Old Apr 28, 2011, 10:54 AM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Help!
Jet pump drive info
Greetings,
Looking for info from the guys that really know the hobby.
I'm trying to locate a jet pump for a large scale RC boat that will use a 5 to 10 hp electric motor; thinking something like a mini version of what is used on a PWC/ Jet ski.
Speed required is not fast, something on the order of 5 mph min, 10 mph max.
Big boat, 48 inches long x 30 inches wide, 150 to 200 lbs, lots of drag and salt water.
Good acceleration is desirable, and 5 second bursts are intended, so efficiency for acceleration is desirable, rather than for speed.
This drive does not have to be steerable, although left right, up down.
I understand this project is asking for something likey way outside of the ordinary.
If no pumps are available, then I would want suggestions for a screw solution that I can put a grate over, allowing water to pass through, but not fingers.
Hoping to find off the shelf products for this.
Any help or suggested source greatly appreciated!
Eric
epwierman is offline Find More Posts by epwierman
Old Apr 28, 2011, 11:40 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
This uses a jet drive and is electric, not sure on details of the drive though:
http://www.robotspodcast.com/forum/v....php?f=3&t=882
If you can find more details of it, you might find a useful drive.
wparsons is offline Find More Posts by wparsons
Old Apr 28, 2011, 02:54 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Here's the biggest one I've seen.
http://www.hobbyking.com/hobbyking/s...dProduct=13388
Paul.
785boats is offline Find More Posts by 785boats
Old Apr 28, 2011, 11:40 PM
sundogz is offline
Find More Posts by sundogz
Platinum Card Member
sundogz's Avatar
United States, AR
Joined Sep 2007
Reminds me of this http://wavejet.com/
sundogz is offline Find More Posts by sundogz
Old Apr 29, 2011, 12:30 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
You could make your own:
coriolan is online now Find More Posts by coriolan
Old Apr 29, 2011, 12:33 AM
10x8 is offline
Find More Posts by 10x8
Cookie
10x8's Avatar
Australia, NSW, Petersham
Joined Sep 2005
http://www.rcgroups.com/forums/showthread.php?t=1311309
10x8 is offline Find More Posts by 10x8
Old Apr 29, 2011, 01:59 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Or this: http://www.powerski.com/content/psi_index.php
Firehawk989 is offline Find More Posts by Firehawk989
Old Aug 27, 2012, 05:13 AM View Post
ben007
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Aug 27, 2012, 10:07 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Eric,
Check the MHZ jets:
http://shop.mhz-powerboats.com/category-11/category-22/
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Aug 27, 2012, 01:37 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
You intend to have a 200lb hull at 48" long float? I would've thought that would easily sink.
The hobbyking jet drive and a 6 or 7kW motor would work if you were spinning 10-20k rpm, anything more than that wouldn't be reasonable. Not ure how fast it would go but you should definitely get 5 mph, probably get it on plane depending on the hull type. Do you have plans or a design drawn up? That could help.
boaterguy is offline Find More Posts by boaterguy
Old Aug 27, 2012, 08:41 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Here has up to a 49mm impeller diameter.
http://www.cornwallmodelboats.co.uk/...upner_jet.html
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 27, 2012, 08:50 PM
Joined Nov 2007
good point...
Wanted Jet Drive or flex shaft boaterguy Boats (FS/W) 0 Apr 20, 2011 07:04 PM
Question Aero Jet info - Found It dpw21562 Electric Plane Talk 1 Apr 07, 2011 08:47 PM
Discussion need some plumbing and pump info jeff262 Life, The Universe, and Politics 4 Sep 15, 2007 10:55 AM
Idea Azimuthing Centrifical Pump head drive... Shaun Hendricks Dock Talk 13 Sep 05, 2006 03:06 PM
FS: Jet Propulsion Pump ljfaraci Boats (FS/W) 3 Mar 07, 2005 11:53 AM
