Old Apr 27, 2011, 04:14 PM
mazur50 is offline
Find More Posts by mazur50
Joined Apr 2007
Mosfet P-channel Linear Region control
Does anyone have a circuit for controlling Mosfets in the Linear Reagion.
I am locked into using a p-channel mosfet and cant use PWM.
I need to be able to controller the Mosfet with a pot and i have a heat since that will control the heat.
Thanks for all the help.
mazur50 is offline Find More Posts by mazur50
Old Apr 27, 2011, 07:41 PM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Voltage or Current control?
Simple single op amp would work, would need additional details (input voltage, frequency response, voltage rail, etc.)
BTW, why are you locked into a P channel?
ltc is offline Find More Posts by ltc
Old Apr 27, 2011, 07:58 PM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
just invert this for a P-fet
jglenn is offline Find More Posts by jglenn
Old Apr 27, 2011, 08:00 PM
jglenn is offline
Ohio
Joined Nov 2003
Or try a linear amp!
Old Apr 27, 2011, 08:05 PM
jglenn is offline
Ohio
Joined Nov 2003
P-ch the arrow points out. Just modulate the gate voltage. They are just like
grids in tubes!
Old Apr 28, 2011, 10:27 AM
mazur50 is offline
Joined Apr 2007
I am looking for voltage control. at the moment.
I have to use a P-channel becasue that is the side i have access to.
Old Apr 28, 2011, 10:32 AM
mazur50 is offline
Joined Apr 2007
How do you determin R1 and R3
Old Apr 28, 2011, 11:44 AM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Why a mosfet instead of a BJT? How close to the high side rail does the output need to come?
If you want to control the load voltage and can stand the output not coming completely to the high side voltage then you would be much better off using a NPN in common collector or N-Channel mosfet in common drain configuration. That way the output voltage is equal to the input voltage minus the junction or threshold voltage.
Using a P-Channel in common source will actually control the current through the load and you would need feedback(ie an op amp) to directly control the voltage of the load.
PS Added the quote because that is all the info we have. The quality of the output depends on the quality of the input.
jeffs555 is offline Find More Posts by jeffs555
Old Apr 28, 2011, 11:51 AM
mazur50 is offline
Joined Apr 2007
I need the output to be as close to the rail as possiable, that is why i dont want to use BJT. I am using a BJT now.
Can you give me a little more insight to your second line.
Old Apr 28, 2011, 06:57 PM
jglenn is offline
Ohio
Joined Nov 2003
How do you determin R1 and R3?
The fet gate voltage when running linear is sort of like the grid of a tube, a proportional
change affects conduction. The spec sheet will have the range, set up the pot divider
to cover that. There may be differences from device to device. And non-linearities.
Old Apr 28, 2011, 07:08 PM
ltc is offline
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
A rail to rail op amp, a FET and a few resistors. Linear, easy to scale and limit.
Simple
Old Apr 28, 2011, 08:00 PM
jglenn is offline
Ohio
Joined Nov 2003
This circuit works well, driven by an opamp.
There are also power opamps like the EL2008 that can drive 1A at RF freq.
Old Apr 28, 2011, 08:12 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
When a MOSFET is operating in its 'linear' region, Gate voltage controls Drain current. The action is similar to how Base current controls Collector current in a bipolar transistor, but at low currents the Gate contol is close to 'pinch-off' and highly non-linear. It is also quite temperature dependent.
A pot is OK if you don't mind constantly adjusting it, but if you want a stable output voltage then you will need an amplifier and feedback loop.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Apr 28, 2011, 09:43 PM
jglenn is offline
Ohio
Joined Nov 2003
Thanks for the curves. Some find that in digital switching, the rise and fall
are actually linear. Slow ramp or slew causes heating. Too fast causes spikes.
Old Apr 29, 2011, 12:14 AM
mazur50 is offline
Joined Apr 2007
I was looking at using the irf4905 because I have a few. How would I start.
For Sale Cox P-40 Control Line badbill Aircraft - Fuel - Airplanes (FS/W) 2 Mar 16, 2011 01:12 PM
Discussion control line flying in the Ottawa, Ontario, Canada region GrahamC Control Line 0 Apr 24, 2007 10:41 AM
Looking for P-Channel High-Side MOSFET Mr.RC-CAM DIY Electronics 20 Dec 13, 2004 05:39 PM
Question How To Control The Six Mosfet In Bldc CLEMENT DIY Electronics 1 Nov 07, 2004 06:14 PM
Speed Control Not Linear BQuick Electric Heli Talk 2 Jun 06, 2002 10:21 AM
