Canada, BC, Smithers
Joined Nov 2011
The Corsair is such a sweet little plane that it would probably be worth the effort of putting a brushless motor in. More power, longer lasting, and it would probably solve the tail-heavy issue as well. I have also noticed that the stock motor is the same size as the one in the MSR and also the tail motor in the 120 SR. Those 2 motors seem to go on forever. Might be worth trying one of them instead of the iffy UM motors. |
The mSR uses the same motor as the XP/F4U,Pole Cat, etc., but with a different pinion. Therefore, it will not last any longer in the F4U. It's the application that determines the longevity of these cheap 'pager motors'. We have seen up to 20% variability in thrust between samples, and longevity is all over the map. Some motors last for hundreds of flights, while others fail before the plane even gets airborne for the first time. Most fall somewhere between. Remember, the manufacturer never intended these motors to be used as powerplants. Rather, they were designed for low-stress, intermittent use - such as vibrating pagers & cellphones, and operating optical disc drawers, carousels, and the like.
The Nine Eagles Solo Pro motor is currently the best option for a longer-lasting, direct-fit brushed motor with similar power to the stock setup. It has the same power as one of the stronger F4U motors. The Nine Eagles Bravo XP motor provides a 30% increase in thrust over the stock motor when both are running 5043 props & top-quality batteries, and also tends to outlast the orginals. Of course, top-quality batteries are mandatory with this setup. The Nine Eagles motors have the same external dimensions as the original, so it's an easy swap. Just put the PZ pinion on the new motor, swap the motor connector, and you're all set. See the SP/SX motor swap thread for details: http://www.rcgroups.com/forums/showthread.php?t=1326158 Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Nov 2011
Thanks for the info. Now that I look closer, I can see that the pinion on the UM motor has 9 teeth and the one on the MSR has 8. Of course, it is also driving a larger secondary gear. I was just hoping since one was PZ and the other was Blade, there might be a difference in where they sourced their motors.
Joined Nov 2011
Hey, Joel, I was just wondering... instead of the extra weight of an esc and a 2s battery and a brushless motor, what if you used a larger brushed motor, like the one in the MCPx? Do you think the esc on the board could handle that (or some other slightly larger motor)?
If you're not comfortable with doing the pinion & connector swap, RCBabbel sells plug & play Bravo SX motors & SP motors. Joel |
Hey guys, new to the thread but not new to the UM series or the hobby. Finally picked up the Corsair (and Mrs. Claus got me the full size for Xmas, which is still looking at me in the box crying to be let out!!!) & thought I'd take a peak at the forum. I've skimmed over some pages in the beginning & end. Looks like the "Dime Mod" works out well!! Any other mods/adjustments I may want to look into before her maiden flight. Looking to keep her stock as far as motor & props goes. Thanks in advance!! Coconut
Welcome Coconut. The dime mod may or maynot be neccesary. You have to check your planes COG (center of gravity). The stock prop? I can tell ya right up front, change it for the mustang prop. Save the stock one for looks on the shelf. It does not provide enough thrust. Happy Flyin. Lee
Regarding receive antenna replacement....
The most important things are that the replacement antenna wire is the same length & diameter as the original, and that it uses the same type of insulation. Antennas are typically tuned for resonance at the frequency of operation. Antenna length determines the resonant frequency. Shorter = higher frequency, while longer = lower frequency. The length-to-diameter ratio determines antenna bandwidth (range of frequencies over which the antenna will efficiently operate). Fatter = wider bandwidth, skinnier = narrower bandwidth. Length-to-diameter ratio also has a lesser effect on resonant frequency. A fatter antenna needs to be a bit shorter than a skinny antenna. The type of insulation (or lack thereof) also affects the resonant frequency. An insulated antenna needs to be a bit shorter than an antenna made from bare wire. An improperly-tuned receive antenna will always perform far worse than a properly-tuned antenna. Incidentally - an improperly-tuned transmit antenna will not only perform poorly - it will usually destroy the transmitter's power amplifier. Never attempt to repair or modify a transmit antenna - unless you have an in-depth understanding of antenna theory & RF, and have access to proper RF test equipment that is designed to be used at the transmit frequency. Joel |
| Thread Tools | |
| Discussion Blade MCP X - owner's thread | rchelijc | Micro Helis | 11994 | Today 07:37 PM |
| Discussion Parkzone vs.BlitzRCWorks F4U Corsair (which one) | wjohnson1186 | Beginner Training Area (Aircraft-Electric) | 21 | Nov 05, 2012 01:55 PM |
| Discussion Parkzone f4u corsair VS Airfield f4u corsair | Hoopsta17_99 | Electric Warbirds | 54 | Mar 16, 2012 08:11 PM |
| Discussion Difference between Parkzone's different Ultra Micro planes? | bunger | Indoor and Micro Models | 21 | Jul 10, 2011 03:32 PM |
| New Product New Ultra Micro F4U Corsair BNF by ParkZone | P-51C | Micro RTF | 3 | Feb 23, 2011 10:27 AM |
