Old Feb 11, 2013, 11:10 PM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Springfield
Joined Jul 2004
http://www.mayor-hobbies.com/shop/pr...?id_product=21
i did not buy it from here but atleast you can see the specs of the motor
snolord1 is offline Find More Posts by snolord1
Old Feb 12, 2013, 12:20 AM
terrasmak is offline
Find More Posts by terrasmak
Crew Chief
Las Vegas
Joined Jan 2009
Originally Posted by oneagleswings View Post
Thanks! When I get one of the 900mm wing's I'm going to go with the Power up 400 zoom from HURC. I've got everything for that one already except for the motor. I want to try out the mini first though.
Just get one of each, its only about $60 for the pair.
terrasmak is offline Find More Posts by terrasmak
Old Feb 12, 2013, 12:33 AM
oneagleswings is offline
Find More Posts by oneagleswings
United States, NC, Lexington
Joined Jul 2012
I guess it would be if you lived close to Nitroplanes warehouse and could go over and pick it up. Just for the Mini kit without electronics and shipping it's 41+ dollars. They want 15.86 to ship a 25.00 foam kit.
oneagleswings is offline Find More Posts by oneagleswings
Old Feb 12, 2013, 01:01 AM
rhodesengr is offline
Find More Posts by rhodesengr
United States, CA, Livermore
Joined Jan 2012
with the cost of gas, that is not such a bad deal. Buy more stuff to amortize the shipping.
rhodesengr is offline Find More Posts by rhodesengr
Old Feb 12, 2013, 01:28 AM
Crew Chief
Las Vegas
Joined Jan 2009
Buy 2 and shipping is only about $1 more , find a friend and order a few planes.
Old Feb 12, 2013, 10:25 AM
FireFlyer451 is online now
Find More Posts by FireFlyer451
FireFlyer451's Avatar
United States, CO, Denver
Joined Jan 2013
More Popwing 900 fun. When balanced out it is a lot of fun to launch and fly.
Popwing 900mm - Launch a flying wing (0 min 14 sec)
FireFlyer451 is online now Find More Posts by FireFlyer451
Old Feb 12, 2013, 06:46 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
I was thinking about trying this one?
http://www.valuehobby.com/emax-cf2805-outrunner.html
My friend has a HyperFlea running that motor on 800 2s.
It screams.
That will work well if you want to use your 2s batts.
I think he's running 7x3 on it. I can find out if you need me to.
HXT500's will work ok, that's what I used.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Feb 12, 2013, 08:57 PM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
If he's getting the mini he would have to make the width of the prop slot wider as I have a 4" prop and I'm almost hitting the edge of the elevons. I think 5" before u have to start modding
Old Feb 13, 2013, 01:26 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Good point.
I have a 6x3 on mine with a little trimming.
He could go 6x4 with that motor.
Old Feb 13, 2013, 07:25 AM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
Yes he could no doubt but its not going to be as efficient
Old Feb 14, 2013, 05:31 AM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Unexpected landing 3500' out
Winter Cruise (4 min 4 sec)
Alpha1actual is offline Find More Posts by Alpha1actual
Old Feb 14, 2013, 05:34 AM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
Can you show your (for those who record on-board flights) camera mounts? I want some ideas on how to mount mine, it that doesn't bother you! Thanks!
Stuka_99 is offline Find More Posts by Stuka_99
Old Feb 14, 2013, 10:56 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I'm wondering if the plane was found.
Over a mile away but in an open area.
Old Feb 14, 2013, 11:31 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Originally Posted by snolord1 View Post
Hmmm idk on 3s maybe but on 2s I have doubt. But I am not the motor guru. Maybe someone else that knows a bit more,can chime in with recommendation
I had some leftover Turnigy T1811-2900kv motors and 5x3 props from a destroyed micro quad and I mounted one to the Mini Popwing. Its worked pretty well so far with a 2S battery.
epyonxero is offline Find More Posts by epyonxero
Old Feb 14, 2013, 08:32 PM
kc10kevin is offline
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
I'm also interested as well. Also what FPV set are you using. CP or linear? Freq? Great video clarity!
kc10kevin is offline Find More Posts by kc10kevin
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 02:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 04:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 12:01 AM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 02:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 02:02 PM
