Old Apr 30, 2011, 04:51 AM
DCLXVI is offline
Find More Posts by DCLXVI
Instant Human, Just Add Coffee
Nederland, Noord-Holland, Hilversum
Joined Jan 2005
JXD Firmware
After being a while annoyed with the standard firmware in the JXD990 i made the following changes to it:
- Setting the TV-IN function as first option in the menu
- Setting the default TV-IN recording resolution to full
- removed the top bar and progress bar and placed the recording indicator, time and percentage at the bottom of the screen.
This is based on the 990C_935B_WK0826 firmware.
If others want this firmware i can put it online for download.
While doing this i discovered how to bring back the TV-IN function of my "bricked" JXD318 that doesn't record anymore after a firmware update, and even get rid of the interlaced pictures when recording in full resolution.
DCLXVI is offline Find More Posts by DCLXVI
Old Apr 30, 2011, 05:06 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
DCLXVI that is good news!!!! Can you post a link so I can download it and tell me how to ''flash'' the firmware ??
THanks!
saucisse is offline Find More Posts by saucisse
Old Apr 30, 2011, 05:31 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
how you did to make it record in deinterlaced mode the JXD318 ?
when i touched JXD318 firmware i was just able to touch xml files,
i even tried to make to record in MJPEG but didn't success.
if you succeed to make it record in progressive mode i would like to know how you do it
looks like we got the same concept of design, i did exactly the same mod to my 318
wallaguest1 is offline Find More Posts by wallaguest1
Old Apr 30, 2011, 05:58 AM
DCLXVI is offline
Joined Jan 2005
USE THIS AT YOUR OWN RISK!!!!!!
Here is how to update:
First check the current firmware in the JXD990 (Settings > System information)
This should be 990C_935B_WK0826 (Do you have an other version please post it before updating)
BACKUP ALL YOUR FILES OF THE JXD as they will be erased !!!!!!!!
Download Firmware + Flashtool
Extract the ZIP file and run FRM.exe from the sub directory
Set the options as shown in the the picture
Browse for the bootcode to Images_RedBoot_201000427.img
Browse for the resource + Bin file to Firmware.img
Now turn off the JXD990
Press and hold the + button
Plug in the USB cable still holding the + button
Wait until DEV0 turns blue and show connected, now release the + button
Check all settings again en press ISP
Wait for the updates to be done (can take a few minutes)
DO NEVER DISCONNECT THE JXD MEANWHILE AS YOU WILL BRICK IT !!!!!!!
When the update is done disconnect the JXD and press the reset button (to get it out of updating mode)
Turn it on, the bootscreen will be shown for a few minutes while the JXD is configuring it self.
Now the new firmware should be ready for use.
Old Apr 30, 2011, 06:07 AM
DCLXVI is offline
Joined Jan 2005
You use s(UN)pack tools for editing the XML with the Sunplus 8000 toolkit you can extract parts and compile it again i have used the 990 recording code in the 318 as this has some kind of deinterlacing in full resolution recording.
Old Apr 30, 2011, 06:21 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
My JXD 990 says: Version: 06.11.53.44 Descript: 990_935a
Can I flash it ?
Old Apr 30, 2011, 06:23 AM
DCLXVI is offline
Joined Jan 2005
wallaguest1, what firmware you have now in your 318?
Old Apr 30, 2011, 06:26 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
This is brilliant! I could never get to grips with the Sunplus tools...
Could you post the 990C_935B_WK0826 firmaware someware. Mine is an older version.
Shikra is offline Find More Posts by Shikra
Old Apr 30, 2011, 06:27 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I guess we have to flash the 990C_935B_WK0826 if we have an older firmware version ?
Old Apr 30, 2011, 06:30 AM
DCLXVI is offline
Joined Jan 2005
Can I flash it ?
NO you have a different recording chip, when flashing it you will loose the TV-IN function, i can compile a version for you with the correct chip but i can't test it !!!!!! so it is for your own risk
Old Apr 30, 2011, 06:34 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
No prob I'll test it. I only use my JXD for ground recording ''just in case'' since I have live telemetry and coordinate no prob if I brick it lol They say you don't get nothing if you don't try
Old Apr 30, 2011, 06:37 AM
DCLXVI is offline
Joined Jan 2005
The firmware included in the ZIP file is this version with the modifications
BUT PLEASE BE CAREFUL with flashing when you have other firmware versions, JXD is known for whatever recording chips they can get their hands on to put in the devices for now i know that their at least two of them in the 990 and 318
Old Apr 30, 2011, 06:38 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
I'll test if you want -mine isn't working any more... Nothing to loose
Old Apr 30, 2011, 06:40 AM
Joined Nov 2006
the one i am using now is:
06.27.44.62
318_5420
quite old in fact, i guy from this forum told me there is a much more new firmware but i was unable to install his firmware in my JXD318
i guess the dumping tool (frmorp) is not perfect enough yet,
Old Apr 30, 2011, 06:41 AM
npole is offline
Find More Posts by npole
Joined Apr 2009
The major JXD990 problem (that's really affect the visualization and your recordings quality), is the autodim adjustment. It does have a sense when used with the internal camera, but for some exotic reasons the programmers decided to leave this feature enabled with the TV-IN!! So if you're recording anything (this includes .. films) at each brighter scene it step down the brightness; when flying if you have your OSD on (usually white) it makes the whole scenery dark. Looked for a solution by years.. but didn't found any. :\
npole is offline Find More Posts by npole
Help! JXD Drift King 340 micro heli Help! sarsshadow Crash Discussion 3 Feb 04, 2012 01:30 PM
Discussion JXD 340 Drift King BATTERY BLuEArMy Coaxial Helicopters 7 Jan 16, 2012 02:49 PM
Mini-Review JXD 331 aka Viefly v268 or Gyro Commando Ornithopter Coaxial Helicopters 4 Jun 04, 2011 08:38 PM
Discussion mjx F27 VS JXD drift king cedddddd Coaxial Helicopters 12 Apr 06, 2011 04:21 PM
Discussion JXD 921 or JXD 990? Cralis FPV Talk 84 Oct 12, 2009 08:26 AM
