View Poll Results: Model platform
Delta 89 57.79%
Non Delta 65 42.21%
Voters: 154. You may not vote on this poll
Old May 20, 2011, 01:08 PM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Originally Posted by LuvEvolution7 View Post
on the bottom...................I would say no Frank. it could if designed properly, but most aircraft are fairly flat along the bottom. as long as the fuselage is expanding, the boundary layer remains thin and attached, due to the increase in pressure. think of it like an airfoil..............the air flows over the top surface and the pressure builds. boundary layer is laminar and thin, but as we get to the peak of the curve, the pressure reduces slightly and the boundary layer starts to thicken and detach, especially as AOA rises. kinda the same thing with a fuse too. pressure builds as the body expands and then tapers towards the rear. for a NACA inlet to work properly, we've got to place it at a point where this pressure is at it's best potential to recover in the duct.
I think if it's on the top there's a real risk that you won't be able to ingest enough airflow to the fan. Especially so in any form of high alpha flight (a sharp turn, for example). The NACA inlet, whilst low drag, is already at the disadvantage of having almost no ram effect, which is why it isn't used for jet intakes on full-size aircraft - only for ventilation / cooling flows, combine this with the flow wrapping up around the cylindrical fuselage and you'll struggle to get a useable amount of air on the upper side in normal flight. In high alpha, you have twice the problem in that the intake is now shielded from the airflow by the fuselage.
The 'hybrid' type of intake, sticking out a little, will of course help, but I think placement is going to be crucial.
SMorrisRC is offline Find More Posts by SMorrisRC
Old May 20, 2011, 01:11 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Bd5
I'm looking at the 3 view of the BD-5 and if you notice, the NACA inlet starts just after the fuse starts to narrow again. I've checked this against better drawings/photos and it appears that this 3 view has the inlets a bit too far astern. photos show the inlets to be at the point where the fuse is the widest.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old May 20, 2011, 01:13 PM
Joined Jan 2009
I agree. if it's on top, we're going to get into all sorts of aero issues. if we're going to use a hybrid intake, it's got to be on the side, or the bottom. if it's on the bottom, it's got to pitot style only, as I doubt a NACA inlet will do any good. if we go with a bottom design, we could always neck up the fuselage a bit, to minimize cross section.
Old May 20, 2011, 01:15 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Thanks again.
Got it now(slow learner)
If the looks of the model may be a bit od. I think I have an idear to help the NACA duct handling AOA. My idear is to have it as in/or clouse to the nose, split it op in two parts- one on top and one on the bottom.
frank40 is offline Find More Posts by frank40
Old May 20, 2011, 01:19 PM
Joined Jan 2009
intake
if we use a bottom intake with a necked up design, I'm guessing it would look something like this. yes it's crude, but it serves its purpose. LOL.
we won't gain much by necking in the fuse, but anything is better than nothing if you want to go fast.
Old May 20, 2011, 01:37 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
So it seems that the inlet should be on the sides, right.
Old May 20, 2011, 01:40 PM
Joined Jan 2009
depends what we're going with. if it's a NACA hybrid, then the side makes more sense aerodynamically speaking. or if there's some way to make it a part of the nose, that could work too. top or bottom is pretty much out.
if we're going with pitot style inlets, they can be wherever they fit the design the best. it might be prudent to design the best shape around the inlets and wing planform that we choose. I think the inlets and ducting are the most important part..............kinda like designing an A-10 around the gun.
Old May 20, 2011, 02:26 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
LOL
Here is the laste sketch for tonight, with the inlet on the sides. see you
Old May 20, 2011, 02:42 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Awesome. I'd fly that.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old May 20, 2011, 04:06 PM
Joined Jan 2009
me too.
Old May 20, 2011, 06:34 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Looks like a mirage got busy with a concorde
Odysis is offline Find More Posts by Odysis
Old May 20, 2011, 07:34 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
More like a Delta Dart and a concorde (the trailing edge of the Mirage is a 90 degree angle while the Convair designs like the Delta Dart and Hustler had the trailing edge angled more toward the tail). I like it.
alexandermh is offline Find More Posts by alexandermh
Old May 21, 2011, 06:33 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Glad you liked it I moved the wings a bit forward, to get the CG clouser to mid fuselage.
I have posted a drawing so we can make some different looks on the side view, so go nuts......
By the way you can stop voteing, the platform is decided. But I can't stop the poll sorry.....
I am looking for idears to votes we need to do in the future, seens I can't stop the poll we need another way to do it.
Old May 21, 2011, 07:13 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Just a pic.
Old May 21, 2011, 07:56 AM
mrshea is online now
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
that is cool.
mrshea is online now Find More Posts by mrshea
Question Rc jet boat build HeliFried Racing Boats - Electric 126 May 20, 2011 04:05 PM
Question Rc Group App Clavin01 Site Suggestions / Complaints 1 Apr 14, 2011 08:02 AM
Discussion Newbie on RC Group's PhoenixFlyer Classic Pattern Flying 15 Apr 09, 2011 07:05 AM
Sold Blitzworks RC F-14 Jet thedeuce Aircraft - Electric - Jets (FS/W) 0 Mar 06, 2011 08:36 PM
