Old Apr 26, 2011, 09:55 PM
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Hk buddy codes
TURNIGY Transmitter Strap
http://www.hobbyking.com/buddy.asp?c...F-FFCCA0883054
Turnigy 800mAh 2S 20C Long Lipo Pack
http://www.hobbyking.com/buddy.asp?c...8-4DBBD60918C6
Rhino 360mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...7-EBA7A4444301
Rhino 360mAh 3S 11.1v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...E-EEFC117398A4
TURNIGY Basic 18A v3.1 Speed Controller
http://www.hobbyking.com/buddy.asp?c...F-BB80CD0D49D7
TURNIGY BESC Programming Card
http://www.hobbyking.com/buddy.asp?c...8-3C6AB3D21D3F
ZIPPY Flightmax 350mAh 2S 20C
http://www.hobbyking.com/buddy.asp?c...4-91A9D51DB6F6
GOOD FROM TODAY plus 14 days
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Apr 27, 2011, 01:43 AM
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
OrangeRx Satellite Receiver
http://www.hobbyking.com/buddy.asp?c...3-58A49C73A05A
Turnigy2836 brushless Outrunner 2350kv
http://www.hobbyking.com/buddy.asp?c...B-E98E32DF57B4
Turnigy Heat Shrink Tube 30mm Red
http://www.hobbyking.com/buddy.asp?c...1-7B709E54053E
HXT 4mm Connector to T-plug conversion charge lead
http://www.hobbyking.com/buddy.asp?c...D-FADA263A08B6
Main Rotor Blade Assembly Tool (5mm)
http://www.hobbyking.com/buddy.asp?c...4-94FBBEF594E7
Turnigy MG90S Metal Gear Servo
http://www.hobbyking.com/buddy.asp?c...A-1E92AAD9D2A5
TURNIGY Plush 6A /.8bec/6g Speed Controller
http://www.hobbyking.com/buddy.asp?c...8-57A86C7038ED
450 class Carbon Fiber Main Blade 325mm
http://www.hobbyking.com/buddy.asp?c...B-906E5E8B5A23
Turnigy 4mm AquaProp 31x22x14mm.
http://www.hobbyking.com/buddy.asp?c...5-BF6AA70299A7
CA Applicator Reg
http://www.hobbyking.com/buddy.asp?c...4-1E830D4B4B8A
CA Applicator fine
http://www.hobbyking.com/buddy.asp?c...3-93FD0F100D9F
Dakrat is online now Find More Posts by Dakrat
Old Apr 28, 2011, 07:13 AM
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
Are you guys aware of this thread: http://www.rcgroups.com/forums/showthread.php?t=1314501 (we are on page 294 already).
You can also post your buddy codes here: http://hk.rc-international.info/swarm
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Apr 28, 2011, 08:53 AM
Joined Dec 2009
hacker Style Brushless Outrunner 20-50S
hacker Style Brushless Outrunner 20-50S 8.71$
3.17mm Prop Saver w/ Adapter & 3 bands 0.44$
3mm Prop Saver w/ Adapter & 3 bands 0.44$
georgeus is offline Find More Posts by georgeus
Old Apr 28, 2011, 08:23 PM
USA, FL, Boca Raton
Joined Feb 2001
I' ll go ahead and move the code there,geoff
Old May 05, 2011, 02:32 PM
Slovakia
Joined Jan 2011
Super Light 5 Spoke Wheel D30xH7 (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...7-6271CE670E62
HobbyKing 4-6min Epoxy Glue
http://www.hobbyking.com/buddy.asp?c...9-FE4F11C5CAE7
Carbon Fiber Square Tube 750x3mm
http://www.hobbyking.com/buddy.asp?c...2-5FEFB8CE7F0C
MarkAurel is offline Find More Posts by MarkAurel
Old May 09, 2011, 12:52 PM
Joined Apr 2007
NTM Series 35-48A 1100kv / 640w
http://www.hobbyking.com/buddy.asp?c...7-655178D446C5
Normal price - $19,99
Body price - $12,10
TimeWheel is offline Find More Posts by TimeWheel
Old May 10, 2011, 12:29 PM
Joined May 2011
HK buddy Codes
Here are some more buddy codes
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...9-8559FE19015B
Turnigy Glow Plug Lighter Tool
http://www.hobbyking.com/buddy.asp?c...F-CF15F076BC45
Carbon Fiber Tail Blade 62mm
http://www.hobbyking.com/buddy.asp?c...5-1AF501755B16
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...6-0873A94C4214
HXT900 Replacement Gear Set
http://www.hobbyking.com/buddy.asp?c...6-054942E3CEEC
CA Applicator Fine (1pc)
http://www.hobbyking.com/buddy.asp?c...8-EADDAA829F3E
Ex-Long CA Ex-Tips (1pc)
http://www.hobbyking.com/buddy.asp?c...B-872AEC52BDF9
Hellyflyer is offline Find More Posts by Hellyflyer
Old May 11, 2011, 01:57 PM
Joined May 2011
some buddy codes
here are some buddy codes, added them to http://www.buddyprice.fr.nf/index.php
Rhino 1050mAh 2S 7.4v 40C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...C-D162B9592421
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...F-977A46D05E86
Rhino 460mAh 3S 11.1v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...5-901653E46A29
Turnigy nano-tech 460mah 3S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...4-5DA2E8C20158
Turnigy nano-tech 370mah 2S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...4-05922621E60F
Turnigy nano-tech 460mah 2S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...7-B8AD42C158E8
Turnigy 1600mAh 2S 20C Losi Mini SCT Pack
http://www.hobbyking.com/buddy.asp?c...6-A2CC294A2051
ZIPPY Flightmax 5000mAh 2S1P 45C
http://www.hobbyking.com/buddy.asp?c...E-CCEF90DF48C7
ZIPPY Flightmax 5000mAh 3S1P 45C
http://www.hobbyking.com/buddy.asp?c...A-1B30C6979DF7
ZIPPY Flightmax 800mAh 3S1P 20C
http://www.hobbyking.com/buddy.asp?c...7-F5AB8F2712E4
ZIPPY Flightmax 800mAh 2S1P 20C
http://www.hobbyking.com/buddy.asp?c...0-CEFCC5D3AE2B
PA45 Connectors (6sets/bag)
http://www.hobbyking.com/buddy.asp?c...4-B6C1C57F14E0
BMS-617MG+HS Super Fast Servo (Mos-FET) for Competition 6.8kg / .10sec / 46g
http://www.hobbyking.com/buddy.asp?c...7-883B195CB9AC
BMS-621MG High Speed Servo (Metal Gear) 6.4kg / .13sec / 47g
http://www.hobbyking.com/buddy.asp?c...E-9F8D9E846C06
HXT Lipo Monitor 3S. A must have for all lipo users!
http://www.hobbyking.com/buddy.asp?c...5-5045552FBDF4
R/C Helicopter Pitch Gauge
http://www.hobbyking.com/buddy.asp?c...E-4219436777E8
HK-310 3 Channel 2.4ghz FHSS Ground Radio
http://www.hobbyking.com/buddy.asp?c...A-1FF37FA71C4D
Lithium Polymer Charge Pack 18x22cm Sack
http://www.hobbyking.com/buddy.asp?c...C-4CFB01A4D111
Valid until may 24
five is offline Find More Posts by five
Old May 22, 2011, 12:38 PM
Philippines, NCR, Makati City
Joined Dec 2004
Turnigy 1811 Brushless Indoor Motor 3800kv
http://www.hobbyking.com/buddy.asp?c...A-5F0EC9D65D2F
belabs is offline Find More Posts by belabs
Old May 24, 2011, 08:36 AM
Croatia, City of Zagreb, Zagreb
Joined Oct 2010
quanum telemetry
http://www.hobbyking.com/buddy.asp?c...E-C693AA476680
volt temp addon
http://www.hobbyking.com/buddy.asp?c...0-173707F26333
multi remote operated switch
http://www.hobbyking.com/buddy.asp?c...C-2BEFB9CCE3C1
zaguar is offline Find More Posts by zaguar
Old Jun 01, 2011, 08:21 AM
Joined Jan 2006
New item - KK multicopter compatible quadrocopter controller!
http://www.hobbyking.com/buddy.asp?c...8-987016F86A5C
McRancor is offline Find More Posts by McRancor
Old Jun 06, 2011, 12:32 PM
North Lake Tahoe
Joined Nov 2009
Turnigy 800mah 2s 20c-30c long lipo.
Possible to use with Blade Cx3 with very slight mod.
tahoelight is offline Find More Posts by tahoelight
Old Jun 29, 2011, 02:47 AM
ddark's Avatar
Zadar, Croatia
Joined Aug 2010
Some from me too:
HobbyKing 929MG Metal Gear Servo 2.2kg/ 12.5g/ 0.10sec
http://www.hobbyking.com/buddy.asp?c...A-B5CFA5C919E0
Servo Mount/Protectors (2pcs/bag) 50mm
http://www.hobbyking.com/buddy.asp?c...7-8A38E7C3A620
Hobby King 60A ESC 4A UBEC
http://www.hobbyking.com/buddy.asp?c...8-3EEC4E5B2D26
JXF 7x5 / 178 x 127mm Poly Composite propeller (2pcs/bag)
http://www.hobbyking.com/buddy.asp?c...3-85702A9CF8C8
APC style propeller 7x6-E
http://www.hobbyking.com/buddy.asp?c...B-8538971DA604
ddark is offline Find More Posts by ddark
Old Jul 08, 2011, 04:30 AM
Joined Feb 2007
HobbyKing Quadcopter Control Board Save US$: 5.75
vzgherea is offline Find More Posts by vzgherea
Discussion HK Buddy price for Kinetic 800 cornel4web Foamies (Kits) 6 Apr 27, 2011 11:09 PM
Discussion Nitro rcx coupon codes anyone? abletowinginc Hot Online Deals 4 Apr 21, 2011 11:37 AM
Question Any active coupon codes right now? beginnerRC-ist Hobby Lobby 0 Mar 07, 2011 12:30 PM
Discussion do futaba or hitec radios have their own special codes or signal codes? yurdakut Radios 1 Aug 18, 2010 04:18 AM
