Old Dec 14, 2012, 12:55 AM
gp125racer is offline
Find More Posts by gp125racer
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
Thanks for the link.
What kind of speed are you seeing on that setup? I'm hoping to put a camera setup on it eventually so I want to haul a little extra weight and not have it be too much of an issue.
Don
Originally Posted by rocketscience View Post
I use this one... very similar specs. Might save a couple bucks. 6x4 apc.
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Old Dec 14, 2012, 01:01 AM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
Don
Never clocked it but here:
pop wing onboard 2 (5 min 36 sec)
and i'm uploading this one. I reduced throws on the servo arms and changed the 808 cam settings. (give it a while to process)
popWingCam (0 min 0 sec)
rocketscience is offline Find More Posts by rocketscience
Old Dec 14, 2012, 01:15 AM
gp125racer's Avatar
Joined Feb 2005
Looks sweet! Thanks for sharing.
Santa needs to place an order for me now
Don
Old Dec 14, 2012, 07:13 AM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
Try adding some reinforcement to your vertical stabs. They are pretty flimsy and might be flapping in the wind a little. If you have a key chain cam, stick it on the wing pointing to where you think you might be getting the flutter and see what is doing it the easy way.
Edit: I just re read your post. You are saying you can see them flutter from the ground?
Schoolya is offline Find More Posts by Schoolya
Old Dec 14, 2012, 08:32 AM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Yep. I fly it right in my yard most of the time. And I do a lot of high speed low passes so it's fairly easy to see the "flutter" when it happens.
But I like the key chain cam idea. That might shed a little light on things when you're right up and personal with the wing.
Speaking of those key chain cams..... Who has the best prices on them?
Also, I know some models are better quality than others as far as resolution and all that. Which one is considered the best one?
We can keep that part of this to PM's so we're not hijacking the thread.
Thanks.
Hit N Run is offline Find More Posts by Hit N Run
Old Dec 15, 2012, 02:47 AM
Not a six pack
USA, IL, Chicago
Joined Jul 2008
here's all the info you ever need. I like the HD wide angle one (#16 HD wide angle). Check for updates though. They come out with a new one every minute it seems.
http://www.rcgroups.com/forums/showt...=50&page=10000
here's a video with the camera under the brim of my hat. Flying of course.. the mini popwing.
mini pop wing in the dome 1 (5 min 36 sec)
Old Dec 15, 2012, 07:41 AM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
the control surfaces on this are somewhat flimsy too, you could easily get flutter with no loose linkage due to the foam just flexing.
Old Dec 15, 2012, 09:11 AM
Hit N Run's Avatar
Joined Nov 2011
Well, the winds are decent today (7 to 10mph) so i'll be flying down at the club field in a couple hours. I will adjust the CG a little each way and run through a battery pack at each adjustment. I'll let you know how it all turns out.
If it still does the fluttering, then i'm going to consider running a strip of balsa on each elevon to stiffen them up. If THAT doesn't do it then i'm just going to chalk it up to "airframe potential" and that they just can't take those high-G maneuvers without the occasional elevon flutter here and there.
I'm running an RCTimer BC2208-14 (1450kv) brushless with a 7X6 prop so there's plenty of torque coming out of it. Possibly part of the cause of the flutter. Speeds are guesstimated around 50 to 55mph at WOT. Nothing crazy by any means for a wing like this, but still maybe past the limit for stable flight? We shall see....
Old Dec 15, 2012, 03:29 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
I am on my second popwing now. The last one i went into a dive and full speed and it destroyed its self in flutter. It was significantly reenforced too. Im guess it was at about 70mph when it went nuts. I still landed it pretty smoothly, so the electronics made it.
Old Dec 15, 2012, 05:36 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Make your next wing an Assassin, it will take direct dives into the ground In stride.. Not to say the Popwing isn't a great wing, I have one of each.
whirlcap is offline Find More Posts by whirlcap
Old Dec 18, 2012, 11:39 AM
Captain Ron is offline
Find More Posts by Captain Ron
STOP CALLING THEM "DRONES!!!"
Captain Ron's Avatar
Las Vegas, NV.
Joined May 2009
I finished adding leds to my mid-sized Popwing. It came out great. I can't wait to fly it.
Captain Ron is offline Find More Posts by Captain Ron
Old Dec 18, 2012, 02:56 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Interesting layout.
My problem is keeping up with top and bottom.
All you have is the blue tips to tell.
Let us know how it goes.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Dec 18, 2012, 05:25 PM
Las Vegas, NV.
Joined May 2009
Those blue LEDs are super bright so I should be able to tell top from bottom. Most of the time I will be looking at the bottom of the plane while flying so it should be ok. It's windy and rainy now so maybe I can fly it later in the week.
Old Dec 19, 2012, 07:56 AM
SpinningProp is offline
Find More Posts by SpinningProp
SpinningProp's Avatar
Joined Jan 2012
Short little video of my PopWing w/808 cam mounted on top.
Pop-Wing 900 takes to the sky (1 min 41 sec)
SpinningProp is offline Find More Posts by SpinningProp
Old Dec 19, 2012, 05:44 PM
Las Vegas, NV.
Joined May 2009
Great video!
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
