Fpv
HI,
Thought I would share some FPV vids from my Teksumo. I have two teksumos and love em. Such a fun plane! I am running a 2826 2200kv motor with 7x4 prop and 2200mah 3s battery. Oh yeah they're tough as anything too...a few crashes in the vid. Cheers, Gim
Hope that helps! Don |
Latest blog entry: D100
Las Vegas
Joined Jan 2009
Still can't decide on what motor to get . This one http://www.headsuprc.com/servlet/the...00-Zoom/Detail or something slightly smaller.
United States, CA, Livermore
Joined Jan 2012
You guys using APC or APC style props with spacers, I found that spacer can fall out when I land or crash. Do people glue these into the prop? |
Las Vegas
Joined Jan 2009
Personally, I would use a 2200mah battery with at least 25C (or higher C rating). The 2200mah packs balance out well on the Popwing and you get better flight times. With the 1300mah packs, you'll likely need to add "dead weight" up front and the flight times wont be more than maybe 5 minutes if you fly "sporty" like I usually do. With my current 1450kv setup, I use about 20A at full throttle and 2200mah 25C Turnigy packs. I'm getting between 10 and 20 minute flights depending on how I manage the throttle. I can "putt around" at half throttle and just float around forever, or I can go wide open for the entire span of the battery and get about 8 minutes per pack. With the Power Up 400 "zoom" 2200kv, you'll probably be drawing about 28A at full throttle so that will drain your batteries a little faster. You will probably have flight times between 5 and 15 minutes depending on how you manage the throttle while you're flying. Seeing as the amp draws are up in the high 20's with the power up 400 "zoom", I would recommend the 2200mah 30C packs from Turnigy. $16.52 a piece isn't too bad. ![]() Also, I would get at least a 35A ESC. It's always good to have a little safety margin in there. A 40A ESC would be even better. And there are only two servos so a 2A or 3A "internal bec" should handle that with no trouble at all. Here's a couple of good ones... From HeadsUpRC... HURC 40 Amp Brushless Motor ESC w/ 3A BEC From HobbyKing... H-KING 35A Brushless Motor ESC w/ 2A BEC Seeing as you will be ordering from HeadsUpRC anyhow, I would probably just get the Hurc 40A. It'll get to your house MUCH sooner and shipping is soooo cheap! And Jeff's customer service is excellent!
Joined Jan 2012
I looked at this but didn't see how to get a 2200 mounted without getting into very thin foam. I already snapped the nose off once with a 1300 battery which just uses the standard battery pocket. How did you mount the 2200 and keep the nose strong?
| Thread Tools | |
| Question Techone models?? | lectroglide | Indoor and Micro Models | 5 | Aug 07, 2011 01:54 PM |
| Sold Techone Energy EPP Foamy | Wattsup23 | Aircraft - Electric - Airplanes (FS/W) | 9 | Mar 31, 2011 03:28 AM |
| Sold Techone Piaget 3D EPP New in box $45 shipped! | Lindy757 | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 17, 2011 11:01 PM |
| Discussion TechOne F3P??? | cglynn | Indoor Pattern/F3P | 6 | Mar 11, 2011 01:24 PM |
| Question techone malibu 2 or techone aeolus? | genesis96 | Indoor Pattern/F3P | 16 | Jan 19, 2011 01:02 PM |
