Old Apr 23, 2011, 07:29 PM
atesus is online now
Find More Posts by atesus
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
Build Log
My new toy - Miles 2M RES woody - Build log
Finally starting this build. This is a Philip Kolb design kitted in Turkey, has eye pleasing lines - at least for me, and will be quite a step up from my trusty Gentle Lady . The kit is laser cut down to the cap strips so it should go together quickly even at my speed. This will be fun!
--Ates
atesus is online now Find More Posts by atesus
Last edited by atesus; Apr 27, 2011 at 12:20 PM. Reason: Changed the thread type to "Build Log"
Old Apr 24, 2011, 10:38 PM
Noel Eberhardt is offline
Find More Posts by Noel Eberhardt
Cupertino, CA
Joined Dec 2008
Please keep up posted with your progress and comments. Being that you do such beautiful construction I'm confident it'll turn out real nice. Take and post pics as you progress.
Noel
Noel Eberhardt is offline Find More Posts by Noel Eberhardt
Old Apr 25, 2011, 12:28 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Best looking kit box!
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Apr 25, 2011, 11:00 AM
Cupertino, CA
Joined Dec 2008
Just curious, but where did you get the kit from? Did you bring it back from Turkey?
Noel E
Old Apr 25, 2011, 11:20 AM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
Noel E
Not that the thought didn't cross my mind, but not worth the hassle. I got it from Kennedy Composites.
Old Apr 25, 2011, 11:48 AM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
It would be nice to see a build thread. Heard lot's of good things about Miles 2M.
Sailhigh is offline Find More Posts by Sailhigh
Old Apr 25, 2011, 11:52 PM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
I'll try do my best with a build thread then. But it's gonna move slooooowly, just warning :P.
Old Apr 27, 2011, 01:56 AM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
This evening I went over the kit wood, checked weights etc. The sheet balsa selection (grain/density/stiffness) is good for the purpose as far as I can see, with crisp laser cutting. There was no wood in the kit with any significant blemishes, though I see some minor warping in the 4mm sheet which carries the stab pieces. I guess I'll steam the stab after assembly and dry flat under pressure. The plywood sheets are also of good quality, though the thicker ply sheet which is supposed to be 2mm is more like 2.2mm thick, so it will require some thinning down when it mates up with 4mm balsa pieces in the tail feathers. The hardware kit includes steel joiners, clevises, bolts, blind nuts, etc. The stripwood is nice and straight.
The kit seems to include pretty much everything that's needed to build the plane aside from the glue. I'll use Sigbond (aliphatic glue) and 30min epoxy where needed, and will try to avoid CA glues. Actually I am tempted to try the new Elmer's Carpenter's Wood Glue Max on this model. According to manufacturer's description, it contains wood fibers, thus sands easily and is waterproof. Gotta try it on some scraps first.
Old Apr 27, 2011, 02:02 AM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
I started the build from the stab. The parts go together like jigsaw piecesand the fit is very good. The two plywood E2 pieces are laminated and drying while the rest of the stab pieces are assembled.
Old Apr 27, 2011, 10:12 AM
balmy breeze is offline
Find More Posts by balmy breeze
San Jose, Ca
Joined Feb 2011
great thread...what are the black dots on the t-pins?
balmy breeze is offline Find More Posts by balmy breeze
Old Apr 27, 2011, 11:31 AM
Sailhigh is offline
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
If you are not in a real hurry, yellow carpenter's glue works really well. I've been using them on woodies for years and the planes are still held together solidly. I started using it when a couple of friends developed allergies with some CA's. Of course I still use epoxy in high stress area.
Old Apr 27, 2011, 12:02 PM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
Thanks BB. The black dots are nylon pin clamps from a2zcorp. They are a tight fit to the T-pins and help holding the parts down. $1.25/28pcs, very useful items indeed.
Sean, thanks for the recommendation. I'm not a fast builder, so the wood glues are fine with me. When I got back to building after a 20 year hiatus, I noticed that I had developed an allergy to CA glues so no more of that...
I glued some scraps together with Sigbond and with Elmer's Carpenter's Wood Glue Max and will compare tonight how it sands and how strong the bond is. I noticed that the Elmer's glue is much thicker than Sigbond, so will have to thin it down with purified water, maybe by 25% or so.
Old Apr 28, 2011, 11:44 PM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
Once dry, I sanded the laminated E2 assembly down to 4mm and joined the elevator parts together.
I sanded the edges of the stab top/bottom reinforcement pieces to smoothly transition down to the stab surface. I lined up the holes using the clevis studs borrowed from the hardware bag and glued the plywood parts in place, completing the stab/elevator assembly.
Old Apr 29, 2011, 12:06 AM
atesus's Avatar
Los Gatos, CA
Joined Aug 2009
The fin/rudder construction is similar to stab/elevator. I first laminated the horn mounts (E2s) and cut R7s from the 2x6mm spruce stock provided. The top end of R7 needs to be trimmed at 45 degrees, I do that after the glue dries.
Again I did the assembly against a straightedge. After everything was dry, I temporarily joined the fin and the rudder with masking tape and sanded their outlines together.
I touched up the pin holes with a damp Q-tip to get rid of them. I'm intending to spray paint the tail feathers and possibly the fuse.
On to the wings...
Old Apr 30, 2011, 12:23 AM
San Jose, Ca
Joined Feb 2011
sweet, that q-tip trick is new one on me, keep em coming, and thanks, need to get my black dots ordered.
Build Log Windlord a RES/NOS Woody "wing" kenb Thermal 136 Jun 17, 2014 06:32 PM
Found 2M RE or RES poly, RTF FGF Aircraft - Sailplanes (FS/W) 0 Apr 17, 2011 11:54 AM
Cool 3D Printer New Shop Toy..I wish!! c0dem0nkey Composites Fabrication 1 Mar 13, 2011 10:02 AM
Discussion Darts : Res - Woody - Nos June 16 - 17 Ray Hayes Sailplane Events 3 Jun 13, 2007 07:03 PM
