Old Apr 30, 2011, 06:26 AM
egall232 is offline
Find More Posts by egall232
England/uk
Joined Oct 2007
Build Log
YA Stingray
Hello,
After deciding 120 mm is not for me i did a bit of trading with Simon <edf crazy> and came home with a kit to build<remember we all used to do it that wayi had one many years ago with a homebuilt Wren turbine and is was a bit of a pig to fly as the auw was way too much for such a small airframe.Anyways this will have a Het 90mm fan and a Het 700 series motor on 10s 5000mah lipos and to finnish it off one of Tams nacelles.I did a search on the Stingray and although several people have talked about it not a lot is apparent when it comes to battery placement, how to mount the nacelle etc so i will just do my own thing.I will film the wings in profilm and may just buff the fuselarge as i want it nice and light.
If anyone can offer any advice or modifications please chip in,
cheers Euan.
egall232 is offline Find More Posts by egall232
Old Apr 30, 2011, 07:09 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Originally Posted by egall232 View Post
Hello,
cheers Euan.
Hello Euan
My friend is currently building the Stingray for the past 3 Days now.
He got the most done now.
He is using the following
XPS 120mm Nacelle
127mm Ramtec Fan
12S Setup
I can go an see him, what he thinks about the battery placement.
Regards
NS.
neversommer is offline Find More Posts by neversommer
Old Apr 30, 2011, 08:24 AM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Hi Euan
Steve here.I think I met you at last years nats. I am the Guy from Dublin.
I have one of these already built. I got it off the BMFA site. It is flown on 12s so if you want to know where the batteries are let me know.
Cheers
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Apr 30, 2011, 10:23 AM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Ns,
Thanks any more info will be great, i think a 120 mm set up is too much for the Stingray and may lead to problems like i had with my original turbine version<too much weight above the thrust line> but hey it may work ,Steve how you doing i remember chatting,photos of your nacelle and battery position will be a great help,also can i ask how much it weighs and how many watts you have?,
Do you think i could drop the cell count to 9 or 8 s ?
cheers Euan.
Old May 01, 2011, 02:33 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Hello,
After spending a few hours going over the build manual and sorting out the pre cut parts i have done a little bit of work,the wings have had the elevons cut out and te and le added.Rather than use epoxy i prefer to use a good quality white pva as i find it easier to sand and a lot less expensive,
tomorrow i hope to get the elevon servos mounts sorted.
I had a look at the rudder servo mounts and found it impossible to fit as per the manual? any ideas chaps? also the vertical fins locate in a neat tube clamp but still require an allen bolt fixing at the leading edge,apart from looking crap do a really need it ?
Tam can you give me an idea on how to mount your nacelle <keep off the green bottles and answer your e mails>
cheers Euan.
Old May 03, 2011, 03:48 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Hello,
i managed to get the spars fitted and glued together and went back to the rudder servo mounts,
day off tomorrow so will have a look at the nose gear mounts and speed brake,
cheers Euan.
Old May 09, 2011, 10:28 AM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Hello,
whilst waiting for my retracts to arrive i have finished off the wing and , hinged the elevons ,fitted the servo mounts,mounted the canopy and catches and sorted the air brake out I have a Tams nacelle waiting for my edf that should be about it before i prep and paint it,
all up weight so far is just under 4.5 lbs so my target is not too far off,
cheers Euan.
Old May 10, 2011, 05:19 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Well,
my retracts arrived and to my surprise HC sent air up spring down along with a set of sprung oleos < i ordered the less expensive ones> fitted with little hassle apart from the oleos that i had to cut down.For the nose leg i found a home made by me at school <30 yrs ago> trailing link that looks spot on
The speed brake is a very poor fit and will need fairing in with filler along with a magnet to hold it down,
maybe get around to some more building tomorrow?
cheers Euan.
Old May 12, 2011, 04:14 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Hello,
I managed to fit all the retracts along with the air tank, fill valve etc and to my delight it has held air four three hoursiam however very dissapointed with the Tamjets nacelle its full of voids in the glass work and the hatch is too small to fit it neatly:mad , still after a few hours filling and sanding will see it sorted,
cheers Euan.
Old May 12, 2011, 08:14 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks great ...too bad about the pin holes ,i tried priming in the mold with my Nacelle's ...but i always had voids,so i make my own gel coat (epoxy) and i have way less voids using that method,not perfect but very few pin holes.the seams require a small amount of filling and sanding .this is looking good ...very sleek looking airframe.
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 13, 2011, 12:34 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Roger,
perhaps Tam should get you to do his glass work,if i had actually paid cash for it <it was a trade> it would be on its way back to the US.
Still the weather at the moment is poor so i have plenty of time to sort it out,
cheers Euan.
Old May 15, 2011, 04:18 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Such a great kit!
I almost forgot this one but I still fancy this one on my wishlist
Too bad several great other projects are waiting on my bench first.
Subscribed!!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old May 16, 2011, 05:00 PM
juanjulian is online now
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Euan.
Nice build building mine at the samte time and posted my build at rcuniceverse.
Bought a already started kit and had to do a lot of extra work fixing wings since the ailevons were badly cut and build.
What fan and motor setup are you going to use?
Cheers,
Juan
juanjulian is online now Find More Posts by juanjulian
Old May 16, 2011, 05:22 PM
egall232 is offline
England/uk
Joined Oct 2007
ya Stingray
Jaun,
Hello i am using a het 6305 90mm fan and a het 1400 kv 39mm motor on 10s ,
Kit is very good quality apart from the speedbrake and should be under 10 lbs ready to go,
cheers Euan.
Old May 19, 2011, 07:39 AM
steveair3 is offline
Find More Posts by steveair3
Joined May 2007
Hi there
I tried to take a few photos with the I phone of the interior of my Stingray.
The Batteries are made up of 2 6S packs which are actually 2X 3s packs in series.If you look there are two boxes made up to take each battery pack.They start just inside the wheel cutout and go twords the front.
I hope this helps.
Photos are not great.
Cheers
Steve
steveair3 is offline Find More Posts by steveair3
Careful! Here ya GO, ET!! FL Knifemaker Life, The Universe, and Politics 11 Apr 20, 2011 03:10 AM
Discussion a good deal ? tell me what ya think. luke450 3D Electric Heli Flying 14 Apr 09, 2011 08:21 AM
Discussion THIS will keep ya busy for a WHILE. dll932 Life, The Universe, and Politics 2 Mar 23, 2011 04:12 AM
Discussion Hey, Cleveland's mobbed up too, ya know... dll932 Life, The Universe, and Politics 5 Mar 06, 2011 10:16 PM
