This thread is privately moderated by Repairman6, who may elect to delete unwanted replies.
Old Sep 01, 2003, 02:52 AM
voodoosoup is offline
Find More Posts by voodoosoup
Trader Rating: 0
Farfromloopin'
USA, IN, Fort Wayne
Joined Jun 2002
Trader Rating: 0
270-1809 Is the part number - And it just barely fits in lengthwise.
It is plastic but it comes with a plastic and metal screw down cover.
voodoosoup is offline Find More Posts by voodoosoup
Old Sep 01, 2003, 11:13 AM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
Trader Rating: 0
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Trader Rating: 0
In the initial post, there's a picture in the bottom left corner, showing a pot on the end of the supply, labelled "Voltage Adjust".
What is the adjustable output range of the supply?
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Sep 01, 2003, 11:38 AM
-Draken- is offline
Find More Posts by -Draken-
Trader Rating: 0
Arrow Nut
-Draken-'s Avatar
Chilliwack, Canada
Joined Apr 2001
Trader Rating: 0
I played with this, the range was about 9.5v - 15v. It will go higher than 15 volts but the PS shuts itself off beyond 15v.
-Draken- is offline Find More Posts by -Draken-
Old Sep 01, 2003, 12:37 PM
Trader Rating: 0
St. Louis Metro
Joined Apr 2003
Trader Rating: 0
Bummer, I need one to go down to 7.2V
Old Sep 01, 2003, 08:09 PM
drksyd is offline
Find More Posts by drksyd
Trader Rating: 48
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Trader Rating: 48
Is shipping free to Hawaii too?
drksyd is offline Find More Posts by drksyd
Old Sep 02, 2003, 07:38 PM
Repairman6 is offline
Find More Posts by Repairman6
Trader Rating: 0
Joined Aug 2003
Trader Rating: 0
Sorry lower 48 only, Add $3 for Hawaii
Tnx
Glenn
Repairman6 is offline Find More Posts by Repairman6
Old Sep 02, 2003, 07:48 PM
Trader Rating: 0
Joined Aug 2003
Trader Rating: 0
Hi Greg,
The ebay Auction is 17.99 Plus $10 S&H.
We offer Our wholesale Prices to You.
We appreciate your business
Tnx
Glenn
Old Sep 04, 2003, 12:37 AM
drksyd is offline
Trader Rating: 48
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Trader Rating: 48
Cool, will send email now.
Old Sep 05, 2003, 10:45 PM
dadspet is offline
Find More Posts by dadspet
Trader Rating: 0
dadspet's Avatar
Endicott, NY
Joined Sep 2001
Trader Rating: 0
a few questions on supply connections
Would some one please be a little more specific on the connections for these supplies.
1. For the AC, does it matter which of the 2 AC wires from the AC power plug go to AC(L) or ACin?
2. Why are there two +V and two -V terminals. I assume I use one +v and one -1 for my charger. Are there two independent DC outputs each of which I can connect a charger to?
3.I guess the S terminals never need to be used. Is that correct?
4.Is a cooling fan needed.
dadspet is offline Find More Posts by dadspet
Old Sep 06, 2003, 03:23 AM
erashby is offline
Find More Posts by erashby
Trader Rating: 3
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Trader Rating: 3
Re: a few questions on supply connections
No, but make sure you use a grounding cord/plug.
No, but as long as you are under the maximum amps, you can connect several chargers (at the same voltage usually 13.8) to the same terminals.
Correct for our use for R/C hobbies.
Not generally, but it depends how many amps you will be pulling from the unit. I so far have only pulled 5 amps max. If you hook two chargers up, I would sugget monitoring the power supply to see how hot it gets. Adding a 12 volt dc or a 120 volt AC computer fan wwould be easy.
erashby is offline Find More Posts by erashby
Old Sep 06, 2003, 08:30 AM
rktung is offline
Find More Posts by rktung
Trader Rating: 2
Glencoe, IL USA
Joined Jan 2001
Trader Rating: 2
on/off switch?
hi,
is there an on/off switch or button on the unit? didn't see one.....thanks
rktung is offline Find More Posts by rktung
Old Sep 06, 2003, 09:14 AM
Lucas in Alaska is offline
Find More Posts by Lucas in Alaska
Trader Rating: 5
Sitka, Alaska
Joined Mar 2001
Trader Rating: 5
I got mine this week and it works great. I'm using a Supernova charger and the charger gets warmer than the power supply.
I also talked to Sue at Ramboy and she said she's going to get their tech person to type up a short post on how to hook these up, which will be nice for the beginner.
Lucas
Not associated with Ramboy in any way except the power supply.
Lucas in Alaska is offline Find More Posts by Lucas in Alaska
Old Sep 06, 2003, 12:00 PM
erashby is offline
Trader Rating: 3
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Trader Rating: 3
Re: on/off switch?
Originally posted by rktung
hi,
No switch, no power cord. This is definitely a DIY power supply. But it is easy to DIY. Just get a grounded power cord. Stip the insultion of of the end of the wires for about 3/8". Then screw the correct wires to the power in connector screws. If you want a switch you could add an "in-cord" switch or a toggle switch.
I got a small project box and a lighted 120Volt toggle switch from Radioshack. As soon as I have some time I am going to use the project box to cover the contacts on the end of the power supply and mount the on off toggle switch and possibly a 120 volt AC or 12 volt DC fan on the side grating of the power supply. I'll take pictures and post it here with part numbers.
Old Sep 07, 2003, 09:33 PM
wildbill95823 is offline
Find More Posts by wildbill95823
Trader Rating: 49
NON PayPal Member
Sacramento Metro, California, United States
Joined Nov 2001
Trader Rating: 49
Power Supply
Hi,will take 10 of them!Will PayPal funds.
Bill
wildbill95823 is offline Find More Posts by wildbill95823
Old Sep 08, 2003, 06:41 AM
Frank Hurd is offline
Find More Posts by Frank Hurd
Trader Rating: 60
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Trader Rating: 60
Got Mine
Received my PS Saturday. Just happened to still have my old micro wave that I replaced and used the cord from it on the PS. Worked like a champ! What a bargain!
Our field has electrical hookups- no more heavy batteries at the field!
Frank Hurd is offline Find More Posts by Frank Hurd
Sold Power Supply 12 volt 19 Amp **NEW** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 10 Mar 03, 2007 11:52 AM
Sold Power Supply 12 volt 19 Amp *NEW* Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 23, 2007 04:23 PM
Sold Power Supply 12 volt 19 Amp **NEW** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 6 Dec 27, 2006 04:24 PM
Sold Power Supply 12 volt 19 Amp For Charger Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 11, 2006 05:22 PM
PC Power Supply 12 Volt Maximum Mod ?? KillerWatt DIY Electronics 4 May 08, 2004 01:23 PM
