Old Apr 27, 2011, 05:08 PM
ronbo422 is offline
Find More Posts by ronbo422
No Lawn Darts
ronbo422's Avatar
USA, TX, Leander
Joined Dec 2006
OS .61SF Needle setting?
Hey guys,
I'm putting my 2 nitro planes back in the air after 8+ years in the "hangar". Both are equipped with OS .61 SF's. What should my initial needle setting be? I started one today and it idles great and runs good up to about 1/2 throttle, but when I go WOT it dies. Seems like it's rich but I turned needle in 3 clicks and it does the same. I wanna make sure I'm starting with the right setting but can't find my original paperwork from OS.
Ronbo
ronbo422 is offline Find More Posts by ronbo422
Old Apr 27, 2011, 09:03 PM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
An engine that's quite rich at full throttle will be running in a 4 stroke mode with lots of smoke from the exhaust. If yours doesn't get that 4 stroking sound after 1/2 throttle before cutting out then it's likely too lean on the high speed needle. Open the needle 1 turn and try again.
downunder is offline Find More Posts by downunder
Old Apr 27, 2011, 09:23 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Mine likes to run at 1 and 3/8ths turn from closed.
I believe most OS engines are less than 2 turns out for the final tune, 3 turns out has to be slobbery.
What carb do you have?
1320fastback is offline Find More Posts by 1320fastback
Old Apr 28, 2011, 02:30 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I would suggest that if it starts okay, then your "initial" needle setting is fine. Provided the carburretor is clean, and the jets are not bunged up with waxy varnish from the old fuel, you should be able to then tune it at WOT (or close to) by turning the main needle until the revs peak, and then open it a couple of clicks to make sure it's not running too lean.
If you're finding that turning the needle significantly (we're talking quarter-turns here, not clicks) doesn't make any difference, then you may have an air leak somewhere in the system, or the carburretor is partially blocked with hardened fuel.
abenn is offline Find More Posts by abenn
Old Apr 28, 2011, 10:40 AM
pryor808 is offline
Find More Posts by pryor808
pryor808's Avatar
United States, NY, Medford
Joined Oct 2008
Start off at 2 1/2 turns out.
pryor808 is offline Find More Posts by pryor808
Old Apr 28, 2011, 03:32 PM
ronbo422 is offline
No Lawn Darts
ronbo422's Avatar
USA, TX, Leander
Joined Dec 2006
Thanks. I'll give it a shot this weekend and see how it tunes out.
~Ronbo
Old May 01, 2011, 11:29 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
2 1/2 turns is about right to get any engine started... and that's all you need initially is to be in the ballpark... if that doesnt work try 3 turns.... if that doesn't work.. try 2 turns.... you just need too get it ticking over enough to fine tune it.
Once you get it running... open throttle... if it dies immediately with no sputter whatsoever.... its lean... turn out your needle about 1/4 turn...try again.... once you get it to transition to full throttle and running... turn your needle.. whichever way you've been turning.. listen for the peak RPM's... when it hits its absolute peak... turn out your needle about 1/8 of a turn(richen).... thats a ballpark to actually fly... this is all generally speaking... as it might take longer to do the first few times you try it... and you might find a quicker way... but essentially this is starting/tuning a 2stroke in short form. Good luck.
DGrant is offline Find More Posts by DGrant
For Sale OS .61SF Long Stroke with OS rear fuel Pump and 2 Headers folke190d Aircraft - Fuel - Engines and Accessories (FS/W) 3 Apr 05, 2011 05:44 AM
Discussion OS 50 hyper super low end needle setting cdog14550 Fuel Heli Talk 1 Jul 31, 2010 10:39 AM
Discussion OS 50 hyper super low end needle setting cdog14550 Engines 2 Jul 31, 2010 08:58 AM
Discussion OS 70 FS won't hold needle setting cfischer505 Engines 6 Mar 24, 2007 01:39 AM
