Joined Jun 2007
I am working on a flying site, the scenery is at California Halfmoonbay.
Panorama image is provided by Harald. Half Moon Bay is located at WikiMiniAtlas37°27′32″N 122°26′13″W / 37.458840°N 122.436848°W / 37.458840; -122.436848,[2] approximately 25 miles (40 km) south of San Francisco, 10 miles (16 km) west of San Mateo, and 45 miles (72 km) north of Santa Cruz. Neighbouring towns include Montara, Moss Beach, and El Granada to the north and Purissima, San Gregorio, and Pescadero to the south. This is the first "Flying site" which I make, and have no idea about the distances and sizes of relevant objects. Only the average size of trees might help. The test version of the Flying site is "ready" at least it is a good slope gliding scenery, the uplifting wind speed is 2 m/sec. There is a start position for watercraft and heli, but four for fixed wing, one of those is on the remote road, in front of a hill. If you have time please assists the construction, for several reasons. I would like to complain at Phoenix Support about the water management of the Creator and the simulator. I need your help: 1. To locate this site better if possible. 2. Test the Flying site, if sever bugs can be found I might repair. 3. If any of you have experience with water editor or wish to play with it, and try to find the solution please send me an e-mail or PM. At present the water quality is "low" because the water was "clear"-ed. The water level is at -32 m. May be this is the reason that I can not manage the water editor properly. http://members.iif.hu/laszlo.csaba/Peninsula.zip |
Hamburg
Joined Mar 2004
Looks good, some issues:
- sometimes the plane could penetrate a rock on left hand side. - strange: The shadow disappears on water in left regions and the plane crashes before the shadow is at the same level as the airplane. - Comparing to the methods I used for Reflex the thermal lift looks very unrealistic for a slope soaring scenery. Where is the downwind downwash? Can you send me your pxq? Here is a testflight I made: http://youtu.be/TsK9kvJZbBg?hd=1 |
Joined Jun 2007
I would like ask all of you to make some more tests. It is not the question of proper testing by me, as you will see there are some basic problems. I will publish the PXQ but after the correction of the trivial mistakes. To keep track of the development I will assign version numbers to the flying sites and make projects for each version. To explain some effects, I would like to ask You to make some more tests. 1. Make a video using Aerobatic Slope Soarer, at Coutriside Hill. 2. Make a video using Slope Soarer at Peninsula. 3. And just for fun, using Beast and Motebello Castle (official) fly acros the hill (use binocular) under the surface. NOW proceed step by step. You said: "The shadow disappears on water in left regions and the plane crashes before the shadow is at the same level as the airplane." This effect was noticed by Puzom while we made Tortuga. This is a bad feature of the Simulator (not the Creator). This is the "double shadow" effect. (I am going to complain about this at Phoenix) There is a shadow on the water surface and a second on the object below the water. It is disturbing if that object is a plane or a h-map. Here the water quality is "low" therefore there are no shadow on the water surface, (I consider this as a bad feature of the Simulator) but there is on the surface of the plane below the water. What You see is the shadow on a "plane" at 5 meters below the surface. Now this is a design decision. 1. If the plane is deleted, no shadow at all. 2. If there is plane about 1 metre below the surface, there will be shadow, the effect will be less noticeable as before. NEW Part: I have tested this solution and it is almost good. The shadow is almost realistic, the watercraft can start, only some debris at crash remain on the surface. 3. If the plane is less than 1 meter (who knows exact figure) the shadow might be realistic, but the crashing model might not sink, and the start position will be bad, the model will be jumping. At present in my new version there is no plane, but you can have an other decision. OTHER: Could you send me a screen shot of the penetrating model? I will work now on a problem which is not very nice. This is the Montebello Castle effect. You can fly below the pilot, and so far my solutions to overcome this are not working More over if the plane is removed, one might fly down to the infinity behind the hill and might do the same if over the 1 square kilometre water surface. I had to test this now. I will explain the uplift business in my next comment, as short as I can, otherwise this might be a novel. |
Thanks for the new fields guys! Nice to see new stuff is still being created. Sadly bit busy now myself so not much PhoenixRC creations from me.
Cheers! ------------------------------------------ Feel free to make a donation for my Phoenix R/C work: https://www.paypal.com/cgi-bin/websc...NonHostedGuest ------------------------------------------ |
Joined Jun 2007
Peninsula is ready.
http://members.iif.hu/laszlo.csaba/Peninsula.zip Info can be found at Readme.txt |
Joined Jun 2007
I had to make a new version. I would appreciate very much if some of you can test it, and point to the problems, perhaps can be corrected. There is a new surface at the left side, and by chance I got a small patch of "high" quality water, the usage of it can be found at Readme.txt. http://members.iif.hu/laszlo.csaba/PeninsulaM.zip |
Joined Jun 2007
It seems to me that you are not very enthusiastic about slope gliding sites.
The final version is ready, thanks to EPPfor FUN. He could provide to me the blueprint of ReflexXTR simulator scenery: Peninsula he has made, and a test video. By this way I could make a reasonable flying site. The power of Reflex is higher than that of Phoenix, at least in this respect. Video:
The download address as usual: http://members.iif.hu/laszlo.csaba All previous versions are deleted. |
Joined Jun 2007
If I see the equirectangular image I might tell you what is the problem. Phoenix for me is not responding at all. Now I (we) are considering to write them, because at the course of Peninsula development great many defficiences of the Creator and simulator became clear. On the other hand if you download our Tempelhof flying site, (see my download adress) or homepage of EPPforFun: http://www.szenerien.de/ you can see the runway there. If you wish I can send you the PXQ, and having the Flying site "high" folder you can see the runway at Creator |
Joined Feb 2009
RCRC Phoenix Creator Files
Harold and Laszlo,
I did look at your Templehof site and it looks "similiar" to my flying site. Here is a url to my server. All of my Creator files are contained in the zip file. Thanks for the help! Fred http://fth.bounceme.net/rcrc.zip |
| Thread Tools | |
| Alert flying site | RCShop | Slope | 4 | Mar 20, 2011 10:35 AM |
| Discussion Phoenix-new flying site MVC | upnover | Simulators | 0 | Feb 15, 2011 08:58 PM |
| Discussion Virgin Flying Site Checklist.... | SENTRY 62 | Video Piloting (FPV/RPV) | 32 | Jan 03, 2011 09:47 PM |
| Question How does one make a flying site in Phoenix Creator? | spagoziak | Simulators | 3 | Jul 19, 2010 10:23 AM |
| Discussion Put your flying site on Phoenix sim | McKrackin | Electric Heli Talk | 0 | Apr 28, 2010 02:08 AM |
