View Poll Results: Model platform
Delta 89 57.79%
Non Delta 65 42.21%
Voters: 154. You may not vote on this poll
Old Apr 29, 2011, 11:43 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
the red and white plane It's nice, but it has allready been done. Rich can u make a quik drawnig of your idea for the inlet, not sure I follow u. Here a thourgh..... Lets make the inleet area the same as the outleet!
My thoughs is..... If the inleet is bigger than the outleet the airspeed at the inleet is slower than the outleet, and this can act like a break. please comment.
frank40 is offline Find More Posts by frank40
Old Apr 29, 2011, 03:57 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Check this one out. It's somebody elses idea, but a pretty neat one if you ask me!
http://www.ikeaerospace.com/
Steve C is offline Find More Posts by Steve C
Old Apr 29, 2011, 08:00 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
delta mod
hey Frank
I've modded your last drawing, so you can see the changes I would make. first of all, I slightly increased the LE rake of the canards. secondly, I norrowed the fuse and added the coke bottle shape to area rule the fuse. thirdly, I increased the aerodynamics of the cockpit, by sharpening the rear edge and also narrowing the turtle deck. if you look at the bottom view, you'll be able to see what I mean by recessing the intakes within the sides of the fuse, therefore narrowing the frontal cross section and reducing drag. it's a rough drawing of course, but the intake area and the exhaust area are roughly the same.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Apr 29, 2011, 08:32 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Originally Posted by frank40 View Post
Hi Kevin. Itís looks like you model performs nicely and handles low speed to, what kind of airfoils do you use.
Thanks Frank,
I used the MH23 airfoil with 2-3 degrees of washout.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Apr 29, 2011, 08:42 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Thanks for informing me guys. Still learning. Heck, this is even what I am going school for.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Apr 29, 2011, 08:55 PM
Joined Jan 2009
you'll learn all about area ruling then. believe me!!!!!! LOL. the coke bottle shape is much more slippery than a straight or cigar shaped fuselage, especially for a delta planform. at our speeds, I'm not sure that it would make a huge difference for sport flying, but it might make a difference for guys entering speed contests with high power setups. the biggest advantage to sport flying is that it just looks plain sexier than a straight line.
Old Apr 30, 2011, 03:59 AM
Von W is offline
Find More Posts by Von W
Von W's Avatar
BelgiŽ, Vlaams Gewest, Scherpenheuvel-Zichem
Joined Aug 2000
Originally Posted by LuvEvolution7 View Post
is it just me, or does the red and white plane kinda look like the offspring of a Mig 21 and a Saab Draken? LOL.
haha, It's not the first time I get this comment, for the draken you are wrong but for the Mig you've got it wright on one detail. Actually it's based on the first drawings of a design Willy Messerschmidt did for the Spanish air-force in the early fiftys. The P300 it never made it to construction in spain but in Egypt they have build a few prototype's but they looked completly different.
the model was my first turbine jet and I don't wanted to use a thrust-pipe so I moved the turbine to the back of the plane. therefore the wing was also moved farter backwards because of the CG. Then I made a little foam model and the testflights showed that the for stability reasons the vertical fin had to be enlarged. An bigger fin looked a bit silly so I took the little fin under the fuselage from a Mig21.
LuvEvolution7
Today 12:42 AM
That's wy I took the sexy fuse from a Mirage2000, but I wanted a more classic wing set-up. The first wing was a little swept back and looked not bad but then I took the wing and stabiliser from a F100. The design is already a few years old and was well advanced but never was build, it still wanders around in my head but now I would build it with a decent EDF instead of a turbine.
Von W is offline Find More Posts by Von W
Old Apr 30, 2011, 07:33 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi there
Rich. I realy like what you have drawn, it's the way to go.
Von W. I realy like your mix of Mirage and F100 looks awsome, did you draw it your self.....That means you have cad skills
Steve C. Well never seen that before but it's to special if you arsk me.
Kevin Cox. It seemas that this profil preforms verry well.
Can't get the sideprofile right on the mod. Rutan ARES, can I please get some help.
Mayby it's time to deside on the model???, any thourghts.
Old May 01, 2011, 03:43 AM
Von W is offline
Von W's Avatar
Joined Aug 2000
Hey Frank40, and of course all the others,
Yes I did draw it myself, indeed, it means that I have some CAD skills but I'm certainly not a professional designer and I use them almost exclusively for designing my planes.
I also like the looks of the Mirage F100 a lot but one of the reasons I never built it is the highly swept wing. Do you know the famous Huckebein?
Well I designed and flew three of theme, they flew but they were very tricky to fly. One reason is the position of the exhaust it is very low compared with the CG, it means that you have to be very careful with the power if you are flying slowly because it pushes the nose up instead of getting some speed. If you didn't cut the power quickly it comes to a spin and I never recovered a Huckebein from a spin . Of course this is not a problem with the Mirage F100, What you often see with those highly swept wings is that they wobble when flying slowly and if you roll the planes it looks often like a barrel roll.
I like to fly my jets very low and very fast with some big loops and slow rolls so they have to listen tight to my control inputs.
Maybe it's just me but I'm a bit scared that with this wing it's not ideal
Old May 01, 2011, 04:42 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi Von W
If I may suggest a small chance in your design, I would offset the stabilizer to minimize the interference from the main wings.
I think your cad skills are awesome.
Reg. your Huckebein. I think the problem was your thrust line, I would think it had to have a bit down thrust, because of the high point of mass in the vertical axel and then trimmed for straight flight.
Old May 01, 2011, 06:05 AM
Von W is offline
Von W's Avatar
Joined Aug 2000
thanks for compliment frank,
The past few years I did not much about designing modells my last bigger design I made was a foam DC-3.
http://www.rcgroups.com/forums/showt...ghlight=skybus
I know about the thrust line and if I would build a new huckebein I would built it with some down thrust. I still like the design but for now I've had it with the Huckebein, my last one still survives as a nice static modell .
About the Mirage F100, I quickly put some negativ dihedral in the stab to get a little offset.
The second option is this
Personally I prefer the first one
Old May 01, 2011, 06:48 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi Von W
I realy like your cad work, very nice jobs. Yes moving the stabs. up looks just great Hope that's ok that I come with suggestions for changes.
Old May 01, 2011, 08:09 AM
Von W is offline
Von W's Avatar
Joined Aug 2000
Hi Von W
Sure it's ok, it maybe encourage me yet to begin the construction
Old May 01, 2011, 03:39 PM
Kevin Cox's Avatar
Joined Jan 1997
Frank, here is my help on the side view. I tried to keep the vertical close to the original.
Old May 01, 2011, 04:15 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi Kevin. That looks awsome love your tail (don't get me wrong) thanks. Maby I will make the nouse a bit slimmer, hope u don't minde.
Question Rc jet boat build HeliFried Racing Boats - Electric 126 May 20, 2011 05:05 PM
Question Rc Group App Clavin01 Site Suggestions / Complaints 1 Apr 14, 2011 09:02 AM
Discussion Newbie on RC Group's PhoenixFlyer Classic Pattern Flying 15 Apr 09, 2011 08:05 AM
Sold Blitzworks RC F-14 Jet thedeuce Aircraft - Electric - Jets (FS/W) 0 Mar 06, 2011 09:36 PM
