Old Mar 22, 2012, 09:20 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
It would have been cool if these guys didn't release new hardware each time they screw up, making users buy new stuff each time, too.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 30, 2012, 12:28 PM
gustofusion is offline
Find More Posts by gustofusion
Joined Mar 2012
can anyone confirm the mount holes spacing on this board, the pdf indicates 44mm hole to hole, can this be confirmed? Thanks
gustofusion is offline Find More Posts by gustofusion
Old Apr 14, 2012, 08:45 AM
knupps is offline
Find More Posts by knupps
knupps's Avatar
Norway, Vest-Agder, Kristiansand
Joined Feb 2012
As a newbe I have to get it in realy slow.
Bought a S-802 octo with a TMF PRO Multicopter Controller.
http://www.infinity-hobby.com/main/p...72dd9d61c74a90
Have a problem with the the config. of the controlboard.
When I go THROTLE UP and LEFT, wait 30sec, it looks fine.
But when I start motors, they start with a high speed........
I can control them, but with throttle is down they will no stop.
They still turn rather fast.
I have read most of this post, but there is something I am missing.
Had a Gaui 330 and the manuals are understandable, but this is not.........
PLEACE HELP.....................
My new quad frame. (1 min 38 sec)
Here is my new quad using Gaui parts.
knupps is offline Find More Posts by knupps
Old Apr 14, 2012, 08:57 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
The motors are meant to 'idle' when the board is armed. Some FC's let you stop the motors when the board is armed but with the TMF they keep spinning to tell you 'I'm armed, if you wanna come near me please disarm'. I think it's a great safety feature.
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Apr 14, 2012, 09:07 AM
knupps is offline
knupps's Avatar
Joined Feb 2012
Thanks, I can understand that safety issue, but I think they are spinning too fast.
Close to liftoff speed, .... I think.........
Might try it with the proppellers on and see what happends.
Old Apr 14, 2012, 12:03 PM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Hi guys,
getting some problem here. I have used FH-X46 before on my quad, without any issues.
Now I built a hexa and have significant problem with stability. I have the switch set to position "1", front of the FC goes between 2 front legs. The copter gets airborne at about half throttle using motors Turnigy Park 1050kv with 8x4 props, m2m is 530mm. No heating issues at all. The hexa is very instable, have to make corrections all the time while taking off or hover. 40% expo set on AIL, ELE, despite of this a very little correction makes a big move with the hexa. It seems like there is no self leveling at all. How could this be possible?
Can this be caused by the little propellers or rather some vibration, what do you think?
icah is offline Find More Posts by icah
Old Apr 14, 2012, 06:02 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Assuming propeller rotations, CG etc etc are correct, I have the gain set at maximum on my hexa, no expo. Very stable !! Vibration can potentially cause problems. Do you have the coin stuck on the top of the board as suggested?
Mark
kaz1104 is offline Find More Posts by kaz1104
Old Apr 14, 2012, 06:22 PM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
Mark
i have not seen/read that one before
whats the purpose of putting the coin there ?
QiW is offline Find More Posts by QiW
Old Apr 15, 2012, 01:44 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
Coin just add a bit of weight, and dampens the high frequency vibrations ... does seem to have a positive effect.
Old Apr 15, 2012, 07:44 AM
icah is offline
Joined Oct 2010
Just made another flights today, after rechecking all the motor, prop directions I have suspected my battery that it could not give enough power for the hexa. 2200mAh/20C was replaced by 5000mAh/20C. The difference is very noticeable! Now the hexa flies okay, except that it can not stand the wind as much. (small m2m) To be sure to decrease vibrations I have put some dampeners below and above the FC mount holes.
Anyhow, the proble was caused by the battery, giving out insufficient power. However, my battery is now getting warm what is weird because I have used it formerly on my 770mm hexa with lower kv motors and 12x4.5 props without any heating issues. Seems that lower kv motors with bigger props need less C than higher kv ones.
Old Apr 30, 2012, 07:14 AM
knupps is offline
knupps's Avatar
Joined Feb 2012
I am about to do my maidenflight with my S-802 octacopter with TMF Pro controller.
My question is: Which setting is default on the attitude?
See picture:
Wanted quadcopter/octocopter/hexacopter ashabelnikov Aircraft - Electric - Helis (FS/W) 1 Feb 21, 2011 01:04 PM
Discussion Foxtech FH-25HD 550tvl day/night mrleenagle FPV Talk 8 Aug 13, 2010 09:36 PM
Discussion I need help building a quadcopter or hexacopter lazer155 Coaxial Helicopters 17 Feb 23, 2010 08:47 AM
Discussion Hexacopter using microkopter controller lazer155 Coaxial Helicopters 2 Apr 15, 2009 09:50 PM
