Old Apr 25, 2011, 10:05 PM
Ruskiflyer is offline
Find More Posts by Ruskiflyer
Joined Apr 2011
ParkZone P-15 Build
Hello Everyone
So I have decided to put together a P-51 Mustang using a Parkzone Airframe kit. Im going to install the following parts in it, please feel free to comment with warnings or hints:
For the Motor: TR 35-42D 1000kv Brushless Outrunner Link: http://www.hobbyking.com/hobbyking/s...idProduct=3884
Quick question here, what kind of mount adapter do you all think I should use with this motor, also what size prop?
For ESC: TURNIGY K-Force 40A Brushless ESC Link: http://www.hobbyking.com/hobbyking/s...p?idProduct=89
For Battery: ZIPPY 2200mAh 3S 11.1V 20C Lipo Battery Deans/EC3/TRAXX Link: http://compare.ebay.com/like/1905187...=263602_309572
For Servos: HexTronik HXT900 HXT 9g Servo Link: http://www.google.com/products/catal...d=0CD8Q8wIwAA#
I am a little worried about getting the engine on as I am not sure what kind of mount i am going to need to build or purchase, feel free to chime in with any hints or help.
PS: I forgot to ask if anyone has had any luck with the HobbyZone 6 channel transmitter and receiver. Please let me know if it is complete crap and what else you might recommend for its replacement that is still in the cheap area. Thank You!!
Ruskiflyer is offline Find More Posts by Ruskiflyer
Old Apr 26, 2011, 12:19 AM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
The motor, ESC, battery, and servos look good.
I use a Spektrum DX6i and a mix of Spektrum and Hobbyking Orange receivers. They haven't failed me yet.
For motor mounts, check this out: http://www.rcgroups.com/forums/showthread.php?t=1365616
BTW, not to be picky, but it's a P-51.
Edge767 is offline Find More Posts by Edge767
Old Apr 26, 2011, 12:24 AM
Joined Apr 2011
Wow, cant believe I did not see the earlier lol thanks for pointing it out Amy chance a mod can change the Title of this thread? Also I had two more questions if anyone can help:
1. When looking through the parts list for PZ P-51d i notice a Motor shaft: 480 Outrunner (PKZ4418) and a Control Horn Set: P-51D BL (PKZ1823). My question is Does anyone know what those are used for?
2. For the Motor Shaft, am I going to have to buy one for my new motor as well, or is this something the motor ships with?
Old Apr 26, 2011, 12:47 AM
Edge767 is offline
AMA 52726
Edge767's Avatar
Joined Jun 2005
Motors come with the motorshaft. They sell replacements for those who prang 'em into the ground and bend them. Then, you can replace the shaft in the motor without replacing the entire motor.
As for the control horn set, I don't think you need that with the fuselage kit. Control horns are used to attach servos and servo wire to the control surfaces. They should come with the fuse kit.
Old Apr 26, 2011, 12:50 AM
Joined Apr 2011
Thank you for your response. I will be adding pictures once I get this project started. I also want to do a landing gear mod, a saw a few different ways to do this so that will be my first addition after the maiden trip. One last question i wanted to stick a bigger prop on it as well, I was looking at a 10X6, is that okay for a 1000Kv brush less motor?
Old Apr 26, 2011, 01:16 AM
Edge767 is offline
AMA 52726
Edge767's Avatar
Joined Jun 2005
I'll let someone else answer the prop question. I think it should be okay, but let's hear from one of the experts around here.
Old Apr 26, 2011, 11:05 AM
Joined Apr 2011
Ok thanks for your input anyway Ill try searching through the 600 page p-51d post again to see if i can find something about this.
For Sale Trade: New Parkzone Bf109g PNP for Parkzone P-47d ... hcsk8ter Aircraft - Electric - Airplanes (FS/W) 2 Apr 18, 2011 02:35 PM
Wanted Parkzone Habu or Parkzone p-47 fishon2 Aircraft - Electric - Airplanes (FS/W) 0 Mar 28, 2011 11:29 PM
Discussion Parkzone bnf p-47 with 15 power! DeaninMilwaukee Parkflyers 0 Nov 06, 2010 09:46 PM
Discussion ParkZone P-51D Mustang build questions Jet Freak Electric Warbirds 7 Feb 25, 2007 08:00 PM
