Espritmodel.com Heli Air
This thread is privately moderated by tom bacsanyi, who may elect to delete unwanted replies.
Old Apr 23, 2011, 05:22 PM
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
under construction
ELECTRIC DUCTED FAN PHYSICS
Contents:
1. SAMPLE ELECTRIC DUCTED FAN
2. SYMBOLS AND CONVENTIONS
3. WEIGHT AND MASS
4. AIR
5. FORCE=MASS TIMES ACCELERATION
6. ENERGY=ONE HALF THE QUANTITY MASS TIMES VELOCITY SQUARED
7. POWER
8. EDF SIZE
9. EDF THRUST
10. EFFICIENCY
Motor, Neu 1527 1.5y 8mm shaft
esc, Turnigy 200 amp "monster"
Fan, 125mm custom
Ducting, inlet ring and split thrust tube with 90% FSA outlet, 14.28 in^2
lipo, 4ea. Zippy 3600 6s 20C in series/parallel (12s 7200)
volts, 43.1
current, 146 amps (the meter reads 14.6mv or 146 amps on a 500 amp shunt)
watts, 6292
thrust, 20 lb. 1.6 oz.
v= velocity in feet per second
F= force in pounds
#= pounds
m= weight in pounds divided by g
a= acceleration
g= acceleration due to gravity or 32ft/sec^2
E= energy
P=power; watts, horsepower, or ft lbs/sec.
math is done using BASIC symbols in a search window, Google and most others will work.
* is multiply; 3*4 = 12
/ is divide; 7/2 = 3.5
- is subtract
+ is add
^ raise to the power of....; 3^3 = 27; 5^2 = 25; 16^(1/2) = 4; 27^(1/3) = 3
pi is 3.14......
3. Weight and mass.
Just because a large rock happens to weigh 32# on Earth and ~6# on the moon doesn't pin down its mass. If we divide it by g we get units of mass.
32#/32ft/sec^2 or 1#/1ft/sec^2. If we did this on the moon we would have 6/6 and get the same number. I'm going to jump ahead to show how this works.
The 32# rock is in a frictionless sled and we are going to push it with a force of 4# horizontally. How fast does it accelerate?
Newton's second law: F = m*a
Divide both sides by m: F/m = a or swap a = F/m
substitute numbers: a = 4#/1#/ft/sec^2 = 4 ft/sec^2
The units cancellation is confusing in linear format. I included them to show that the units are consistant. When using the search window, only the numbers would be used: 4/1 = 4 So the rock would gain 4 ft per second for each second it is pushed.
4. AIR
SLUGS:
The density of air is .0748lb. per ft^3 at sea level and 68 degrees F. We need to convert that to mass units and as in section 1, we will divide by g. .0748/32 = 0.0023375 this was cut and pasted from a search window result. In aerodynamics the mass units are called slugs.
Density correction for altitude:
I am at 900 feet elevation. A correction factor for elevation is -3.16% per 1000 ft. It is accurate enough for our purposes up to 10,000 ft.
.0023375-900/1000*.0316*.0023375 = 0.0022710215 We will round it to .002271 slugs.
Density correction for temperature:
The density of air varies inversly with the absolute temperature. My Temperature is 72F To convert to Rankin, 460+72= 532R. The standard air, 460+68=528R.
The inverse ratio: 528/532*.002271 = 0.0022539248 rounding to .002254 slugs. This was a small correction of about 1%. Not doing these two corrections would have contributed a 4% error.
F=ma is the cornerstone of the laws of motion. Birds bees planes helicopters all generate lift by accelerating air downward. The induced drag of a wing is proportional to the tangent of the downwash angle. The static thrust of an edf is proportional to the mass and proportional to the velocity of the efflux.
I have an edf with a nozzle of 14.28 in^2. What would the thrust be if the efflux was 250 feet per second?
Since this is a continuous process, we will take a one second slice. F=ma, we need mass. The cubic feet of air per second would be 250fps*14.28/144. Multiply that by .002254 slugs we previously calculated for the mass per second. We divided the nozzle area by 144 to convert in^2 to ft^2. The mass per second calculation would be: 250*14.28/144*.002254. This mass would accelerate to 250 feet per second in one second, that is our acceleration. we will put into the search window: 250*14.28/144*.002254*250. Here is the result 250*14.28/144*.002254*250 = 13.9701041667. rounding to 14 pounds of thrust.
Notice the velocity is in there twice. So we could have squared it but that would obscure what we did. We determined thrust from velocity. My edf has 20.1 pounds of thrust so what is the efflux velocity? We have to solve F=ma for velocity.
m = area*v*slugs and a=v/sec so....
F=area*v*slugs*v/sec.
divide both sides by area*slugs gives...
F/(area*slugs)=v^2. Take the square root of each side.
(F/(area*slugs))^(1/2)=v swap sides....
v=(F/(area*slugs))^(1/2). Do the numbers:
(20.1/(14.28/144*.002254))^(1/2) = 299.8735874083 Or 300fps. Convert to mph: 60/88*300 = 204.5454545455 rounding to 204mph.
If we took the 32# rock and threw it at 50 ft/sec, how much kinetic energy would it have?
E=mv^2/2 where m= lbs/g
E=32lbs/32ft/sec^2*(50 ft/sec)^2/2
The seconds cancel and one ft cancels leaving ft lbs, do the math....
32/32*50^2/2 = 1,250 ft lbs. A quantity of energy.
7. POWER
Power is a continuous flow of energy.
If we threw one 32# rock at 50 ft/sec every second that would be 1250 ft lbs/sec.
Convert to horsepower: 1250 ft lb*1 hp/550ft lb. The ft lb cancels leaving 2.27 hp.
Convert to watts: 2.27 hp*746watts/1 hp. The hp cancels leaving 1695 watts.
If we threw a continuous stream of 50 ft/sec tiney rocks at the rate of 32# per second, that would be the same 746 watts.
In 3. above, we calculated thrust from mass and velocity using F=ma. so in this case convert # to mass, #/g and 50 ft/sec per one second slice....
F=32#/32ft/sec^2*50ft/sec^2 =50lb
TO BE CONTINUED
300^2*.002254*14.28/144*300/2/550 = 5.4864409091 horsepower in efflux
6292/746 = 8.4343163539 watts input converted to horsepower
5.4864409091/8.4343163539 = 0.6504902921 (.65 or 65% is the calculated efficiency of the example fan as a ratio of the watts into the ESC and power in the fan efflux expressed in watts) This will be clarified in sections 8, 9, and 10.
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Dec 06, 2011, 05:49 AM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice work Tom, good to see physics applied to the hobby correctly. Klaus Schornhorst did the same several years back but he seems to have faded from sight as we all will eventually I think.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Latest blog entry: T/A 37 Tweet/Dragonfly
Old Dec 14, 2011, 11:53 PM
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Tom, can you share some of your construction methods you used to attach your blades to the machined hubs you made for the 6 and 12 blade fans?
Also, I'd love to ask you a question regarding pre-fan stators. Do you have any experience with pre fan stators? In turbojet engines, often there are pre compressor fixed blade stators that get the air rotating in the same direction axially as the compressor rotates. I'm wondering, in a layman's way, if this could potentially improve fan efficiency in some way.
Really why I'm interested in this is for airplanes without optimum ducting. I'm looking for ways to improve ducting issues in some of these cheap foamies with long ducts - the Hobby Top Gun F-100 comes to mind immediately as its one of my models in the production line up. The ducting is a little nightmarish though at least it is ducting - some don't even have that. But I was considering running the fan without a spinner on it and instead fitting a short rocket tube of the same diameter of the spinner in front of the fan and then it would have a static rocket nose cone in front of it to fair into the fan. The tube would be held in the duct by stators, and those stators would not just be flat but would introduce some small amount of swirl to the air to get it twisting in the same direction as the fan. Not too much, but just a little.
I'm being a little bit of a copycat here but I'm wondering of some of those other engines have something in these pre stators. Also, the thought of not having a spinner on the fan is another way the fan can be more easily balanced. The spinners tend to create balance problems in all but the best fans that are dynamically balanced. So if the pre stators can improve blade efficiency by offering optimized air flow at the fan face and the fan can be more easily balanced with less mass via no spinner then aside from the setup being more of a hassle, it may be an improvement?
Eddie P is offline Find More Posts by Eddie P
Old Dec 16, 2011, 04:44 PM
Official Boat Bum
Eddie P's Avatar
Joined Mar 2000
Also Tom, I was interested in a comment you made in another thread but thought I'd ask the question here as it's directed toward your fan knowledge and not so much the thread it came up in - here it is:
Phil,
The formula you used would only be correct if there were no least common denominator between the rotor and stator count.
My fan has 12 and 5 or 60 individual passages per rev so at 30,000 rpm you get 30 khz.
If it had 12 and 6 then there would be only 12 simultaneous passages of 6 blades so at 30,000 rpm you would get a powerful 6 khz. That is how a siren works!
I'm not sure how this goes, I can see 12 blades, 5 stators being 12 blades passing 5 stators in one revolution, or 60 blade/stator passes (12*5=60)
Is the fact that the fan blades pass the stators nearly simultaneously on the even blade count/even stator count the key for khz sound? I'm thinking it is - it's typically nice to have something other than a whole number when dividing blade count by stator count, right?
For example, I am re-fanning and motoring one of my older models. I have some very old Robbe Rojet fans in a 4 engine BAe-146. I'd like to maintain a nice sound that it currently has or even improve it along with a power upgrade it will get with more powerful brushless motors. It has 4 blade rotors and 3 blade stator shrouds in it's current stock configuration at about 200 watts per motor. I'm thinking of using a 5 blade rotor, or a 6 bladed rotor or a 9 bladed rotor at a little less than 300 watts per motor. What concerns me now is the stator count. Am I assuming correctly that I should hear some loud fan noise from the 6 or 9 bladed rotors due to the stator count?
My next experiment would be to fashion some stator blades to add to the shroud. This would not only increase strength of the motor mount but if it could fine tune the sound on say a 9 bladed fan it may be worth the hassle.
What do you think? Feel free to answer on PM and erase these posts if you believe this will clutter up your blog thread on fan design. Thanks again and thanks for posting your thoughts on fan design. It's a great subject these days with so many copycat fans running around with interesting features but questionable combinations of features.
Old Jan 31, 2012, 12:55 AM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
jcdfrd is offline Find More Posts by jcdfrd
Old Feb 01, 2012, 09:27 AM
mikecopey's Avatar
United States, FL, Oviedo
Joined Dec 2008
Originally Posted by jcdfrd View Post
mikecopey is offline Find More Posts by mikecopey
Beech Starship Under Construction IAD Scale Electric Planes 278 Jan 30, 2004 04:08 PM
Water tower under construction rccrashed Aerial Photography 66 Oct 07, 2003 12:25 AM
New floater now under construction Karl Bē Parkflyers 35 Aug 07, 2003 10:51 AM
Todd's Tiny under construction Tres Wright Parkflyers 30 Jun 23, 2002 11:20 PM
