This thread is privately moderated by Repairman6, who may elect to delete unwanted replies.
Old Sep 15, 2003, 01:54 AM
drksyd is offline
Find More Posts by drksyd
Trader Rating: 48
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Trader Rating: 48
Read the first post.
drksyd is offline Find More Posts by drksyd
Old Sep 15, 2003, 03:09 AM
ScotY is offline
Find More Posts by ScotY
Trader Rating: 12
ScotY's Avatar
Joined Feb 2001
Trader Rating: 12
How do you run these things in parallel? 26 amps would be perfect for my needs. $22 each shipped to Hawaii?
ScotY is offline Find More Posts by ScotY
Old Sep 15, 2003, 03:20 AM
drksyd is offline
Trader Rating: 48
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Trader Rating: 48
Yep, really thought about getting another one to just leave at work but these things are pretty small and not a problem to carry around.
Would you be Scot with the electric Raptor?
Old Sep 15, 2003, 03:34 AM
ScotY is offline
Trader Rating: 12
ScotY's Avatar
Joined Feb 2001
Trader Rating: 12
Yes, that's me. I don't think I know you, or do I?
Old Sep 15, 2003, 04:52 AM
drksyd is offline
Trader Rating: 48
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Trader Rating: 48
I see you at the marsh, I fly the little mini wing. That's all I have that I can fly there for now. I was cruising with Phil them yesterday.
Old Sep 19, 2003, 01:32 AM
erashby is offline
Find More Posts by erashby
Trader Rating: 3
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Trader Rating: 3
Fixed up the Power supply
I added a cover to the electrical connections, a lighted toggle on/off switch, two deans female plugs(so I can plug two chargers into the PS), a cooling fan with its own toggle on/ off switch.
Here are some pictures.
(edited: It doesn't show here in the pictures but I hooked the fan up to the VS outputs.)
erashby is offline Find More Posts by erashby
Old Sep 20, 2003, 09:24 AM
jimmyray is offline
Find More Posts by jimmyray
Trader Rating: 38
jimmyray's Avatar
Oxford, Alabama USA
Joined May 2001
Trader Rating: 38
How!?!
How I hooked it up - your result may vary, but hopefully not!
jimmyray is offline Find More Posts by jimmyray
Old Sep 20, 2003, 09:25 AM
jimmyray is offline
Trader Rating: 38
jimmyray's Avatar
Oxford, Alabama USA
Joined May 2001
Trader Rating: 38
Pic without the notes
Old Sep 20, 2003, 11:05 AM
papanurg is offline
Find More Posts by papanurg
Trader Rating: 0
Toledo
Joined May 2003
Trader Rating: 0
Power supply problem
I bought one of these about a month back and it was working fine until I tried to charge a 3s LiPo pack with a Triton. I kept getting an error message that the Batt volt was too low. I moved the Triton to my car battery and it worked fine so I decided it must be the output from the power supply that was too low, so I used the little white plastic screw-adjuster, on the left side of the above picture, to up the output. As soon as I did this the power LED went out and the power supply stopped working entirely. I opened it up and the only fuse I found was intact. I adjusted the screw back to its original position and I am still getting nothing.
Does anyone have an idea of what is up with this power supply?
papanurg is offline Find More Posts by papanurg
Old Sep 20, 2003, 11:11 AM
erashby is offline
Trader Rating: 3
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Trader Rating: 3
No idea what is wrong. You just need to trouble shoot it. But I would contact the vendor and see if he will give you a discount on another one. Instead of $19.99 including shipping I think that 1/2 price would be reasonable-$10. If I were the vendor that is what I would do, so people here on r/c groups would feel confident in buying the Power Supply, after all they are all surplus and used.
Old Sep 20, 2003, 01:21 PM
ArcherAce is offline
Find More Posts by ArcherAce
Trader Rating: 48
GRAVITY... Just Say NO!
ArcherAce's Avatar
Toledo, OH
Joined Apr 2002
Trader Rating: 48
I'd email the vendor, papa. They have been doing a brisk business here on ezone with these powersupplies. I'm sure they'd be willing to work with you to make it right.
Let us know how it turns out.
ArcherAce is offline Find More Posts by ArcherAce
Old Sep 20, 2003, 08:04 PM
papanurg is offline
Trader Rating: 0
Toledo
Joined May 2003
Trader Rating: 0
Works again
I'm not an electrician so I don't have an explanation, but it works again.
I let it sit for a couple of hours, set the output screw close to its original position and plugged it back in...things I tried before posting without success...and low and behold it worked again. I don't know if the unit stores an amount of energy and needed to dissipate it before it worked again or what. Anyway the power unit is plugged in and charging up my 3s LiPo as I write this.
Old Sep 21, 2003, 01:49 AM
weflyon is offline
Find More Posts by weflyon
Trader Rating: 7
Woodland, CA , USA
Joined Sep 2001
Trader Rating: 7
Earlier is this thread someone mentioned that the unit will go up to about 15v and then cut out. Also, I remember something about having to fake out my Astro 110 deluxe to get it to charge a NMh battery that is getting the "low battery voltage" message. Glad it's all working again though.
Here's a thought. If you started to charge the Lipo's to soon after discharge could they not have had a chance to equalize pack-to-pack when load was released? I seem to remember reading something about Lipo packs needing to be within a certain voltage range one to the other to function effectively. I am still standing on the sidelines having yet to take the LiPo plunge so I have no direct experience with them.
Good Luck, Steve.
weflyon is offline Find More Posts by weflyon
Sold Power Supply 12 volt 19 Amp **NEW** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 10 Mar 03, 2007 11:52 AM
Sold Power Supply 12 volt 19 Amp *NEW* Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 23, 2007 04:23 PM
Sold Power Supply 12 volt 19 Amp **NEW** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 6 Dec 27, 2006 04:24 PM
Sold Power Supply 12 volt 19 Amp For Charger Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 11, 2006 05:22 PM
PC Power Supply 12 Volt Maximum Mod ?? KillerWatt DIY Electronics 4 May 08, 2004 01:23 PM
