Old Apr 26, 2011, 09:35 AM
ISPYFROMABOVE is offline
Find More Posts by ISPYFROMABOVE
Plane crazy
ISPYFROMABOVE's Avatar
USA, CA, Yucaipa
Joined Jul 2010
Help!
Help. Esky tandem coax
Ok. two things. This is my first coax. Esky tandem coax
http://www.rc-fever.com/esky-tandem-...th=337_177_689
I got it because my other heli is not indoor appropriate. I had it up and it flew well for the most part however... even with the elevator trim all the way back, i still had to hold some back elevator stick in order to keep it in a stable hover. It's almost like its nose heavy. Has anyone else had this problem and how did you fix it???
Also, somehow one of the flybars hit a blade and snapped about a third of the way in towards the rotor head. Is this just 1mm carbon rod that i can replace? Can i reuse the current shortend rod and just re-atach the weight and re-center it on the head???
Coming from a slightly more agressive heli this little thing is fun inside. So i would like to get it back in the air as soon as possible. Thanks.
ISPYFROMABOVE is offline Find More Posts by ISPYFROMABOVE
Old Apr 26, 2011, 10:28 AM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
Can the battery be moved back a little to help with forwards drift?
Never had a tandem, but would assume forwards and backwards movement is obtained by slowing down the front rotors and speeding up the rear, to dip the nose down for forwards movement and vice versa for backwards movement? If so, does the RX offer any adjustment here?
I also noticed from the pictures that the swashplate seems to be able to move, is this for lateral (sideways) movement?
Frank_fjs is offline Find More Posts by Frank_fjs
Old Apr 26, 2011, 11:01 AM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
The way the battery tray is designed, the battery can not be moved without cutting some of the tabs off. I'm not farmiliar with coax or tandem yet as i only got 2 flights on it so far. I suppose i could break down and read the manuel.... that might shed some light on the subject.
Old Apr 26, 2011, 11:11 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Please pay particular attention to the "lipo care" section
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Apr 26, 2011, 11:41 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That is the nature of tandem coax helis. If you change weight distribution, you are going to get really awful forward movement. Here's why. To move forward, the rotors tilt forward. See what happens when they both attempt to level. Of course, this is an exaggeration, but you should get the idea. To get decent movement from a tandem requires offset masts and movement biased to one mast.
Balr14 is offline Find More Posts by Balr14
Old Apr 26, 2011, 12:14 PM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
BALR
So fighting against the constant forward movement is normal??? i figured a stable hover for a tandem coax would be a no brainer
Old Apr 26, 2011, 07:06 PM
AH-64 D is offline
Find More Posts by AH-64 D
Springfield, VA USA
Joined Sep 2008
ISPYFROMABOVE,
Your Esky tandem looks like a 5 ounce knockoff of the 14 ounce Twister Skylift. As such, it should not be trying to plow ahead straight out of the box. Check to be certain that both of your swashplates are level.
AH-64 D is offline Find More Posts by AH-64 D
Old Apr 26, 2011, 07:33 PM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
AH
i will do that tonight.... any sugestions about the flybar, i dont have a spare but i'm not afraid to modify the existing one.
Old Apr 26, 2011, 10:00 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
A shorter flybar isn't going to hurt it.
Old Apr 27, 2011, 05:40 AM
AH-64 D is offline
Springfield, VA USA
Joined Sep 2008
Be sure to balance whatever flybar you create. Things can get crazy if it is unbalanced.
As for swashplates, power up the electronics so that the servos center. Power everything off and look at the swashplates - They ought to be perpendicular to their rotormasts. If one is not, make sure it has not popped apart, then adjust its linkage to level it. Power up and check to be sure it is still level.
Old Apr 27, 2011, 09:12 AM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
OK. so i now have a SHORT flybar now, but it's ballanced and i dont get any vibrations out of it. It now requires full back input on the stick to maintain a stable hover. I didn't have a lot of time to look at the swash plates or linkages, it was midnight when i finished the flybar. Slaped everything back together and noticed how hard it wanted to fly forward, and decided after a few drunken manatee flops that i'd fly my HBFP instead since it was trimmed out well. I'm going on vacation this weekend and i'll take the tandem with me to work on it.....
Old Apr 27, 2011, 06:24 PM
AH-64 D is offline
Springfield, VA USA
Joined Sep 2008
Esky has a reputation for selling products that require a lot of trimming to get them to fly right. have a good vacation and good luck with your tandem.
Old Apr 27, 2011, 11:31 PM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
OK...... tore it down while getting ready to leave. The front swash was WAY off. So i re-leveled it as best as my eye would let me. The battery is charging now so i'll know in a few.
Thanks for the help.
Old May 04, 2011, 04:24 PM
Plane crazy
USA, CA, Yucaipa
Joined Jul 2010
Alright. Back from vacation.... I needed it.
As far as the Tandem goes....... After leveling out the swashplates it flew much better. i was able to trim it to a nearly hands off hover. I had it up aboug 5' in the air buzzing around (It had only been up about 1-2 minutes) and the front of it dropped out of the sky like a rock, pulling the rest of in tow.
No damage to report, but I noticed that the lower set of blades on the front shaft are not spinning. Haven't taken it apart yet, has anyone ever experienced this befor. I've never had a motor just quit withoug warning, or could this be the 3-in1?
Old May 05, 2011, 09:30 AM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
I assume you checked the upper collar to make sure the screw did not back off. This issue is very common on a regular coax. This is the collar that sits just beneath the swash. If this is loose the shaft will drop down disengaging from the motor. Make sure the "B" gear is engaged with the pinion
Mike.
EDIT: Check your rotor head screws as well
Discussion Coax Help and Talk about Anything Thread frieslander Coaxial Helicopters 30882 Today 06:47 PM
Rave The official tandem coax thread THE_SHRUB Coaxial Helicopters 451 Aug 13, 2015 04:25 AM
Discussion Eflite tandem VS. Esky tandem BOTH COST $110 THE_SHRUB Coaxial Helicopters 7 Feb 09, 2011 12:34 AM
Sold ESky Coax Power Drive Parts elau Aircraft - Electric - Helis (FS/W) 5 Jul 13, 2008 12:13 AM
For Sale Esky Lama 2 coax! jive Aircraft - Electric - Helis (FS/W) 3 Feb 21, 2007 08:42 AM
