Old Apr 26, 2011, 01:08 PM
Phaeton is online now
Find More Posts by Phaeton
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Build Log
Super Cub DIY lightweight Tundra Tires - v0.5
We (dijko and me) each are scratch building a 46" bush Super Cub, Piper PA-18 Super Cub, and also the Tundra tires are the result of some improvisation. Thought I could share here as well.
I used balloons, stretched over furniture foam, in this case 5 cm thick. Roughly cut and after that shaped whit a very sharp knife, while spinning (the foam) attached to a high speed drill. I used foam because I liked the tires to keep wobbly-ness.
The images below speak for themselves.
The balloons I used here were too small. They compress and malform the foam and it is difficult to get them both the same diameter. So, shopping for larger balloons then. But you'll get the idea.
The hubs are taken from Dubro's Tundra tires. Those tires are, however very nice, 100 gram each, way too heavy for this plane.
And the beauty of it all? They are 25 gram each... Water and dirt resistent and no air leaking out...
Yvo
Phaeton is online now Find More Posts by Phaeton
Old Apr 26, 2011, 02:01 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Very cool idea!
portablevcb is offline Find More Posts by portablevcb
Old Apr 26, 2011, 02:24 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I used a black balloon as a "leather helmet" for a doll head I made to pilot a Tiger Moth. It lasted 1 season before the rubber began to dry-rot and crumble. I think this is a great idea for a tundra tire, but make sure you build it so you can replace the rubber easily. You might even want to double up on the balloons to make it a bit tougher.
Has anyone thought of using "liquid rubber"? You could dip your foam doughnut in the liquid rubber and rotate it until it dried to prevent drips and runs.
warhead_71 is offline Find More Posts by warhead_71
Old Apr 26, 2011, 02:43 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Removing rubber is easy, scissors will do Yep, I thought of the double layer variant. But I have to get me new balloons first now... But somehow black balloons are more rubberish than the colored ones, this stuf is Trexler like.
Liquid rubber? Like this? http://www.smooth-on.com/. I'm going to have a look...
Yvo
Old Apr 26, 2011, 02:55 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I'm sorry, I meant "plasti-dip". I see it in the hardware stores... for adding rubber grips to tools, etc.
http://www.plastidip.com/home_solutions/Plasti_Dip
Maybe you could simply add Plasti-Dip over the balloon... so it acts like an inner-tube, giving you a smooth surface to start with.
Old Apr 26, 2011, 02:59 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Ah, already looking and Google-ing, thx
Old Apr 26, 2011, 03:28 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Found a European Plasti Dip distributor. I'll give the spray a try and apply/try both on the balloons and the plain foam. Perhaps some profile or 3D text on the tires when the stuff handles well...
To be continued...
Yvo
Old Apr 26, 2011, 03:39 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I just hope the spray stuff does not eat the foam.
Old Apr 26, 2011, 03:41 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
I have plenty of spare material, I'll try that first. Otherwise it will be dipping...
And when successful, the tailwheel will get a Tundra look as well...
Yvo
Old Apr 26, 2011, 03:56 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
By the way, I'm following the Peter Rake 1/6 Scale Albatros DVa thread: Beautiful job you did on the pilot.
Yvo
Old Apr 26, 2011, 04:09 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Thanks. I was just trying to make it worthy of the plane... that is quite a model.
Old Apr 27, 2011, 08:17 PM
FLYBOB54 is offline
Find More Posts by FLYBOB54
Closed Account
Joined Mar 2011
Don't blow the balloon up before you use it and it will last a lot longer. Talc helps too.
FLYBOB54 is offline Find More Posts by FLYBOB54
Old May 02, 2011, 03:42 PM
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Little update...
Can't get the foam smooth enough to get (that's a guess) the Plasti Dip on well enough to get the real Tundra look. The balloons are still an option as well, but I have to find the proper size first. Otherwise, it will be Plasti Dip with another kind of foam, more smooth to begin with.
But we're going to maiden the Cub first, see if and how it flies. Or crashes . In other words, see if there are any wheels left afterwards
But I'll find a proper solution, also for my next project, a Carbon Cub SS, completely build with carbon rods. At least the fuse.
Yvo
Old May 03, 2011, 08:26 PM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Very cool projects! Keep those posts coming, this is interesting.
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old May 05, 2011, 10:55 AM
tozovr is offline
Find More Posts by tozovr
Ninja-Exterminator
United States, ME, York
Joined Apr 2011
Maybe try memory foam?
tozovr is offline Find More Posts by tozovr
Discussion Large Scale Tundra Tires FlyingW Giant Scale Airplanes 180 Feb 14, 2016 08:29 PM
Found DuBro Tundra 5.5" Tires MinneFlyer Aircraft - General - Miscellaneous (FS/W) 0 Jun 28, 2010 07:21 AM
Discussion 1.2m Piper Super Cub - Tundra & Floats kiwilama Scale ARF/RTF 3 Apr 26, 2010 03:55 AM
Discussion Balloon (tundra) design tires for Elect. flight realtimerecon Product Announcements 1 Feb 15, 2009 11:39 AM
Help! Tundra Tires Jonas M. The Builders Workshop 7 Dec 26, 2008 10:20 PM
