Is this the type of gravity feed air gun you are talking about? http://www.harborfreight.com/air-too...gun-47016.html or more like this one? http://www.harborfreight.com/air-too...gun-66222.html It doesn't look that hard to add to my list of things to learn. For cleaning, I assume that you just run a lot of warm water through the gun (so that it is not a one-use-only tool)? Thanks, John |
John,
Be sure to get the Harbor Freight gun with the 1.4mm tip, it will be useful for PVA and for 2K clear coats. For 2k color you might want a smaller tip, but that's off topic. After spraying PVA, clean the gun with warm water. Learning to use an HVLP gun is easy, just takes some practice and lots of fooling around with the fluid control, the fan pattern control and the pressure adjustment. -Alex |
Yep, But let me ask what primer did you use? What are the plugs made from? Any Bondo showing? What resin are you using? If you used a catalyzed polyester primer and have 100% coverage than you are probably OK. If you have bondo showing you may have issues even if its as smooth as possible. If you used any primer from a spray can it will probably stick. I typically use 1 piece plugs and splitter with alignment pins for a perfect mate. I am not a fan of 2 piece plugs. hard to get a good mate. Join in the mold where ever possible. You want to use a finish coat that is catalyzed. Duratec finishing primer is about the minimum. I prefer painting and polishing. Again with a catalyzed paint. Polyester gelcoat works but can be a lot of sanding and polishing. A 2 part urethane is easier. If you think you may have a potential issue by not using catalyzed products than you will need the PVA to be safe. Good luck with the project. |
You can use water to clean up your gun. Quote:
Typically 2 component catalyzed urethanes work best when using just wax. I've still seen epic failures with just wax and auto paints. Also, you want to make sure that your paint is fully cured. If the paint isn't fully cured it's reactivity will be heightened. The job of the wax is to provide slip. The role of the PVA is to create a barrier that blocks reactivity. BTW, you can't use just PVA. PVA needs to be applied on top of a waxed surface. |
All good information from you guys. I did spend a couple of months going through old threads here looking for tips and failures etc. before deciding to go down this path. Samotage and his JART build was a fun one.
My process:
Ok, so tomorrow I get a new toy HVLP spray gun and go play with spraying PVA and seeing how that goes. The nice thing about the PVA is that I can either peel it off or wipe it off with a damp cloth. Thanks to all. John |
Wax on top of PVA will be a nightmare. When you go to buff the wax, on top of the PVA, you will just tear the PVA right off the plug.
1) 4 coats of wax with 15-30 between applications 2) Let your last application of wax sit for 1 hour after buffing before applying PVA 3) Apply the PVA and let it fully dry (1 to 4 hours depending on temperature, humidity, and thickness) 4) Apply the the surface coat and let it get tacky to the touch 5) Start with light glass (1 ounce), then 2 ounce, then tight weave 3 or 4 ounce, then some heavier tooling fabrics. If you go to the tooling fabrics right away you will get the fabric pattern telegraphing all the way to the mold surface. |
What wax are you using? Partall #2 wax works well with PVA, Its a bit of a pain to polish out except when its fresh. Meguiars #8 is good also. There are others. Johnson's Past wax works. |
I use brushed on PVA over Partall #2 on my corian molds and never, ever have sticking problems. I'm doing wings, tails, and fuselages now and am getting quality better than I ever expected. I can't use many of the semi-permanent releases because of the solvents in them potentially harming my mold material.
R&G sells a very tiny cell sponge for PVA application. I have a bunch of them if you'd like to try them. The finish is absolutely mirror-like with this method, but it doesn't take to tight places well. I've had no complaints of surface quality at all. I'm not painting (DLG) FWIW. |
| Thread Tools | |
| Discussion RC Heli 2 iPhone & iPad Application | ethervision | Micro Helis | 3 | Apr 21, 2011 09:02 PM |
| Discussion best epoxy/microsphere mixture for interesting application | rmgrc | Composites Fabrication | 3 | Apr 21, 2011 06:35 PM |
| Mini-HowTo Using XBee Explorer USB for FTDI application モU-blox GPSヤ | alz3abi | UAV - Unmanned Aerial Vehicles | 0 | Apr 04, 2011 05:08 PM |
| Discussion pva glue,pva release agent is there a difference | avago | Composites Fabrication | 12 | Sep 18, 2006 06:03 PM |
| Build Wingo with PVA instead of Epoxy ? | JensJakob | Foamies (Kits) | 10 | Jun 04, 2001 11:50 PM |
