Old Feb 16, 2013, 03:28 AM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Originally Posted by IFlyRCs View Post
I'm wondering if the plane was found.
Over a mile away but in an open area.
Found in 30 min., zero damage. Here's footage from the following day. To the fun police: These are my neighbors, my hood. They're used to my BS and know where to come knockin if a 900mm piece of EPP hits their garden gnome.
Snow Bash (3 min 43 sec)
Alpha1actual is offline Find More Posts by Alpha1actual
Old Feb 16, 2013, 08:13 PM
Joined May 2012
Super easy to launch
Popwing Snow Launch and Flyby (0 min 50 sec)
Old Feb 25, 2013, 11:45 AM
Bilymac is offline
Find More Posts by Bilymac
Auburn, CA
Joined Feb 2009
I have a leftover power system from an old build: Park 480, HS 55's, Spektrum RX. Will this setup work in the 900mm Pop Wing? Thanks for any insight.
Bilymac is offline Find More Posts by Bilymac
Old Feb 25, 2013, 11:55 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
The kv of the motor is probably too low and you would need too large of a prop.
EDIT: Wrong! - see below
IFlyRCs is offline Find More Posts by IFlyRCs
Old Feb 25, 2013, 12:34 PM
Joined May 2012
Funny you mentioned the 480. I've been testing an Eflite park 480 1020kv on 4s with my 900mm wing. Currently it's running 4s 2800mah, 8x6 APC. 20a draw @full, 7-8a cruise. An 8x4 worked well too, 17a draw @full. This is with the weight of a 3s 850mah up top, and FPV gear.
Old Feb 25, 2013, 01:07 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Well I stand corrected.
Didn't know it run on 4s.
I guess it would even work on 3s.
Thanks for the info.
Old Feb 25, 2013, 01:25 PM
Joined May 2012
3s would work with a larger prop (10x6 or 11x6). With lower kv, 4s should be ok as long as you don't exceed the max rated watts/amps. I found the sweet spot with an 8x6.
Old Feb 25, 2013, 04:12 PM
Bilymac is offline
Auburn, CA
Joined Feb 2009
Thanks for the quick replys. Gives me something to work on.
Old Feb 28, 2013, 08:10 PM
Joined May 2012
Short cruise @beach with the popwing. Pushing further with the park 480 on a 4s 2800mah, 8x6 APC.
Stormy day at Cedar (8 min 7 sec)
Old Feb 28, 2013, 10:08 PM
DJO is online now
DJO
Find More Posts by DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Check my most recently blog post as of the moment for more information on my FPV PopWing v2.0 build - coming soon to my YouTube channel!
Yo everybody,
So recently I've been building a lot of FPV setups on here, and I've got the itch to get another setup for myself up and flying. I LOVED my old PopWing, it was a great FPV platform. 25 to 30 minute flight times, small, durable, fast and agile. Overall it flew great! After a while though, it was pretty beat up and ripped apart after I did so many modifications to it. So I ordered a new PopWing kit, this time the painted version
For the most part I'll be running a very similar setup on this one. However, this one will be laminated
The setup will include:
-900mm NitroPlanes PopWing KIT
-Lightweight Laminate (10 feet)
-ExceedRC 1360kv ~52g Motor
-FLiPower 30 Amp ESC w/BEC
-6x6 Pusher Prop (to be tested)
-1350mAH 3S 30C EFlite Battery
-Two 9g Suppo Servos
-FrSky FASST TFR6-A 6ch RX
-200mw 5.8 GHz vTX (and RX) - EDIT: 150mw 1.3 GHz vTX + 900mhz/1.3 GHz RX
-PZ0420 or 520 TVL FPV Cam - EDIT: 480 TVL Micro Cam
-SpiroNet Antennas (to be tested)
-8'' LCD FPV Monitor on the Ground
-Probably a 2200 mAH 3S for the RX + TV - EDIT: Probably a 1300 mAH 3S instead
The FPV setup will operate similarly to this one that I just recently shipped out to a member on here (but I don't have a GoPro HERO3 to plug in ):
I'll be using a tap lead off of the main 3S battery with a filter (top right, one of those) to eliminate some RF noise from entering the system. ESC and RX are ready to be glued into the foam with some painter's tape to keep it all nice and clean.
I can't wait to get back into FPV! In the future I'll also be buying one of those keychain cameras with the "D" lens for some good HD footage from the PopWing.
Stay tuned!
Dan
I'll be laminating this one and probably be using it for FPV as well like my old one!
Dan
DJO is online now Find More Posts by DJO
Old Mar 11, 2013, 07:53 PM
Joined May 2012
playing in strong winds
crazy wind (2 min 8 sec)
Old Mar 11, 2013, 07:55 PM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Having fun in very light winds soon to be doing FPV with this PopWing v2.0 - very soon!
Episode 67: The FPV PopWing v2.0 Flies! (0 min 0 sec)
Dan
Old Mar 12, 2013, 12:20 AM
FD Pilot is online now
Find More Posts by FD Pilot
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
New Pop Wing Build
Just finished my first Pop Wing build. Made some modifications I think added to the utility and flight characteristics of my Pop Wing. Maiden was uneventful, I lucked-out on the setup and got close to perfect. This wing flies great, lots-o-fun, all smiles here
FD Pilot is online now Find More Posts by FD Pilot
Old Mar 12, 2013, 04:38 PM
Bariboy is offline
Find More Posts by Bariboy
United States, NY, Kingston
Joined Feb 2006
IN the building process of the exact same popwing! My starboard elevon is not nearly as mobile as the port. It appears to be a tad thicker on the material left behind when it was made. Any recommendations on dealing with this? Scott
Bariboy is offline Find More Posts by Bariboy
Old Mar 12, 2013, 04:43 PM
Joined May 2012
Stealth
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 02:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 04:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 12:01 AM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 02:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 02:02 PM
