Old Jul 15, 2011, 10:33 AM
Mespert is offline
Find More Posts by Mespert
Mespert's Avatar
Canada, QC, Saint-Hubert
Joined May 2011
Huffdaddy, if you haven't done it already, try a 5043 prop. Will change the plane.
Mespert is offline Find More Posts by Mespert
Old Jul 15, 2011, 05:22 PM
thejanitor86 is offline
Find More Posts by thejanitor86
thejanitor86's Avatar
United States, FL, St Augustine
Joined Jun 2011
yeah the 5043 makes it fly like a whole new plane.
thejanitor86 is offline Find More Posts by thejanitor86
Old Jul 15, 2011, 05:38 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
How is it with the UM T-28 prop compared to stock 3 blade?
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jul 15, 2011, 05:47 PM
HuffDaddy is offline
Find More Posts by HuffDaddy
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
that's what I'm hearing... by chance do you (or anyone else) have a pic of the 5043 mounted on the UM Corsair they could post for me?
HuffDaddy is offline Find More Posts by HuffDaddy
Old Jul 15, 2011, 08:44 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
HuffDaddy,
Here's a couple pictures of my Corsair with GWS 5043 painted prop and GWS prop adapter. I hate orange props. The tape is on there to hold a piece of clay when locating the CG. As you can see the clay located in this area is well forward of the stock battery slot. I opened the slot so Hyperion 240's 1S would fit. The battery all the way forward in the modified stock slot tucked up against the cowling corrected the CG to 27mm. My Corsair flies great and the Hyperion 240 1S is a very nice battery for the Corsair.
Allan
swimmer is offline Find More Posts by swimmer
Old Jul 15, 2011, 08:47 PM
Mespert is offline
Mespert's Avatar
Joined May 2011
There you go, do you need to see how it looks or how to mount it ?
Old Jul 15, 2011, 08:51 PM
Mespert is offline
Mespert's Avatar
Joined May 2011
Guess I got beaten to it
Just came back from flying it again and it is as fun and easy as the T-28 now, but it flies better inverted. It rolls not as good tough.
Swimmer, where did you get the spinner ?
Old Jul 15, 2011, 09:50 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
GW/SPN001- This has multiple prop adapters. Two are 1.5mm for the Corsair. I got mine at HobbyTown.
Allan
Old Jul 15, 2011, 10:14 PM
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
Allan & Mespert... excellent, thanks for the pics
Mespert, so now that ya mentioned it, is there a special mounting process or adapter needed? I just assumed that it screwed on in place of the stock 3 blader...no?
Originally Posted by swimmer View Post
HuffDaddy,
Here's a couple pictures of my Corsair with GWS 5043 painted prop and GWS prop adapter. ....
Allan
Old Jul 15, 2011, 11:08 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Answer: Yes. The GWS 1.5mm prop adapter screws on like the original three blade prop.
My next mod is installing a Bravo SX motor.
Allan
Old Jul 15, 2011, 11:19 PM
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
ok... so a guy needs the prop + the adapter... and the adapter screws onto the prop shaft and then ya screw on the prop to that?
are these the adapters?
http://www.microflight.com/Online-Ca...dapter-Set-4mm
Allan
Old Jul 16, 2011, 12:56 AM
Afraidtoregister is offline
Find More Posts by Afraidtoregister
Looking4Grass in AZ
Afraidtoregister's Avatar
United States, AZ, Mesa
Joined Feb 2011
Moved way in on control horns. It flies! The rolls are a lot less ugly now.
But it flies.
Afraidtoregister is offline Find More Posts by Afraidtoregister
Last edited by Afraidtoregister; Jul 16, 2011 at 04:20 AM. Reason: changed "loops" to "rolls" as I meant to say
Old Jul 16, 2011, 07:09 AM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
This kit GWSPN001 has the spinner attached to the adapter. The one you show will work but you won't have a spinner.
Allan
Old Jul 16, 2011, 08:43 AM
Joined Jun 2011
and only two out of the six in that set of adapters will work. but its cheap enough still. here is a link to the prop adapters TurboParker recommended.
http://www.rcgroups.com/forums/showthread.php?t=1361812
Old Jul 16, 2011, 10:16 AM
ho50ca is offline
Find More Posts by ho50ca
Joined Nov 2004
But it flies.
Watch going all the way in on linear servos set to 100%. You can get a lockup which isn't fun. Don't push linears beyond 95% if you're on the inner hole. I use 90%.
ho50ca is offline Find More Posts by ho50ca
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13393 Yesterday 11:29 PM
Discussion Parkzone vs.BlitzRCWorks F4U Corsair (which one) wjohnson1186 Beginner Training Area (Aircraft-Electric) 21 Nov 05, 2012 01:55 PM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion Difference between Parkzone's different Ultra Micro planes? bunger Scratchbuilt Indoor and Micro Models 21 Jul 10, 2011 03:32 PM
New Product New Ultra Micro F4U Corsair BNF by ParkZone P-51C Micro Ready-to-Fly 3 Feb 23, 2011 10:27 AM
