Old Apr 28, 2011, 01:23 PM
rotorblade400 is offline
Find More Posts by rotorblade400
Joined Sep 2008
Help!
Of Amps, Volts, and Watts!
I have the Protek 40 power supply which has 4 individually switched 16 amps outputs. (13.8 V, 40 amps, 520 Watts). On each of the four outputs I am plannig to hook up and charge the following batteries:
1. I am planning to use the Hyperion DUO, charging 2 6S 5 Amp LIPO batteries at 4 amps;
2. using a second charger, the Protek DUO again charging 2 6S 5amp LIPO batteres at 4 amps
3. using a single hyperion charger, again putting up one 6S 5amp LIPO at 3 amps
4. and exactly the same as (3) on the 4th output.
By my count, this should put a total load of 22 amps and slightly more than 300 watts on the power supply. Will that work or is that too much?
Any help would be greatly appreciated!
rotorblade400 is offline Find More Posts by rotorblade400
Old Apr 28, 2011, 04:45 PM
bionicbone is offline
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
i get the feeling your calculation is incorrect. if your charging 6S at 4amps from an input voltage of 13v then the input to the charger is half the output voltage. I'm no experr but i think that would mean the current draw from your power pack would be more like 8amps.
i'll let the experts answer with more details but thought i'd chip in before something gets warm or worse goes pop.
kev
bionicbone is offline Find More Posts by bionicbone
Old Apr 28, 2011, 05:29 PM
thenodemaster is offline
Find More Posts by thenodemaster
Mini-Me is watching you...
thenodemaster's Avatar
Hemet, CA
Joined Aug 2010
kev
You are correct. Remember: Volts*Amps=Watts, Watts/Volts=Amps
thenodemaster is offline Find More Posts by thenodemaster
Old Apr 28, 2011, 07:06 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
Those duo chargers, you mean 1 6s battery on each port right?
So to charge one of them at 4 amps, you need approx 100W (25V*4 amps) per battery. So if each output is 16 amps on your PSU you've got 13.8*16 = 220W per port. I think you could do that ok on any one of the ports BUT.. when you add all the other batteries and chargers to all the ports you exceed your total psu wattage. You'll probably have to charge at a bit less amps to keep the total under 520.
dennisjm is offline Find More Posts by dennisjm
Old Apr 30, 2011, 04:05 PM
Joined Sep 2008
of vots, amps and watts
Thanks, mulicheng, very useful answer!
Help! Of Amps, Volts, and Watts! rotorblade400 Electric Heli Talk 5 Apr 28, 2011 09:15 PM
Yippee! Dual-Range Power Analyzer – Accurately measures Volts, Amps, Watts, Amp-Hrs, Watt-Hrs MRI Medusa Research 123 Mar 23, 2005 04:10 PM
Dual-Range Power Analyzer – Accurately measures Volts, Amps, Watts, Amp-Hrs, Watt-Hrs MRI Product Announcements 4 Aug 07, 2004 01:46 PM
Question Watts Volts Amps ? BRIANRC Batteries and Chargers 18 Mar 29, 2004 05:45 AM
Motor heat: amps, volts or watts? meteor Power Systems 46 Jan 16, 2004 02:19 PM
