Old Apr 25, 2011, 07:43 PM
Aleriance is offline
Find More Posts by Aleriance
Joined Apr 2011
Question
Clear some things up for me? (Batts & Motors)
Hey everyone I have a huge topic that I don't understand... BATTERIES AND MOTORS.
I did read the complete guide on Li-Pos but I still need some clearing up.
Where do I start?
1) Does increasing voltage increase your vehicle's top speed? Is this a good idea?
2) If "C" means discharge rate of a Li-Po, Would a lower "C" last longer during drives or did I misunderstand?
3) "S" represents the number of cells in a Li-Po?
4) The higher the mAh, the longer run time?
5) What are Kv in a motor?
6) What does say "20T" mean in a motor?
(I drive RC buggies)
Any explanations would be greatly appreciated. Thank you all so much.
Aleriance is offline Find More Posts by Aleriance
Old Apr 25, 2011, 09:45 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
1) Does increasing voltage increase your vehicle's top speed? Is this a good idea?It increases the power going to the motor. Make sure both the motor and ESC can handle the increased voltage
2) If "C" means discharge rate of a Li-Po, Would a lower "C" last longer during drives or did I misunderstand? No, the C rating is how much theoretically the battery could handle, ie : 1000mah lipo with a 30C rating can be expected to deliver up to 30amps...but these C ratings are rarely completely accurate, so always get a little higher then you need
3) "S" represents the number of cells in a Li-Po? Represents the number of cells in series, as opposed to parallel (determines the voltage of a cell, 1s=3.7v 2s=7.4v, etc
4) The higher the mAh, the longer run time? Yes, but increased weight
5) What are Kv in a motor? Determines rpm of motor
6) What does say "20T" mean in a motor? No idea
RedStarArmy is offline Find More Posts by RedStarArmy
Old Apr 25, 2011, 09:51 PM
mdh1979 is offline
Find More Posts by mdh1979
Joined Jul 2010
6. The number of turns in the windings.
Matt
mdh1979 is offline Find More Posts by mdh1979
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
20T = 20 turns
This is the number of turn of copper on each tooth on a motor. In general the higher the turn the lower the KV.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Apr 25, 2011, 09:52 PM
jkettu is online now
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Edit: nevermind, I'm slow to type and better answer was already given above.
jkettu is online now Find More Posts by jkettu
Old Apr 25, 2011, 10:55 PM
elecfryer is online now
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
Where do I start?
First off, welcome to RCGroups! Also happy to see that you are reading various threads. There is also a "search" feature that works pretty good.
1. in general motors have "kv" ratings. For instance, a motor with a "kv" of 1000 will (with no load, i.e. just the shaft turning and nothing attached to the shaft) will turn at 1000 rpm for each volt of electric that gets to the motor. If 2 volts get to the motor then 1000 X 2 = 2000 rpm. When you add more voltage you get more rpm. There is however, a limit as to how much "power" a motor can take in and put out AND still be efficient (say 80% efficiency or better). A good electric setup is all about matching the components to the job. I am not a rc car person however there must be some good set up info in the car section.
2. Lets say you drive your car for 10 minutes and the battery is completly discharged, what is that average discharge rate? LiPo's are rated in Ah (Amp Hours) and there are 60 minutes in an hour. 60 / 10 = 6 or the avg disch rate is 6C. With 2 batts of the same capacity but different "C" ratings, they should last about the same amount of time however as they are getting low on power the higher C rated battery may heatup less since it probably has lower internal resistance and since it will loose less power due to lower internal resistance, it may run a little bit longer and hold/output a higher voltage towards the end as compared to the lower C rated batt. WARNING! just because a mfgr says their batt is a "25C" rated batt does NOT guarantee that it is! Check for reviews of the batts that you are interested in!!!!!
3. See post #4.
4. Think of amp/hours as gallons of gasoline. 1 Ah, 1 gallon. 2 Ah's, 2 gallons. The more gallons you have the longer you can run and as posted above more amp hours means a bigger battery that will weigh more and may or may not fit in the space available!
5. See #1, above!
6. no comment!
Sorry for being long winded! Hope I helped!
Michael (if your not fryin, your not tryin!)
elecfryer is online now Find More Posts by elecfryer
Old Apr 25, 2011, 11:31 PM
omnicomps is offline
Find More Posts by omnicomps
omnicomps's Avatar
Joined Aug 2008
The last buggy I had got upgraded to a 15T double motor. I belive it was a 550 size and was brushed. That means there is 2 wires instead of 3(brush less). It was pretty quick off the line and had a decent top speed. If you want all out top speed you could go for a 12Turn double but make sure your speed control can handle the higher rpm. You also don't want to run a lipo on a speed control that is supposed to have a nicad or nimah battery. You can but risk not only frying your speed control but toasting your lipo. You don't want to take a lipo under 3.0v per cell(that's the S.) If you discharge the lipo to low it will stop working. Not sure how much you know about this stuff so hope I am not being presumptuous. If you want a buggy that is going to do 70mph+ you want a brushless motor, brushless speed controll, and a 3s1p 11.1v 4000mah 30c lipo. You also need a lipo charger to be able to charge the lipos. Hobby king has some realy good deals if you don't mind paying a little bit for shipping.
omnicomps is offline Find More Posts by omnicomps
Discussion Okay time to change things out, need some opinions sherlockshah Electric Ducted Fan Jet Talk 31 Mar 24, 2011 09:25 AM
Discussion Can someone recomend some motors for my quad? djdaveq Multirotor Talk 4 Mar 12, 2011 08:24 AM
Discussion Can someone clear this term up for me? mcharles13 Electric Plane Talk 14 Jun 29, 2006 06:09 AM
Discussion Clear this up for me rampman Batteries and Chargers 13 Mar 29, 2006 12:27 PM
Yippee! I'd like to clear things up... sp32 Parkflyers 41 Dec 31, 2004 11:13 PM
