Apr 30, 2011, 08:11 AM
United States, TX, Tomball
Joined Mar 2011
Align Trex 600 Pro LE Nitro RC Helicopter *NEW*
T-REX 600 Nitro Limited Edition
Key Features
Bump resistance fiberglass painted canopy.
Canopy also features a rigid easy clip on/off design for fast installation and removal.
Simple and light weight design provides awesome flight performance nearly equal to larger helicopters while still maintaining very stable hovering and flight.
+/- 14 collective pitch is possible for extreme 3D performance.
Clutch, Fan and Bell assembly provide very smooth operation even at high RPM.
Forward mounted tail servo helps to keep exhaust oil from entering servo and also improves the CG.
Battery tray designed for easy and clean radio gear installation.
Fuel Tank Capacity 440cc for about 10 minutes 3D flying.
Main Gear Ratio 8.5:1, 1500-2200 Rotor RPM Heavy duty tail with thrust bearings.
95mm Tail Blades Highly efficient shaft driven tail design.
Rigid frame design that can handle hard crashes without damage.
Carbon Fiber frames, fins and boom supports.
Super engine cooling system features large diameter fan and very efficient airflow to provide unequaled cooling and horsepower.
Clutch/Start shaft feature a 10mm ID one way bearing to eliminate any bearing problems during starting and flight.
Needed to Complete
- Transmitter (7-channel or more)
- Pitch Gauge
- Engine Starter
- Engine Fuel
- Fuel Pump
This Helicopter is BRAND NEW and assembled.
Brand NEW O.S. Engine Max 50SX-H Hyper
Brand New Align 50 High Performance Muffler
Electronic's that are on heli:
1- Jr R921 2.4 Receiver
1- GP780 Head lock gyro
1- B6T 2 in 1 Voltage regulator (RX and Glow Plug Power)
1- RCE-G600 Governor
3- DS610 Standard servo
1- DS620 Specialized servo
No Fuel ever put into tank! NEW Authentic Align brand Heli.
*****NEW*****
Over $1525.00 invested
Will Sale for $1300.00
Type: Nitro Helicopter Kit
Main Rotor Diameter: 53.1 in (1350mm)
Tail Rotor Diameter: 9.45 in (240mm)
Gross Weight: 7.05 lb (3200g)
Length: 45.7 in (1160mm)
Kit/ARF/RTF: Kit Rotor Blade Length: 23.6 in (600mm)
NEW never used.
Everything on heli new.
Add fuel and a Bind & Fly radio.
I have better detail pics on request.
Cash or Paypal if you want to pay by credit card.
Pick up in Houston or might ship if you pick up shipping charges. I'll have to remove tail boom, if shipped. Has all paper work to put it back on.
