slowed down . I added 10% down ele trim to keep the nose down .I'm useing a DX6i transmitter.
The Hate! there were 3 other Corsairs there they ALL looked the same. But it flies so well I decided to repair the crash damage and repaint. I decided on the AU-1 1956 version . Yes I know that all the AU-1 went to the Marines. BUT I have a photo of 4 AU-1s setting on the ramp with NAVY painted on the aft fuse.
Paul
seitz2c is offline Find More Posts by seitz2c
Old Apr 14, 2012, 08:32 PM
Jovanx is offline
Joined Nov 2011
I always stand up and take notice when I see a Corsair that is not blue. Do you have the flaps mechanically dialed in, or are you using a flapperon setting on the tx?
Old Apr 14, 2012, 09:11 PM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Wow, Jovanx!!! I am kinda eperienced. Thought I had done almost all ya could. If I have not done it, I have read of others doing it. But, you mention something that I have never even considered. Mechanically dialing in flaps!!! Never even thought about that. Thanks so much. Just goes to show me how great these forums are. More brains the better. I can see the disavantages of doing it that way. But, I can also see the advantages too.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Apr 14, 2012, 09:50 PM
Joined Jul 2009
Lee,
The reason you have not heard about permanent flaperons is because they decrease the maneuverability of the plane. Axial rolls, KE passes, vertical climbs, and inverted flight will suffer greatly, or be next to impossible. They also cause throttle/pitch coupling, and increase the tendency for tip-stalls.
Joel
Old Apr 14, 2012, 09:57 PM
Winder Ga
Joined Sep 2008
Yea, I agree Joel. That is part of the disavatages I was thinking of. Flight envelope would dwindle. But, some planes can't do much of that anyway. I was just thinking that some planes could benefit from permanent flaps in my yard. hahaha. Slow and low, relaxing flights every now and again are kinda nice.
Lee
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13298 Dec 08, 2015 12:08 PM
Discussion Parkzone vs.BlitzRCWorks F4U Corsair (which one) wjohnson1186 Beginner Training Area (Aircraft-Electric) 21 Nov 05, 2012 02:55 PM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 09:11 PM
Discussion Difference between Parkzone's different Ultra Micro planes? bunger Scratchbuilt Indoor and Micro Models 21 Jul 10, 2011 04:32 PM
New Product New Ultra Micro F4U Corsair BNF by ParkZone P-51C Micro Ready-to-Fly 3 Feb 23, 2011 11:27 AM
