Old Apr 11, 2012, 02:02 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ya that would probably do it, I glued all of it and had a weight on it while it dried to hold it in place.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Apr 12, 2012, 02:14 PM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
I used thick CA this time with accelerator and it worked well for 800 again. Will stick with them for a bit before trying 1300 again. I was using foam-Tec and I think it may be too flexible for this use case.
Syner01 is offline Find More Posts by Syner01
Old Apr 12, 2012, 07:06 PM
kid at 55 is online now
Find More Posts by kid at 55
Where did that tree come from
kid at 55's Avatar
United States, SC, Lancaster
Joined Nov 2010
Hey guys, does everyone run a prop saver or a prop adapter on their pop wing ?
kid at 55 is online now Find More Posts by kid at 55
Old Apr 12, 2012, 08:04 PM
Syner01 is offline
Joined Jan 2012
I do although I may look into a folding prop also.
Old Apr 12, 2012, 08:31 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Nah, I don't see the need and don't care to have a prop come off at the wrong time due to the oring breaking.
I own/fly/land lots of prop plane belly landers and have never broken a prop on landing (now watch me break one!@!)
Sammy70 is offline Find More Posts by Sammy70
Old Apr 12, 2012, 08:38 PM
Syner01 is offline
Joined Jan 2012
Can anyone suggest a suitable motor/prop for large popwing and these batteries
http://www.hobbyking.com/hobbyking/s...dProduct=18204
And/or these
http://www.hobbyking.com/hobbyking/s...dProduct=18208
Old Apr 12, 2012, 09:12 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
Not sure why your going 4s but your going to stuggle to find a motor light enough that can handle 4s. If your looking to go fast and can use 3s try this motor
http://www.graysonhobby.com/catalog/...mbo-p-414.html
or this (its heavy) for more speed 90+mph
http://www.graysonhobby.com/catalog/...esc-p-645.html
watch this video....he uses the first motor I listed
Banded from rcgroups.com for political comments! Foamy Racer, 2212-06 Super Mega Jet motor from GH (4 min 52 sec)
Edit: sorry I stand corrected, the second motor (super mega jet) will run on 4s but your going to need at least a 60a esc
-Kevin
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 12, 2012, 09:15 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Any 2208, 2210, or 2212 motor will fit/work. You just need to figure out how fast you want it to go and pick a Kv to suit.
Something in the 1900-2200Kv range will be pretty fast on 3s and a 6x4 prop...
Old Apr 12, 2012, 09:25 PM
Syner01 is offline
Joined Jan 2012
I'm going 4s because most of my batteries are 4s.
-Kevin
Old Apr 12, 2012, 09:35 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
I figured as much.....
Old Apr 12, 2012, 10:09 PM
Syner01 is offline
Joined Jan 2012
Retracted
Old Apr 13, 2012, 05:37 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
???? you lost me
Old Apr 13, 2012, 08:19 AM
bluemeane is online now
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
I asked once but never really got much of an answer...
How well do these slow down? Can they be floaty??
I am torn between this (the mini popwing) and the hacker Skyfighter (basically a re-branded mini Swift II)
Any help making the decision???
bluemeane is online now Find More Posts by bluemeane
Old Apr 13, 2012, 09:35 AM
Sonny Cheeba is offline
Find More Posts by Sonny Cheeba
United States, FL, Fort Lauderdale
Joined Feb 2012
Got mine just about built..... Running a Graysons Hobbies V2 Super Jet motor, with a Turnigy Plush 40a ESC, good ole Orange Rx, Tower pro metal gear servos, and Nano Techs 3s 2200mah with a 6/5 Prop...... I'm pretty sure this setup will get this thing moving pretty fast..... Any suggestions out there on how to configure the CG since its a much heavier setup then the "recommended"???
Thanks all,
Sonny
Sonny Cheeba is offline Find More Posts by Sonny Cheeba
Old Apr 13, 2012, 01:54 PM
Syner01 is offline
Joined Jan 2012
???? you lost me
i was going to say maybe i need something larger with metal mount to hold a motor that supports these batteries. like a ritewing...but then i saw they are discontinued lol.
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
