This thread is privately moderated by leccyflyer, who may elect to delete unwanted replies.
Old Apr 24, 2011, 05:11 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
BC#006 - Cambrian Bf109E
Aircraft Name: Messerschmitt Bf109E
Manufacturer/Designer: Cambrian Models
Type: Sports scale fun0fighter
Construction: Veneered foam wing, balsa/ply built up fuselage, sheet balsa tail
First Flight: Warrington Mode Club, 2nd June 1996
Wing Span: 42"
Wing area:
AUW:3lbs 4 oz
Power type - Glow 2-stroke, converted to brushless electric
Motor: Enya .25SS replaced by AXI 2820/10
ESC: Model Motors 40-3p
Tank/Battery: 6oz Slec - 10xCP1700s
Propeller: 10x7" APC-E
Receiver: Hitec
Flight Pack: Futaba 4.8v 110mah NiCd
Servos: Aileron (torque rods) - HS85BB, Elevator (snake) - HS85BB, Rudder (snake) - HS80, (Throttle - Bowden cable - HS80)
Throws -
Undercarriage - n/a
Accessories: Perkins 1/9th scale Luftwaffe latex pilot
Covering: Tissue and dope with airbrushed Humbrol enamels
Current status: In for maintenance - motor swap.
leccyflyer is offline Find More Posts by leccyflyer
Old Aug 07, 2014, 01:13 PM
Sloping off....
leccyflyer's Avatar
Joined Sep 2000
So, the Cambrian Bf109e is undergoing another transition. Having successfully made the leap from Enya .25SS power to AXI 2820/10 brushless electric, she's about to try her luck as a PSS slope soarer. I was so impressed by my new clubmate Derek's Cambrian Spitfire, operating off the slope on Sunday, that I reckon that the Spitfire needs some company.
The motor, esc, switch harness, motor mount are all removed, the spinner is having some holes filled with epoxy and microbaloons, ready to take some ballast and a new 2.4ghz receiver and battery pack is lined up to go in. Pictures to follow.
Question BC-6 charger Flying glass Batteries and Chargers 2 Mar 10, 2011 05:23 PM
Discussion Cambrian Mistral, Petral & Merlin davewindymille Vintage & Old-Timer Designs 1 Mar 05, 2011 04:26 AM
Discussion GWS CN12-R-XC motor and Jeti JES 006 ESC pflumitch Power Systems 2 Feb 23, 2006 10:26 AM
GWS 350C and Jeti JES-006 combo problem RCFlyer55 Power Systems 3 Jan 09, 2005 09:33 AM
GWS Bf109E or Flying Styro Bf109E? The Max-Q Parkflyers 13 Jun 02, 2003 05:13 AM
