View Poll Results: Model platform
Delta 89 57.79%
Non Delta 65 42.21%
Voters: 154. You may not vote on this poll
Old May 06, 2011, 03:44 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Hi Von W. Can I get you to try chaning the wing a bit, just an experement. Here is a pic. of the wing.
frank40 is offline Find More Posts by frank40
Old May 06, 2011, 04:49 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
traditional design
the numbers look very good Frank and I like your airfoil. I would say let's try it.
I too would like to see more of Boredom's design. the only thing I recommended is to change the aspect ratio of the wing, so that it's a more swept back design. straight out like that is great for slow landings and takeoffs, but not so great for high speed flight since it doesn't fit inside the bow wave created by the nose. as I had said, it looks very much like a Mig 23 or a Tornado with the wings fully swept forward. it would look much better in a position more akin to the mid sweep point of those airplanes mentioned. like this..............
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old May 06, 2011, 05:11 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I'll be posting as I am learning a lot from you guys. I just haven't really had anything new.
I won't use any units as this is still completely arbitrary. The root of the wing panel is 227. The total distance from leading edge to trailing is 297.4. The wingtip is 86.5. The distance from the root to the tip is 372.2.
Would the aspect ration be 372.2/227, or would it be 372.2/297.4?
It would be best if someone could just modify my pic below. I understand what is being said. I just do not want to cause more negatives than positives. (if you get what I mean)
Also how would you know where the bow wave on a model like this would be?
boredom.is.me is offline Find More Posts by boredom.is.me
Old May 06, 2011, 05:21 PM
Joined Jan 2009
traditional wing
here's something along the lines of how my wing would look on your fuselage.
Old May 06, 2011, 05:22 PM
Joined Jan 2009
perhaps a little more shaped on the tip section, to make it look more sweeping and faster.
Old May 06, 2011, 05:37 PM
Joined Nov 2007
Is there any particular airfoil?
Old May 06, 2011, 10:12 PM
Joined Jan 2009
I think airfoil choice is much less critical than other parameters. as long as it's a symmetrical section, or a very challow semi-symmetrical section, you should be ok. if it were me, I would choose a symmetrical one though. there are many to choose from in the NACA library, but any of the 000X sections should be ok. ie: 006,007, 008, etc. if you get the basic version of Profili, there are many sections to choose from. hope that helps.
Rich
Old May 07, 2011, 03:12 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Glad to see you still with us Boredom. The last pic. posted by Rich looks awsome and then some. Reg. airfoil I would goe for sometihing like PW51, PW75, or you could try mine. If you use a symmetrical airfoil you will need a little nouse op when flying, in order to fly level.
Old May 07, 2011, 01:10 PM
Joined Jan 2009
or some wing incidence. either way, you are scrubbing some top speed I think. this is why I also suggested a shallow semi-symmetrical section. by shallow, I mean not quite symmetrical, but almost. this will give you the advantages of a symmetrical, but with the extra lift capability of a semi-symmetrical. I think your airfoil might work well in this planform Frank.
Old May 07, 2011, 03:41 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi Rich
I tryed to google "shallow airfoils" but this dose not give me any results. Do you know some airfoils like that, I would like to do some simulations on them.
Frank
Old May 08, 2011, 02:02 AM
Joined Jan 2009
not sure how to describe it, other than to say that it's any airfoil that almost looks symmetrical, without being totally symemtrical. imagine a NACA 006 foil being slightly flattened on the bottom, to not look quite symmetrical.
Old May 08, 2011, 05:19 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Hey B.I.M,
Question 1: Aspect ratio is (span^2 / wing area) for wings that aren't constant chord.
Question 2: There is no bow (shock) wave on our models as we're no where near mach 1. For us, the less sweep, the better. That's why the pylon guys, DS guys, anyone who does real speed has straight wings. Sweep is all about looks (until you get to around 45-50 degrees - then it's a delta, and a different kettle of fish)
LE7 - something like the 1306?
Odysis is offline Find More Posts by Odysis
Old May 08, 2011, 10:32 AM
Joined Nov 2007
?1: Thanks
?2: I knew I wasn't crazy.
Old May 08, 2011, 11:22 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi there
Boredom: I notes that in one of your posts you wright" I just do not want to cause more negatives than positives. (if you get what I mean)" I don't get it?
It's sound like you will back out of this thread, please don't. Jump right back into our playground and poste all you want.
Rich: Ok... thought it was a type of airfoil that I did't know of.
Old May 08, 2011, 11:32 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Right on again! What looks fast on a model ( sharp noses and swept wings) in many cases is actually slower.
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Question Rc jet boat build HeliFried Racing Boats - Electric 126 May 20, 2011 05:05 PM
Question Rc Group App Clavin01 Site Suggestions / Complaints 1 Apr 14, 2011 09:02 AM
Discussion Newbie on RC Group's PhoenixFlyer Classic Pattern Flying 15 Apr 09, 2011 08:05 AM
Sold Blitzworks RC F-14 Jet thedeuce Aircraft - Electric - Jets (FS/W) 0 Mar 06, 2011 09:36 PM
