Old Apr 26, 2011, 03:21 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
What's a good paint for Elapor foam?
Can anybody recommend a good paint for Elapor foam from Multiplex? (EZ Glider, Easy Star, etc.)
I used the Search function here, and found many people asking this question but very few replies.
Any suggestions?
Little-Acorn is offline Find More Posts by Little-Acorn
Old Apr 26, 2011, 05:07 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The Testors Plastic paints work very well with any foam. Lots of pigment so usually one or two coats does the job.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Apr 27, 2011, 05:09 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Any suggestions?
The best paint should be the newly developed paint for Elapor from Multiplex.
I also had good results with the mentioned Testors Plastic Model Paint and Tamiya Acrylic Colors.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Apr 27, 2011, 11:40 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Tamiya and Testors have worked well for me.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 28, 2011, 09:04 PM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
Do these paints adhere to elapor better than EPO? I have no luck with painting EPO. I prefer to leave them white.
restlessswind is offline Find More Posts by restlessswind
Old Apr 29, 2011, 05:48 AM
mk1spitfire is offline
Find More Posts by mk1spitfire
uk
Joined Oct 2007
I use the 'multi primer' first as this de-waxes the elapor surface,provides a key, ready for acrylic paint.
http://www.sussex-model-centre.co.uk...d.asp?id=19243
mk1spitfire is offline Find More Posts by mk1spitfire
Old Apr 29, 2011, 01:33 PM
Joined Jan 2010
Yeah, but that stuff hasn't been imported to the states yet.
Old Apr 29, 2011, 01:54 PM
uk
Joined Oct 2007
Could you not order yourself?
Or contact a multiplex distrubutor?
Old May 01, 2011, 07:07 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I use kyrlon short cuts and it works great... I do sand the foam lightly, but dont use any kind of primer...
dacaur is offline Find More Posts by dacaur
Old May 03, 2011, 08:20 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Gord.
+1.
Wiping down the Elapor with alcohol (and allowing it to dry completely-- only takes a few moments of course) will help with adhesion but the Testors paints stick quite well anyway. You may find that you have to touch it up after a couple hundred flights.
MRGTX is offline Find More Posts by MRGTX
Old May 03, 2011, 08:56 PM
Lammergier is online now
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
I tried to order the multiplex primer from the UK. It cannot be shipped to the US.
Lammergier is online now Find More Posts by Lammergier
Old May 06, 2011, 01:09 AM
Bone Breaker
Lammergier's Avatar
Joined Oct 2002
I have used plastic dip spray in light coats as a primer and it works well.
Old May 06, 2011, 05:52 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Multiplex Primer Ingredients
First, two things of note, as printed on the can are the words Highly flammable and Unhealthy! Considering what is in the can, I would say both statments are highly accurate.
Also to make perfectly clear, this Multiplex Primer is not a paint primer. What it does is 'prime' the foam by removing the surface wax/slickum to accept your primer coat and finish paint.
In English, from the can, the contents are:
toluene, xylene, isomere mixtures
I would expect that if you went to your local hardware store and looked in the paint department for paint remover, etc. you will find a can with same said components. However what the MPX ratio of ingredients are, I do not know. When you find what you are looking for in the hardware store, you may want to consider thinning the solution and then doing a test wipe on a piece of scrap Elapor. All you want to do is to use a damp cloth for this. Also, be in a well ventilated area and no smoking.
As for my experience with painting numerous MPX models and other foam models, no paint really sticks all that well. It is foam after all. However, the MPX Primer will prepare the surface far better than IPA and will enable the paint to better stick.
Stay away from paints that are made for Lexan bodies, as in the kind used for cars, buggies, etc. Testors, Model Master and Boyds will all work quite well, with Model Master being my first choice. I never did care much for the Kyron(sp) paints as some applied a little uneven and all added a good bit of weight to the plane.
HTH
Lou is offline Find More Posts by Lou
Old Apr 10, 2014, 12:42 PM
Squinton is offline
Find More Posts by Squinton
Joined Mar 2014
Hey guys. Can you use the primer on Z-foam? I ask because I have purchased the Multiplex clear coat and blue + primer for my Funjet, and was wondering if the clear coat could work to shine up my Stinson.
Also, the primers instructions are a bit worrying 'may warp parts, pin them down'. Is this a real risk? If so, how would one pin a multiplex funjet wing down without making a deep hole?
Squinton is offline Find More Posts by Squinton
Old Feb 05, 2016, 04:00 PM
T.A.Z is offline
Find More Posts by T.A.Z
Obsession, not hobby
T.A.Z's Avatar
United States, AZ, Phoenix
Joined Sep 2013
For me it's Krylon Short Cuts.
http://www.rcgroups.com/forums/showp...postcount=2378
T.A.Z is offline Find More Posts by T.A.Z
Latest blog entry: Hacker HotWing 750
Discussion I'm confused about paint on elapor foam merlinmurph Sailplane Talk 8 Jun 14, 2006 11:03 AM
Question What's a good foam to use for the "lost-foam" method Cziltang Brone Slope 25 Mar 14, 2006 10:51 AM
Discussion What kind of paint for elapor? Jeanseb Foamies (Kits) 0 Feb 15, 2006 05:46 PM
paint for elapor foam? tduro Foamies (Kits) 1 Feb 08, 2005 03:14 PM
What's a good paint to use for repair touch-up? ferradas Electric Plane Talk 0 Jun 30, 2002 01:51 AM
