Old Feb 21, 2012, 10:02 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Brushless UM Corsair
Here is a picture of the interior of my UM Corsair after the brushless 2S mod. One battery goes in the original spot and another under the top half of the fuselage wired for 7.4v. It will fly slow, lands as well as original and if I want WOT makes for some very fun flying. AUW (with two 1S Hyperion 240 batteries) is 62g. I fly her inside a double gym and outside and it is a blast. Everything fits, you just have to be sure nothing is binding the servos or control rods.
Allan
swimmer is offline Find More Posts by swimmer
Old Feb 22, 2012, 12:56 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I like that! I've got an EFlite 180BL motor that came out of the SBach, (8 grams with adaptor but not prop). I also picked up an EFlite 5 amp esc to go with it (7 grams). Is that motor you are using similar in size? That esc looks quite a bit bigger than mine.
Jovanx is offline Find More Posts by Jovanx
Old Feb 22, 2012, 05:01 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Motor is a HobbyKing AP05 and ESC is a Thunderbird 6.
http://hobbyking.com/hobbyking/store...idProduct=9662
So what do you think your total weight will be after the mod?
Old Feb 23, 2012, 12:17 AM
rclayton is offline
Find More Posts by rclayton
rclayton's Avatar
Mooresville, IN
Joined Mar 2009
Does anyone know how to reprogram the board so that you can use the aileron servos independently and program flaps?
rclayton is offline Find More Posts by rclayton
Old Feb 23, 2012, 12:34 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
I don't remember how to do it, but the procedure is in the brick manual, which is available on Spektrum's website.
BTW - the last thing you want on this plane is flaperons. Spoilerons maybe, but definitely not flaperons. Deploying flaperons will decrease the critical AoA & increase the tendency for tip-stalls, which decreases low-speed maneuverability. Pretty much the opposite of what you want. Spoilerons actually help low-speed maneuverability because they decrease the tendency for tip-stalls and increase the critical AoA.
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 23, 2012, 01:00 PM
Jovanx is offline
Joined Nov 2011
Assuming one gram for a balsa motor mount, It would gain 3 grams on the motor and mount, and then another 7 for the esc. It would be possible to drop a little weight by cutting the wires shorter and using solder joints instead of connectors. After that it is all up to the battery. If you use 2 separate batteries, do you still need the diode to step the voltage down for the receiver, or does it run off just one of them?
Old Feb 23, 2012, 03:37 PM
msdumo is offline
Find More Posts by msdumo
Canada, ON, Calabogie
Joined May 2011
The brick gets it's voltage from the onboard BEC on the ESC. The diode with a .7 volt drop is used to reduce the 5.0 volt BEC voltage to 4.3 volts. The brick would not handle 5 volts.
You could leave the diode out and use one of the batteries that are in series to power the brick by attaching a connector between the two series batteries. The current draw would be greater in this battery. Go with the diode. It's simpler and more predictable.
My 2S brushless T28 went from 41 grams to 58 with the extra battery, esc and motor weight.
msdumo is offline Find More Posts by msdumo
Old Feb 23, 2012, 04:41 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Use the diode. It is cheap and a very simple installation.
Old Feb 23, 2012, 08:07 PM
Jovanx is offline
Joined Nov 2011
I was hoping to weasel out of the diode thing because there is no place in town that sells electronic components. I do actually have a few that I could scrounge off some scrap circuit boards but I don't know how to test them to see if they are the right size. Guess I'll have to order one from somewhere. Couldn't you use a resistor instead?
Today a crust formed on the snow that is about the consistency of rough pavement. I tried a bunch of landings with the Corsair and most of them ended up with nose-overs. I made a set of quick and dirty wheels out of EPP foam 1-1/4" in diameter and they work great! They look big but not ridiculously so, and they completely solved the nose-over problem. I ran 2 batteries through, and must have done at least 30 landings and it remained upright on all of them.
Old Feb 23, 2012, 09:48 PM
msdumo is offline
Joined May 2011
Almost any diode will work. Use a multimeter on the ohms scale. It should have a very small resistance in one direction and a very large resistance in the other direction. If resistances are both large or both small it's no good, either shorted or open circuit.
Old Feb 27, 2012, 07:07 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Swimmer, nice to see you have the crack in the wing in the EXACT same place mine broke (and broke again about 4 more times). Finally learned to fly this bird and stopped crashing. Had a great flight today in variable winds probably 3-7 gusting to 12. Just using the "dime mod" and Hyperion 160s. Flew for about 7 minutes and then set her down before hitting LVC. Still using the stock prop and I've probably gained a few grams in glue and tape. Still with the 160 I get acceptable climb and performance, its just no speed demon but that's fine for me because it is my first aileron micro plane. Most of my crashes (and probably another one) were caused by over controlling the roll pulling out of a dive. I did move the aileron control rods to the second to bottom hole to get a better roll rate. Before it was so slow I couldn't pull out of bad situations. Now I just have to be lighter on the sticks. All I have is the stock RTF radio bear in mind.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Mar 01, 2012, 08:08 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Yep, my Corsair had been pristine after many flights up until I decided to fly it in the wind. Any wind, in my opinion and experience, throws these micros around where it is much work just to keep them in the air. Landing your Corsiar must have been difficult with winds gusting to 12 mph.
Old Mar 02, 2012, 12:14 PM
megadaz is offline
Find More Posts by megadaz
United Kingdom
Joined Mar 2012
Hi all I'v just brought my first rc plane and its the corsair F4U,iv been flying micro helis but there're way to fragile and theres only so much i can do unless i go fully 3d which is way to pricey especially if it breaks.
I must say its a great plane,used my batteries from my heli and iv only had a few minor knocks,nothing a bit of sticky tape wont hold together. I did notice that its very tail heavy so next session out and I'll tape a coin to the front as lots of people have mentioned.
Must admit I'm not not missing my heli and will be saving up for a parkzone Spitfire next.
megadaz is offline Find More Posts by megadaz
Old Mar 02, 2012, 01:06 PM
Jovanx is offline
Joined Nov 2011
Hey megadaz, the suggested CG of 28mm behind leading edge is right on but it needs either a bigger battery or weight up front to get it there. If you just do what you have to do to get it to balance at that location, your next flight will be a breeze (as long as it isn't windy).
Old Mar 03, 2012, 03:32 PM
Well I decided to try the P-51 prop
I can't seem to remove the 3 blade prop from the motor? How did you guys do it? I started pulling really hard on the front, and was afraid I'd pull the little motor right out of the plane if I pulled any harder on the prop. Do you have to remove the motor first to change props?
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13298 Dec 08, 2015 12:08 PM
Discussion Parkzone vs.BlitzRCWorks F4U Corsair (which one) wjohnson1186 Beginner Training Area (Aircraft-Electric) 21 Nov 05, 2012 02:55 PM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 09:11 PM
Discussion Difference between Parkzone's different Ultra Micro planes? bunger Scratchbuilt Indoor and Micro Models 21 Jul 10, 2011 04:32 PM
New Product New Ultra Micro F4U Corsair BNF by ParkZone P-51C Micro Ready-to-Fly 3 Feb 23, 2011 11:27 AM
