Old Apr 24, 2011, 07:25 PM
purcilas is online now
Find More Posts by purcilas
Team PAS
purcilas's Avatar
United States, MD, Bowie
Joined Mar 2011
Question
Ametek 1726 Tachometer
Does this tachometer work for R/C planes? I bid $25 on it on eBay just for un and ended up getting it for $22!
purcilas is online now Find More Posts by purcilas
Old Apr 24, 2011, 08:38 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Appears to be a usefull tool
http://www.chatillon.com/Our%20Produ...1726_tach.html
rick.benjamin is offline Find More Posts by rick.benjamin
Old Apr 24, 2011, 11:38 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
It will work but you probably will have to do a little math like dividing the reading by the number of propeller blades to get the actual propeller rpm.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Apr 25, 2011, 11:04 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Thats a contact tach, and also uses reflective tape to "see" RPM's.
Its a craap shoot if it will work with a prop against a well lit background.
I have tried several different makes, no joy with contact, and you ruin a props balance using a "stick on" piece of reflective tape
moparmyway is offline Find More Posts by moparmyway
Old Apr 25, 2011, 12:34 PM
Team PAS
purcilas's Avatar
Joined Mar 2011
It says its for "contact and non-contact measurement".
Old Apr 25, 2011, 01:00 PM
moparmyway's Avatar
New York
Joined Jan 2009
I understand.
Contact : If you try the contact tips, you will burn them up and also burn your shaft on higher kv motors
Non-contact : If you try a prop, you might be forced to stick on a reflective tape so the photosenser reads a revolution. This tape brings a perfectly good prop into an unbalanced situation, and you dont want to get RPM's off of an unbalanced assembly.
Old Apr 25, 2011, 01:36 PM
Team PAS
purcilas's Avatar
Joined Mar 2011
So what tachometer do you recommend I get for R/C plane? Ill pay for that one from eBay and resell it.
Old Apr 25, 2011, 01:43 PM
moparmyway's Avatar
New York
Joined Jan 2009
I reccomend any one or both of the following;
1. ICE ESC's
http://www.castlecreations.com/produ...oenix_ice.html
2. Eagle Tree data recorder
http://www.eagletreesystems.com/MicroPower/micro.htm
Old Apr 25, 2011, 02:18 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
I have been assuming the RPM readings from the Ice is fairly accurate since the ESC must know the RPM for timing etc. Is this a safe assumption? Or should I take it with a grain of salt as with the other measurements like amps?
crypto666 is offline Find More Posts by crypto666
Old Apr 25, 2011, 02:22 PM
moparmyway's Avatar
New York
Joined Jan 2009
There isnt anyone out there that I have ever heard or read of, that disputes the accuracy of the ICE for RPM readings. Including myself.
Old Apr 25, 2011, 04:16 PM
USA, NV, Caliente
Joined Mar 2009
Good deal, thanks.
I would get the meter and hang on to it if it works. The problem with buying a new piece of test equipment that isn't proven is that you have to have another instrument taking the same readings to get any confidence that it is correct.
What are people using for a tachometer? The Other Dave Power Systems 19 May 02, 2002 12:15 PM
Measure Head Speed with Cycle Tachometer wayne Electric Heli Talk 1 Mar 08, 2002 11:38 AM
looking for a good Tachometer! aerogel Electric Ducted Fan Jet Talk 2 Jan 09, 2002 06:08 PM
Tachometer and KP44 nbrophy Electric Ducted Fan Jet Talk 1 Sep 22, 2001 03:32 PM
What is a good Tachometer? Red Baron 47 Electric Plane Talk 3 Aug 05, 2001 03:59 PM
