Old Aug 18, 2003, 04:00 AM
Denis Leveille
Denis Leveille
Guest
n/a Posts
How to reverse servo direction
I used to run RC cars before I got into planes and still have many
components left. As a matter of fact, I have enough components left to build
a car for my 8 years old nephew. However, I only have an old Futaba
controller left and it does not have the capability to reverse servo
direction. As servo direction for one of the channels must be reversed, I
have thought of 2 ways to reverse it:
Cut the white and black servo wires and reverse them (ie solder white to
black and black to white). Servo is a Futaba 148.
Open the transmitter and reverse wires 1 and 3 on the servo pots.
Are these methods appropriate? Is there any better way to reverse direction?
I realise my question is not directly related to RC planes but this NG has
proven so informative in the past that I am taking the liberty to post here
nevertheless.
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: How to reverse servo direction
No, neither one is appropriate. The best way is to buy a small reversing
module from someone like RAM. The other way is to open the servo and
reverse the two wires going to the motor and the two outer wires on the pot.
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
"Denis Leveille" <denis54@videotron.ca> wrote in message
news:FlX%a.29538$sa4.351220@wagner.videotron.net.. .
build
direction?
here
> nevertheless.
Old Aug 19, 2003, 04:00 AM
Dr1Driver
Dr1Driver
Guest
n/a Posts
> I
Neither will work, and both will likely ruin the servo or the transmitter.
I believe the S148 has the motor hard-mounted to the PC board. This makes it
almost impossible to reverse the servo inside the servo case. I'm not sure
swapping the pot wires inside the TX case will work. Personally, I'd buy a
"servo reverser" lead.
Frankly, you sound like you don't know too much about the electronics of a
servo or TX. If that's the case, definately buy the commercial servo reverser.
The servo leads for Futaba are RED - positive, BLACK - negative, WHITE -
signal.
Reversing ANY leads going into the servo case will NOT reverse the servo. It's
not the voltage (rd & blk) that must be switched, but the input signal (wht).
If the servo was soft wired, as they used to be (Futaba S128 and others), you
could swap the wires to the motor AND feedback pot inside the servo case.
Again, i'd buy the commercial servo reverser, or a whole new R/C set.
Dr.1 Driver
"There's a Hun in the sun!"
CRAngelo
CRAngelo
Guest
n/a Posts
First, try moving the mechanical connection to the servo to the opposite arm of
the servo. If that can't be done then the servo reverser would be appropriate.
Hope this helps---Ray
Denis Leveille
Denis Leveille
Guest
n/a Posts
I reversed the outer wires on the stick control pot. Everything works
perfectly without any problem. Thanks all for your inputs.
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Does your trim still work the correct direction?
Paul McIntosh
news:BV60b.31197$sa4.483283@wagner.videotron.net.. .
Old Aug 19, 2003, 04:01 AM
Fred McClellan
Fred McClellan
Guest
n/a Posts
That's the better solution - mount the servo so the output is reversed
_mechanically_.
Connect to the other side of the output arm/wheel, mount it upside
down or lay it on the opposite side, depending on the original
orientation.
Cheers,
Fred McClellan
the dash plumber at mindspring dot com
David AMA40795 / KC5UH
Guest
n/a Posts
I think you will find that the new Hitec Neon transmitter reverses the
servos by swapping the stick input to the PCB !!!!!!!!
Straight from the manual..........
Servo Reversing
After removing the back of the case you will find four plugs
(there are four plugs if you have the optional 4th channel feature).
Simply unplug and rotate the connector 180 degrees, plug it back onto
the board and the servo throw for that servo, is now reversed.
David
On Mon, 18 Aug 2003 16:34:53 +0000 (UTC), "Paul McIntosh"
>Paul McIntosh
>news:BV60b.31197$sa4.483283@wagner.videotron.net. ..
Old Aug 20, 2003, 04:00 AM
Jim Mullen
Jim Mullen
Guest
n/a Posts
What I do if your radio wont do it. Turn the servo around. Mount it in the
opposite direction. Sometimes this puts the arm further from the surface but
who care its less than an inch movement away.
Normal
________
O
________
Turned around
________
O
________
Dr1Driver
Dr1Driver
Guest
n/a Posts
>opposite direction.
Duh, Norm...the servo will rotate in the same direction no matter how you turn
it around. Think about it.
Dr.1 Driver
Sand57
Sand57
Guest
n/a Posts
Maybe move the pushrod to the other side.
>>opposite direction.
>Dr.1 Driver
Old Apr 30, 2009, 11:04 PM
Gerry E is offline
Find More Posts by Gerry E
Australia, QLD, Buderim
Joined Dec 2008
>opposite direction.
Dr.1 Driver
FLIP THE SERVO OVER NOT AROUND AND IT WILL WORK
Gerry E is offline Find More Posts by Gerry E
Old May 01, 2009, 02:49 AM
RogerN
RogerN
Guest
n/a Posts
"Gerry E" <Gerry.E.3rhn8n@rcgroups.com> wrote in message
news:Gerry.E.3rhn8n@rcgroups.com...
>> >opposite direction.
>> you turn
>> Dr.1 Driver
> Gerry E
> Gerry E's Profile: http://www.rcgroups.com/forums/member.php?u=238903
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=143057
I used to reverse the old servos by reversing the motor leads and the pot
wires. I don't know if this is easily done with the newer servos.
RogerN
Old May 01, 2009, 10:38 AM
Tim Wescott
Tim Wescott
Guest
n/a Posts
>>>> opposite direction.
>>> you turn
>>> Dr.1 Driver
>> Gerry E
> RogerN
I did it not too terribly long ago with an HS-55, but I've got a little
cobbled-together SMT assembly station in my electronics shop. I doubt
that I could do it without a microscope, although someone a decade or
two younger than I might.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Do you need to implement control loops in software?
"Applied Control Theory for Embedded Systems" was written for you.
See details at http://www.wescottdesign.com/actfes/actfes.html
Old May 01, 2009, 03:38 PM
rich
rich
Guest
n/a Posts
Reverse the servo's ARM...not the servo itself....
stupid newbee question - how to reverse a servo? garfield Foamies (Kits) 7 Mar 28, 2009 11:39 AM
How to reverse a servo? ashdec87 Electric Plane Talk 16 Jul 30, 2005 09:12 AM
How do I reverse a servo? RandyK1 Radios 9 Oct 09, 2003 09:32 PM
Help - How to Reverse Motor Direction? AZ_Astro Beginner Training Area (Aircraft-Electric) 8 Dec 18, 2002 08:01 AM
how do i reverse the servo and esc on my old radio? Sonic Electric Plane Talk 7 Jul 09, 2001 12:55 AM
