Old Apr 27, 2011, 08:23 PM
reacher10 is offline
Find More Posts by reacher10
reacher10's Avatar
United States, NY, Shirley
Joined Oct 2008
Question
On board glow driver voltage regulator
I've been flying electrics for some time now and now have 2 glow planes as well.
I picked up a 63" Super Chipmunk and I'm just waiting for some nice weather to maiden it. http://www.generalhobby.com/super-ch...ane-p-104.html
I mounted an Evolution .60 inverted and even with the cowl off it's not straight forward putting on the glow driver. So I made my own on board glow driver. It has a remote plug for a regular glow driver, a toggle switch for the on board and I can also activate with my Tx. A green LED lets me know the on board switch or the Tx is activating it. A red LED will light if the glow plug is burnt out or if the glow plug is not getting current.
I first tried a single 2000 mah Eneloop nicad and then 2 Eneloop's in series and finally 4 cells, 2 in series and those in parallel.
I want to use a single lipo cell. The problem is the voltage is too high...I had to try it.
I just would like some of the more versed do it your selfers if they could take a look at this voltage regulator and tell me if it's suitable for stepping 4.2v down to a usable voltage for the glow plug.
Here is the regulator: http://cgi.ebay.com/DC-DC-POWER-CONV...item3cb689b09f
Here is the info:
DC/DC POWER CONVERTER VOLTAGE ADJUSTABLE 1.2V TO 18V
DC to DC Converter Module
Compact DC-DC Step-Down Converter Module. The output voltage is adjustable via the blue trimmer. Ideal for any electronics project.
Features:
Input Voltage: 3-30VDC
Output voltage: 1.21-18VDC
Max output current: 3A (Recommend use following in 2A, leaving a certain margin)
Built in LM2596S-adj
Dimensions: 37mm x 37mm
*Step-down: The input voltage must be at least 1.5v higher than the output voltage.
Package includes:
1x DC-DC Converter Module
2x Cable
To me it looks like it'll work and then I can use a single 5000 mah lipo cell and this should give me plenty of starts.
Does it it look like it'll work?
reacher10 is offline Find More Posts by reacher10
Old Apr 27, 2011, 09:15 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Most Glow plugs draw more than 3 Amp, Enerloop are Nimh (not Ni-cad) and not good for high drain as you found out. Jomar has a nice unit for that very purpose that I would trust more than some ebay shadowy dealer:
http://www.emsjomar.com/SearchResult.aspx?CategoryID=6
What you need to use for power is a D-size (AA size just can't provide the current) or even F-size Nicad so you won't have to deal with the voltage regulator.
coriolan is online now Find More Posts by coriolan
Old Apr 27, 2011, 09:44 PM
reacher10's Avatar
Joined Oct 2008
Thanks for the info. I know I wrote nicad however I know they are Nimh batts.
I'll have to check and see what the amp draw is and I think you might be right about 3A max draw not being enough.
I'll stick with what I have and give it a real world test when I take her up.
I'll order the regulator for 9 bucks and give it a shot. I'll find a use for it somewhere.
Old Apr 28, 2011, 03:25 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
why use switching devices where a single "C" ( 23*43) element perfectly fits ???
just add a a plus or minus intelligent switch to drive it i.e.: http://aeronews.free.fr/archivesarti...ropratique.zip
Alain
Acetronics is offline Find More Posts by Acetronics
Old Apr 28, 2011, 08:35 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Hey Alain, that link doesn't seem to work............
dmccormick001 is offline Find More Posts by dmccormick001
Old Apr 28, 2011, 09:09 AM
reacher10's Avatar
Joined Oct 2008
I clicked on this file in the zip that DL's: electropratique.htm and it came up, It has to be translated.
Old Apr 28, 2011, 01:41 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Dave
" Open in a new folder" .... Works fine here
Alain
Old Apr 28, 2011, 01:43 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
hé,hé ... not always europeans to translate from US English
Note drawings and hex files are international ...
Alain
Old May 02, 2011, 11:01 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
What I use:
http://www.horizonhobby.com/Products...ProdID=EXRA550
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old May 14, 2011, 02:03 PM
Wind Raider is offline
Find More Posts by Wind Raider
Joined Mar 2007
http://www.rcgroups.com/forums/showt...2#post18234098
Wind Raider is offline Find More Posts by Wind Raider
Sold SAITO 90TS Flat Twin AAC with on board glow driver Aeromister Aircraft - Fuel - Engines and Accessories (FS/W) 1 Dec 27, 2011 04:23 PM
Sold On board glow driver Kyle D. Aircraft - General - Miscellaneous (FS/W) 1 Mar 31, 2011 05:20 PM
Question Advanced Glow Switch/On Board glow driver deckert Fuel Plane Talk 4 Jul 20, 2010 03:05 PM
For Sale Flight Glow II - On Board Glow Driver - New Steve_O Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 14, 2009 08:26 AM
Sold On Board Glow Driver - MPI Super Glow NIB Gnarly1 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 23, 2008 06:44 AM
