Espritmodel.com Heli Air
Old Jul 06, 2012, 04:01 PM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
My F18 shall fly at KY Jets next week. Landing will happen at least once though I'm hopeful for many
carl rich is offline Find More Posts by carl rich
Old Jul 06, 2012, 04:10 PM
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Good luck Carl, I was just wondering the other day how this was progressing. Keep us posted!
strictlyscale is online now Find More Posts by strictlyscale
Old Jul 06, 2012, 05:34 PM
Die Meistertinkerer
Frankensteen's Avatar
United States, GA, Columbus
Joined Jan 2006
Best of luck Carl! Wish I could be there...
Frankensteen is offline Find More Posts by Frankensteen
Old Jul 06, 2012, 06:33 PM
gunradd's Avatar
Tampa FL
Joined Apr 2009
Awsome Carl!
What day you getting in? Ill be their Monday night till Sunday morning.
gunradd is online now Find More Posts by gunradd
Old Jul 06, 2012, 06:53 PM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
I'll be there Thurs morning thru Sat afternoon. I'll either be there this Sunday for the day or come down Weds instead of Thurs. Always a fun time.
Old Jul 06, 2012, 11:11 PM
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Right on Carl!!!
any install pics? good luck man... would love to know your CG and control throws after you have a good maiden
Ron101 is offline Find More Posts by Ron101
Old Jul 06, 2012, 11:27 PM
Ron101's Avatar
Joined Jul 2007
I'm working on a GS P-47 ARF, but can't wait to get back on the F-18....
my goal is to have it done by Jan. and take it to display at the AMA show in Ontario... been working and flying as much as I can so progress has been slow
but I plan to pick up the pace agian soon
Old Jul 07, 2012, 08:18 PM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
CG is at 11mm ahead of the front spar. Thought this to be enough ahead while still significantly behind a turbine model loaded w/ fuel. Can come back from here after first flight. Throws set as suggested in manual. Not sure the airbrake will be needed but it and the canopy are functional. Any last minute reminders from those that have done their homework on how this bird will fly?
Old Jul 10, 2012, 09:45 AM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
48 lbs 4oz of lighteness.
Old Jul 10, 2012, 09:49 AM
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
Wow!!Are you serious?It weighs that much?
gjmjoe017 is offline Find More Posts by gjmjoe017
Old Jul 10, 2012, 09:58 AM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
I think what is throwing you is that lighteness should probably only have one e. So, 48 lbs 4 oz of lightness. Fortunately, the weight I've added has been where the cockpit will go and is almost identical to the cockpit/pilot weight. Should the plane have more than one take off and an equal number of planned landings at Ky Jets it will get a cockpit and numerous upgrades to look better for Ejets.
Old Jul 10, 2012, 12:57 PM
United States, CA, Los Alamitos
Joined Jan 2011
48-50 lbs
Well we fly 20-27 lbs on one fan so it should work. Just gotta bring some brass to the flight line and push forward and pull up. Good luck on your many flights. I think projects like this make guys re-evaluate is it the plane or is it me.
So flying a big twin like the F-18 I have not, but I have flown a big twin ME-262. It has the weight of 12s x 2 7600mah for packs on each fan 120mm's. It is a rush for sure and will look forward to yours and Ron's maidens.
It is always inspiring to see projects that go to the next level.
Well waiting for videos.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Jul 10, 2012, 09:15 PM
Philadelphia, PA
Carl, kirks hunter flys great on the same fan you have. It weighs 35.5 lbs, single fan. I know the setups aren't identical but at least you know what it's been pushed to. Keep us posted.
Old Jul 10, 2012, 10:11 PM
Ron101's Avatar
Joined Jul 2007
Carl if it makes you feel better Smoking Joe Mcbrides legendary yellow twin is 42 pounds dry and 52 pounds wet... flies beautiful !!!
My goal is 42 loaded
F/A-18 Hornet turbine by Yellow Aircraft (5 min 57 sec)
Old Jul 11, 2012, 05:08 AM
EDF Crazy's Avatar
UK
Joined Oct 2007
Carl, good luck on the maiden.. i hope someone gets some good video footage.
Ron, did you fabricate those fan mounts? My hornet didnt have anything like that and was planning to make something very similar. Your F18 is coming along nicely.
EDF Crazy is offline Find More Posts by EDF Crazy
Discussion Yellow Aircraft kits, Old vs. new deluxe kit..F-18 Ceeray Electric Ducted Fan Jet Talk 3 Apr 12, 2011 09:07 PM
Build Log Yellow Aircraft F-18 Twin Build k_sonn Electric Ducted Fan Jet Talk 146 Apr 27, 2009 10:12 AM
Poll Online Build -- BVM F-86 vs Yellow Aircraft F-18 k_sonn Electric Ducted Fan Jet Talk 56 Oct 02, 2008 04:43 PM
Re: Any Yellow Aircraft F-18 Twin owner here? X-spec Fuel Jet Talk 10 Mar 16, 2005 08:19 AM
Cool Yellow Aircraft F-18 Twin EDF GregG Electric Ducted Fan Jet Talk 39 Jul 18, 2001 01:21 PM
