Old Feb 04, 2013, 12:19 AM
whirlcap is online now
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Double 900 size Popwing vertical take off
Here is a nice short video of two 900's doing vetical take off together. Enjoy
Double Popwing Vertical Take Off (0 min 27 sec)
whirlcap is online now Find More Posts by whirlcap
Old Feb 04, 2013, 08:32 AM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Springfield
Joined Jul 2004
Nice.
snolord1 is offline Find More Posts by snolord1
Old Feb 04, 2013, 09:40 AM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
Good one! Does it fly straight off or does it need full elevator correction whilst doing these verticals? I'm trying to kick it off my foot like in the nitroplanes video, up till now only disaster lol
Stuka_99 is offline Find More Posts by Stuka_99
Old Feb 04, 2013, 10:20 AM
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
I was the video guy for that one but my mini requires full down input right as the elevons leave the surface or it will nose up and over into the ground. Not sure how the 900's handle on vertical.
Old Feb 04, 2013, 11:59 AM
Stuka_99 is offline
Callsign: Zulu
Stuka_99's Avatar
Joined Feb 2011
Thanks for your info! Will try this next week. BTW, again, great vid!
Old Feb 04, 2013, 10:51 PM
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Got a combat with Popwing knockout
Here is another one with a hit this time . A couple of Popwings collide and one doesn't fly away
Popwing Tango (1 min 43 sec)
Old Feb 06, 2013, 02:32 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Night flight in snow and wind.
Lunar Sessions: Snow and wind (8 min 28 sec)
Alpha1actual is offline Find More Posts by Alpha1actual
Old Feb 06, 2013, 08:25 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
That is really cool.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Feb 06, 2013, 08:38 PM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
I agree
Mine is finally ready to fly
Old Feb 07, 2013, 05:01 AM
Joined May 2012
Originally Posted by snolord1 View Post
I agree
Pretty bright! Those strips sip up 12v?
Old Feb 07, 2013, 09:55 AM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
Yes 12v. I think there's more to be installed
Old Feb 09, 2013, 10:31 AM
Dynasty0218 is offline
Find More Posts by Dynasty0218
Dynasty0218's Avatar
Joined Feb 2013
I was wondering if someone could answer a few questions for me. First off would be, is the 900mm version a good first 4 channel plane? Would I be able to use 2 part epoxy glue for the entire build? Also, I read that the servo wires are a bit short and some servo extensions are required, is this correct? Thanks in advance for any reply!
Dynasty0218 is offline Find More Posts by Dynasty0218
Old Feb 09, 2013, 01:47 PM
rhodesengr is online now
Find More Posts by rhodesengr
United States, CA, Livermore
Joined Jan 2012
first of all its not a 4 channel plane. Two elevons and throttle so its 3 channels. There is no rudder.
You can use epoxy but you'll have to wait more in between steps. I used hot glue, several types of CA and epoxy in a few places. Hot glue really works very well for gluing the foam piesces together but its too thick for gluing in the spars. My servo wires just barely reached but I added a 3" extension on one side. It depends on how you lay out the components. They are marginal. Have a couple 3" extensions around.
As to whether its a good choice depends on what else you have flown. I found it a little tricky to find the initial setup (CG and elevons trim) to get it to fly. My first few try ended in immediate nose dives. By the time I got it working nicely, it was a little beat up. Flies great now. Tons of fun. In fact I am off to fly it now. Thinking about upgrading the motor to a CF2812.
rhodesengr is online now Find More Posts by rhodesengr
Old Feb 09, 2013, 04:03 PM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
I wish I could fly. 3feet of snow put a stop to that notion
Old Feb 09, 2013, 04:40 PM
Joined May 2012
Nonsense. Winds dying down to 9mph tonight. That 3' of snow we got hit with makes for illuminated fields and cushy landings
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 02:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 04:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 12:01 AM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 02:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 02:02 PM
