Old Jan 27, 2013, 01:38 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Thats pretty much how I do it too. No issues yet but I do get swirls.
josh18 is offline Find More Posts by josh18
Old Jan 27, 2013, 02:08 AM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
I always do a couple of coats of wax on my seasoned moulds and then I brush on watered down PVA. I found the full thickness PVA way too unforgiving, but when I watered it down it became a totally different beast!
I noticed a marked improvement if I leave the wax for at least an hour after bufffing off, then I give it another buff to shine the surface. This seems to let the PVA go on and dry like a mirror.
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Jan 27, 2013, 02:29 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Why use PVA on seasoned moulds.
Why are you still using PVA if the moulds are seasoned?
See my post #507 here with reference to a paper that Adam of WWWorks originally posted a link to:
http://www.rcgroups.com/forums/showt...339865&page=34
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jan 27, 2013, 03:45 AM
Joined Mar 2006
Dunno, just my routine...
Old Jan 27, 2013, 04:27 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Ive never been brave enough to use wax only either.
Old Jan 27, 2013, 06:55 AM
Joined Aug 2008
Do a test strip first, like I described on my thread.
Old Jan 27, 2013, 07:50 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Does the same apply to epoxy? That reference is for polyester - significantly different cure methods. I tried wax-only with epoxy once. Lost the plug, so stuck with PVA ever since.
Does the mould surface end up with the sheen, or shiny like normal PVA?
Odysis is offline Find More Posts by Odysis
Old Jan 27, 2013, 05:07 PM
Joined Aug 2008
Seasoned moulds only.
I suggest you read the article. Here it is again: http://www.rcgroups.com/forums/showt...339865&page=34
Wax only is not recommended for mould production. It is for seasoned moulds when producing parts from them.
Epoxy/vinyester/polyester moulds can be considered similar in terms of seasoning, so it seems.
Old Jan 27, 2013, 05:24 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Thats it Jim, time for me to man up! I will do some test strips to make sure, but next wing I will do with wax only! Here I come crisp masked paint lines!
Old Jan 27, 2013, 05:38 PM
Joined Aug 2008
The second set of wings for my moulded plank are in the moulds ready for spars, servo wires and such detail before joining.
I treated the moulds with wax only. No PVA. However, I did a small test strip first, which pulled off very easily (see my blog). I did this on the second pull (used wax only), because of their age. They must be close to a year old.
edit: I'll post the results after I pull them. I've no reason to expect problems though.
Old Jan 27, 2013, 05:52 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
If there is no paint then epoxy on epoxy can be a stubborn release even on a seasoned mold.
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 27, 2013, 07:32 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Thanks Adam, I'll make sure I do plenty of tests before I commit to moulding. Does it make it better that the mould and the part are made of the same resin? Either way I'll do some tests, maybe some ith paint and some without is a good idea.
Cheers- I havn't done any building for a while, I hope I remember how to do it!
Old Jan 27, 2013, 07:34 PM
Just fly it!
Cody, WY
Joined Nov 2007
I have done heaps of operations that used the same resin in the mold and part and had no problems. That may not be true with every resin though.
Old Jan 27, 2013, 08:13 PM
Joined Aug 2008
Is that with wax only Adam? Or with a semi-permanent? How seasoned?
Gives me cause for concern about my epoxy wing moulds.
Although, the test almost fell off.
edit:
Also, one of the skins started to lift off the mould slightly when I was removing the peel ply even though I tore it off in narrow strips. It sprang back onto the mould though. I'm not too concerned really.
Old Jan 27, 2013, 09:29 PM
Just fly it!
Cody, WY
Joined Nov 2007
Jim, I'm talking about using wax only. Semi's with the right resin/paint release better than anything that I have ever tried.
Discussion RC Heli 2 iPhone & iPad Application ethervision Micro Helis 3 Apr 21, 2011 10:02 PM
Discussion best epoxy/microsphere mixture for interesting application rmgrc Composites Fabrication 3 Apr 21, 2011 07:35 PM
Mini-HowTo Using XBee Explorer USB for FTDI application モU-blox GPSヤ alz3abi UAV - Unmanned Aerial Vehicles 0 Apr 04, 2011 06:08 PM
Discussion pva glue,pva release agent is there a difference avago Composites Fabrication 12 Sep 18, 2006 07:03 PM
Build Wingo with PVA instead of Epoxy ? JensJakob Foamies (Kits) 10 Jun 05, 2001 12:50 AM
