This jet is a copy or rebranding of another F-104 foamy http://www.snhobbies.com/product_inf...ada9d780f51ce2
I have flown that one, which flew fairly well. I wouldn't fly it off of a dirt road, the short wings don't give any roll stability on takeoff and it'll bounce itself off the side (I had no joy off of a grass field). Landings aren't as bad as they might seem - the intakes and fuselage make up a large-ish lifting surface. I was able to hand launch it, although I would recommend making a bungee launch setup for this jet. The problem I had with this model was an off balance rotor, which "stalled" in flight. This normally wouldn't be an issue, except that when the rotor stopped, the momentum flipped the jet over and I lost orientation and crashed. Fun flier, but a challenge in the sense that it's tough to track in the sky. |
Latest blog entry: Turnigy dlux 80A HV: Soft Start and...
I don't think I needed a lot of expo. The ailerons are very effective: although they don't extend very far, neither do the wings they have to roll.
You should be able to fit the rx into the fuselage near the battery by slipping it through the battery holder 'cage.'
| Thread Tools | |
| Question Hobby King 90mm EDF units and 100A ESCs, how good are they? | Concordefan | Electric Ducted Fan Jet Talk | 10 | Sep 20, 2011 08:13 AM |
| Wanted Hobby King 90-100A ESC and 3 HK 90mm EDF units | Concordefan | Aircraft - Electric - Jets (FS/W) | 1 | Apr 24, 2011 08:58 PM |
| For Sale Grayson Hobby/ Hobby King Speed controllers + Motor | Rooster433 | Aircraft - Electric - Power Systems (FS/W) | 6 | Mar 17, 2011 11:48 AM |
| Question Hobby King T45 64mm EDF CG and throws | 1satnaam | Foamy EDFs | 3 | Mar 14, 2011 09:18 PM |
| Discussion 70mm EDF w/ 3300kv Motor from Hobby King | mattyhawk | Electric Ducted Fan Jet Talk | 112 | Jul 14, 2010 04:18 PM |
