This thread is privately moderated by Thermalin, who may elect to delete unwanted replies.
Old Oct 02, 2011, 08:39 PM
JIMBOJONES is offline
Find More Posts by JIMBOJONES
JIMBOJONES's Avatar
United States, IN, Milan
Joined Feb 2009
hardware store window insulation heat film
JIMBOJONES is offline Find More Posts by JIMBOJONES
Old Feb 17, 2012, 09:52 PM
Helno is offline
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
You could buy a bunch of space blankets and use packing tape to hold them together. Probably the cheapest source of mylar available and it is nice and shiny.
Helno is offline Find More Posts by Helno
Old Feb 29, 2012, 04:42 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Originally Posted by CAFplanekid View Post
I can't remember the name of the plane, but there is a manned, powered plane that has been around a while made out of pink insulation foam. Search for it.
That is a huge piece of foam! Ribs could be made of regular 2" insulation foam for less cost and easier cutting. Cap the ribs with yard sticks.
PVC is pretty flexy: you might be able to find bamboo at a landscaping store.
The best craft at the event I was at was built like a huge kite, by a company specializing in fabric and aluminum tube sculptures. It had a surprising glide ratio, thanks to a huge wing area. I have not really seen any conventional air foil designs do well. You just can't get enough airspeed, and alot of the time the wings buckle as soon as they go off the edge and fall.
1x3 OR 1x4 laid flat with1/4 ply between for a very nice spar. Route a 1/4 groove for the ply to be glued into.
I think I would go with some heavy plastic drop cloth for the covering.
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Apr 28, 2012, 09:43 AM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
aircraftspruce website sells aircraft dacron. About 17 cents a square foot, in 60 inch rolls.
Glue it onto wing spars with white glue. When glue is dry, use a hair dryer to shrink it tight.
This is what the big scale RC plane builders use. It must be sealed with something like Polycritic clear floor finish, or a light spray paint job.
wuest3141 is offline Find More Posts by wuest3141
Question High quality small mAh vs. cheap quality large mAh pack Munch Batteries and Chargers 8 Apr 03, 2011 02:38 PM
Question Easy way to transfer large amount of data over the internet? Bugman Jeff Chit Chat 6 Dec 28, 2008 05:25 PM
FS: Large amount of Parkflyer and Indoor equipment epilot Aircraft - Electric - Airplanes (FS/W) 0 Oct 04, 2004 03:18 PM
WTD- small amount of red and blue covering CAWayne Aircraft - Electric - Airplanes (FS/W) 5 Nov 04, 2002 08:42 PM
