Old Oct 16, 2001, 10:39 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Using APC electric props on standard prop adapters
Does anyone know how to use regular prop adapters with the new APC electric props? The prop is too thin and I cant tighten down the nut far enough to grip. Any ideas, dymond sells some adapters in the right size but I dont know if they are short enough,
Thanks Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Oct 17, 2001, 12:01 AM
Brad Trent is offline
Find More Posts by Brad Trent
Brad Trent's Avatar
Canada, BC, Abbotsford
Joined Mar 1999
Joe, I just add 1 or 2 thick aluminum washers, till the not will work properly.
Brad.
Brad Trent is offline Find More Posts by Brad Trent
Old Oct 17, 2001, 12:38 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Joe,
It won't help now, but the earlier versions of the APC-E props had really thin hubs (and blade trailing edges that went well aft of the back face of the hub). Later ones have thicker hubs and blade TEs that don't project aft of the aft hub face.
In the meantime Brad's suggestion is a good one.
I am still occasionally frustrated by those thin hubs myself. A thick but light washer or two between the prop and prop nut are the way to go. Nylon ones tend to be a bit slippery, though. Aluminum would be better.
BEC is offline Find More Posts by BEC
Old Oct 17, 2001, 03:33 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
The hubs seem to vary in thickness depending on pitch (or maybe this is just coincidence). But I haven't had a problem (i.e. needed to use packing washers) with the 10" and 11" ones I've tried, I'm using the Graupner shaft adapters with the domed prop. nuts.
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 17, 2001, 09:39 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Having given all my wooden props a new career in home decorating, that is the last frustration going. Bet anyone who uses many APC-Es has a pile of washers in their field kit by about week 3!
You might find a driver has an overlong thread - I usually have to whack them down a tad with a Dremel driven cut-off wheel too.
APC seem to be able to respond to a need for change - maybe if we all wrote them and asked nicely for thicker hubs?
I find it vaguely amusing that they supplier very accurate bushes to downsize the prop hole, when the first thing I have to do is ream the prop out to fit 1/4" or 5/16" driver shafts!
Dereck is offline Find More Posts by Dereck
Info on Large APC Electric Props Wanted Stephen M Scale Kit/Scratch Built 7 Dec 10, 2002 10:19 PM
APC electric props - Strong? climber Sport Planes 6 Sep 18, 2001 02:04 PM
Zagi-bending motor shafts using Master Airscrew props on belly flops Balin Foamies (Kits) 7 Jul 22, 2001 08:58 PM
K prop & K eff for APC Electric Props (8x6)? BEC Electric Plane Talk 1 Jul 09, 2001 12:16 AM
How to make the new APC Electric props fit your adapter Joe Elston Electric Plane Talk 6 Jun 17, 2001 01:56 AM
