Old Apr 30, 2011, 05:45 AM
Joined Dec 2007
Rounding off the edges of EPP foam?
How do you guys round off the edges of your EPP foam? I'm trying different methods but I'm just making a mess.
RC-Archer is offline Find More Posts by RC-Archer
Old Apr 30, 2011, 06:10 AM
Space Coast
Space Coast
Joined Oct 2000
Belt sander or drywall sanding screen (looks like window screen - try first with a fine grit)
Seems that it likes to be "sanded" in one direction only, if sanded in the other direction it wants to grab and rip the foam. Use light strokes at first.
hoppy is offline Find More Posts by hoppy
Old Apr 30, 2011, 12:07 PM
Joined Jan 2009
For large radius rounding I use a small hot-wire bow. Then sand it as described above.
djacob7 is offline Find More Posts by djacob7
Old May 02, 2011, 11:45 PM
Joined Dec 2007
Thanks, I'll try them.
Old May 03, 2011, 01:13 AM
Livermore, CA
Joined Sep 2004
I use a bench-belt sander most of the time. A one direction sander also works.
If your on a budget, a drum type sandpaper roll does ok, but use finer snading grits so you don't dig in too much.
Butch777 is offline Find More Posts by Butch777
Old May 03, 2011, 02:41 PM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
First shave down the edges using 45 degree slices with a new sharp blade and then drag among 80 grit sand paper in one direction only, then remove the fuzzies with a trim iron or the side of a hot glue gun tip.
The tips, stab and fuse pod were all square, then rounded using this method.
goldguy is online now Find More Posts by goldguy
Question Epp & Depron foam, also Carbon fiber JonathanZ Foamies (Scratchbuilt) 6 Apr 29, 2011 07:23 PM
Question Epp & Depron foam, also Carbon fiber JonathanZ Hot Online Deals 1 Mar 18, 2011 12:11 PM
Discussion Rounding off a square wood fuse nose? flyboy320 Electric Sailplanes 9 Dec 10, 2009 05:37 AM
Discussion Rounding leading edges ??? uniquewon Foamies (Kits) 4 Feb 16, 2006 01:14 AM
