Old Apr 30, 2011, 01:56 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
can you use a single esc to run 2 motors?
lets say you have 2 10A brushless motors and a 20A ESC. can you use the single ESC to run both motors?
captaingeek is offline Find More Posts by captaingeek
Old Apr 30, 2011, 02:23 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Sometimes it works, sometimes it doesn't.
I would use a 30a ESC in the experment.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Apr 30, 2011, 02:57 PM
cmulder is online now
Find More Posts by cmulder
Ireland
Joined Apr 2001
No problem with dc (brushed) motors but ac/3 phase (brushless) might not start up if not exactly the same.
So if you want to try you must use 2 exactly the same motors and props.
The reason is that the coil that will be powered by the esc is "decided" after measuring the location of the magnets.
It can only do that for one motor so if the other "gets behind" when turning (and when starting) the wrong coil in that motor will be powered and then the motor will shake back and forth but not rotate.
cmulder is online now Find More Posts by cmulder
Old Apr 30, 2011, 04:00 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
I've done it, sometimes it works no problem and others you have to play with the throttle a couple of times to get the motors to sync/start up together. Once your flying they go no problem.
Martin Y is online now Find More Posts by Martin Y
Old Apr 30, 2011, 04:50 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Seems to work well with 2&4 poles inrunners(tried it with two Medusa in DF)
coriolan is online now Find More Posts by coriolan
Discussion Can you run 2 brushless motors from 1 ESC??? SGTalon Power Systems 1 Jun 30, 2006 09:20 AM
Can I use a 2 cell brushless ESC with a single cell micro joule system? Matthew Cotten Scratchbuilt Indoor and Micro Models 2 Jul 05, 2005 09:19 AM
can you run 2 motors on one speed controler jswjimmy Power Systems 8 Nov 22, 2004 04:52 PM
can you run 2 brushless motors off of one esc? jeff262 Power Systems 4 May 30, 2004 11:39 PM
Can you run 2 brushless motors off of one ESC nikolaus_c Power Systems 1 Jul 05, 2003 11:44 AM
