Old Nov 04, 2012, 09:10 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Sorry about the crash. F-4 Phantoms already have some bad tendencies and your nose heavy construction probably intensified the issue. I had one of the Eflite Phantoms and I was surprised at how easily the wing would stall on low speed banked turns. Good luck with whatever you choose to do. I personally like flying more than building so I usually go with ARF kits. I just recently traded in my Wren 44 turbine for one of their new Wren 75 Jubilee turbine wih 18lbs of thrust. I picked up an old unbuilt DL Aeromodels/Cermark MB-339 that I'll be putting the turbine into. Should be a great flyer.
Double E is offline Find More Posts by Double E
Old Nov 05, 2012, 01:26 AM
GRVW is offline
Find More Posts by GRVW
Australia, ACT, Canberra
Joined Aug 2006
Originally Posted by 1alonso View Post
Hi
I am finishing my project of this same airplane from YA. I am using jettech tanks and a rabbit. But I am just not sure jet where the CG should go. Can you tell me where do you suggest to be?
thanks
The manual I have fot the Yellow F4 says 7 3/4" to 8 1/4" from the leading edge measured at the root, and that seems right to me. You are wise to use the saddle tanks. Good luck. Please post how it goes. Keen to hear.
GRVW is offline Find More Posts by GRVW
Found Yellow Aircraft F-4 MorneFerreira Aircraft - Fuel - Jets (FS/W) 7 Apr 25, 2011 10:44 PM
Sold Yellow Aircraft F-4 Kit therealhiphop Aircraft - Electric - Jets (FS/W) 2 Mar 19, 2011 10:24 AM
Sold Yellow Aircraft F-4 Kit therealhiphop Aircraft - Fuel - Jets (FS/W) 2 Mar 18, 2011 02:21 PM
Question 4.5kg/10lb thrust turbine jofro Jet Turbines 1 Mar 13, 2011 06:48 PM
Discussion Need some advice on Converting a yellow aircraft f-16C to EDF fenderbean Electric Ducted Fan Jet Talk 3 Mar 07, 2011 06:50 PM
